Question about Toshiba 42H81 42" Rear Projection Television
Toshiba 42h81 picture shifted
A few days ago the picture shifted off center to the right. As a result of the convergence is off, green shadow around white objects and the overall picture is much darker. I have used the service menu to try and correct the convergence but it hasn't help much. Would resetting the HPOS back to the original code help? Does anyone have the default values for the 42H81? Thank you Henry
    Genius:
  • 1,694 Answers
Are you still working on your set? I can help......T.
Posted on Nov 23, 2007
The picture is "ghosting" or doubled
The tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost like $300-350 for parts and labors.
Nov 12, 2010 | Toshiba 42H81 42" Rear Projection...
Cannot correct convergence the green line is double
The tv convergence board is dead.Any colors lines R,G,B mis alignment,have colors shadows or 3D picure look alike.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv convergence picture problems.The shop,will cost u $300-350 for parts and labors.
Nov 06, 2010 | Toshiba 42H81 42" Rear Projection...
Shadowed picture and red/blue convergence is far off
This is a convergence failure, common on this type of tv. here is a tutorial I made:
http://www.fixya.com/support/r5001731-convergence_diagnosing_convergence
Let me know if I can be of further assistance.
Sep 09, 2010 | Toshiba 42H81 42" Rear Projection...
My picture is wavy and out of focus. when i touch the auto focus it goes through the function but ends with failure. it is a toshiba 42h81.
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 14, 2010 | Toshiba 42H81 42" Rear Projection...
Toshiba model 42H81 projection tv receiving blue and yellow shadows on screen.
Convergence is dead.Know how to solders?Must replaced the 2 convergence ICS and all it resistors.Tv Repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300 for parts and labors.
Feb 06, 2010 | Toshiba 42H81 42" Rear Projection...
Shadows on the screen
You have convergence output failure. The output ICs will need to be replaced and possibly a small component like a resistor or two as well. Expect to pay a service company $350-$450 to resolve this.
michtech
Feb 11, 2009 | Toshiba 42H81 42" Rear Projection...
you need to replace both of your convergence ICs they are STK392-110 you can get new replacements at the following link and they provide free instalation instructions with pictures. Heres the link
http://servicemanuals.vstore.ca/
May 29, 2008 | Toshiba 42H81 42" Rear Projection...
Toshiba Model # 42H81 Picture Problem
Can you describe the issue a little more? It may be a convergence issue which is quite common on big screens. But there are quite a few issues that can cause a bad picture.
If it's convergence, you'll be able to tell by going to a news channel and looking at the text. If the convergence is bad you'll see a ghosting like image of 2 or 3 letters for each one that should be there.
Nov 25, 2007 | Toshiba 42H81 42" Rear Projection...
Toshiba 42h81
Replace convergence IC's = requires chassis removal =
Usually about a 400.00 job.................T.
Nov 07, 2007 | Toshiba 42H81 42" Rear Projection...
Toshiba 56H80 Convergence Problem?
There are 2 large IC's in your set and one of them has burned out. These are called convergence output IC's and are usually the STK392-010's. A good idea would be to go ahead and replace both with the newer, upgraded STK392-150 IC's. A good tech can change those IC's in about an hour and a half, and when I do a housecall for a set like that I charge $150, but shops in your area will vary so be sure to ask around.
Sep 07, 2007 | Toshiba 56H80 56" Rear Projection...
Toshiba 42H81 42" Rear Projection Television Logo
112 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
