Question about Samsung SGH-E530 Cellular Phone
Samsung e530 ringer not working
My Phone will only flash up with number and no ringer I have looked at settings chosen ring tone which rang then saved it however when anyone calls the ringer does not work
    Genius:
  • 2,920 Answers
I would put in for a replacement phone with samsung since the one you have is faulty. they usually replace them if theres a problem with them.
Posted on Jan 31, 2009
Somehow I have a bell icon on the screen at the bottom left with the words OFF beside it and now the phone does not ring only the ring on the fax/printer. Thanks Margaret
Hi margaret, is there a ringer switch either on the phone handset, or is there an option in the the fax settings to go directly to print. The issue sounds fairly straight forward, somewhere the phone ringer, or the settings for the phone to ring has been inadvetently switched off. Some investigation shoud bear fruit
Jun 08, 2015 | Bell Lands Phones
I want to take off the ring silencer on convoy 3
I use Convoy 2. Go to "Setting" and select "Sounds settings".Select "Call Sounds" and select "Call ringtones". Then select "Call ringtones". Find "no ring" if you see it just select the ring tone you want and test the ring tone. I hope it is work for Convoy 3.
Sep 28, 2014 | Samsung Convoy Cell Phone
How to change the ringtone
http://service.us.panasonic.com/OPERMANPDF/KXTGA101.PDF
When you get to ringer settings press select, then using the arrow keys scroll to ringer tone, choose one of the tones or melodies then select save and then select off to get out of the menu you should have chosen a new ring tone.
Jun 05, 2014 | Panasonic KX-TGA101S Cordless Handset
Line 1 stopped ringing. The light lights up but does not make a sound. This is the 2nd unit we have had to do this
To program the ringing on the cordless handsets:
Press {MENU}.
2 Scroll to “Ringer setting” by
pressing {V} or {^}, then press .
3 Scroll to “Ringer volume” by pressing
L The current volume is displayed.
4 Press {V} or {^} to set the volume.
L Each time you press {V} or {^}, the
volume will alter and the chosen volume
will sound.
L To turn the ringer off, press {V}
repeatedly until “Ringer off?” is
displayed.
5 Press .
L Confirmation tone is heard.
Sep 13, 2010 | Panasonic KX-TG4500 Phone
Nokia 1661 my phone not ringing why ?
I had the same problem with mine. when I would go to tone settings every time I tried to hit ring tone it would turn off the phone and restart, by the way in ring tone it was blank. No matter what I did it wouldn't work. So I went to settings then restore factory settings entered the code. It reset the factory settings, then when I went back to tone settings the ring tone said Nokia Tune so I hit enter and it gave a list of all other ring tones, then it worked so my phone finally rings.... Hope it works for you.
Mar 22, 2010 | Nokia 1661 Cell Phone
Change ringer tone
Message/Ringer Lamp: The Message/
Ringer lamp informs you visually that you
have a message or a call.
When you receive a call, the lamp
flashes depending on the ringing pattern.
When the ringing pattern is set to Single
(Slow flash), Double (Moderate flash), or
Triple (Rapid flash) in your PBX, the lamp
flashes. When the other ringing patterns
are set in your PBX, the lamp may not
flash. (e.g., S-Double, Call Waiting
Tone1).
When someone has left you a message,
the lamp is lit continuously.
Please note that the above indicates that ring patterns are set in the the PBX. These are issues that require a real person to sit at the main system and program the features that users need. I hope you have an I.T. person that knows your phone system. If you don't, you'll have to find a communications company in your area that can program your system. Thanks for using Fixya.
Jan 19, 2009 | Panasonic KX-T7730 Corded Phone
How to inactivate melody ringer
Base unit ringer tone
(use either the handset or the base unit)
Make sure the base unit is not being used.
Setting the base unit ringer tone by using the
4 Select the desired ringer tone by pressing [d]
or [B].
• The handset will ring and the ringer tone will
change. If the ringer volume has been turned off,
the handset will not ring
• You can also select the ringer tone by pressing [1]
to [7].
5 Press Save, then press [OFF].
Press VOLUME [<] or [>], then select the desired ringer tone by pressing
[1] to [7].
[1] to [3] : Bell ringer patterns [4] to [7] : Melody patterns
• After pressing VOLUME [<] or [>], the base unit will ring using the current ringer
tone.
• The base unit will ring and the ringer tone will change.
• To stop ringing, press [STOP].
1 Press [MENU].
2 Scroll to “Initial setting” by pressing [d] or [B], then press
Select.
3 Scroll to “Set base unit” by pressing [d] or [B], then press Select.
4 Press Select at “Ringer tone”.
5 Select the desired ringer tone by pressing [d] or [B].
• The base unit will ring and the ringer tone will change. If the base unit ringer
volume has been turned off, the base unit will not ring
• You can also select the ringer tone by pressing [1] to [7].
6 Press Save, then press [OFF].
This Can Be Found On Page 17 And 18 Of The User Guide.
If You Do Not Have The User Guide It Can Be Downloaded Here
http://support.radioshack.com/support_phones/doc73/73355.pdf
Thank You For Choosing Fixya.com
Dec 21, 2008 | Panasonic KX-TG2357 Cordless Phone
LG Chocolate Ringer problem
Go to tools, phone settings, voice commands, call alert then do not select name repeat, the other 2 selections have a ring.
Mar 28, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Ringer off
The VT-9118 can use one of 4 different ring tones, and can be turned off.
To reset your ring tone:
  1. Remove the handset from the base.
  2. Press PROG. You should hear a single short beep.
  3. Press #.  You should hear a single short beep.
  4. Press a number 1 through 4. You should hear a long "ring" tone (it might be startling!). You can try other numbers from 1 to 4 to hear them all.
  5. Press MEM to confirm your ring. You will hear a medium beep.
To turn the ringer off, follow the same instructions, but choose number 5.
Hope this helps you. If you need for information, you can download the user manual from http://www.vtechphones.com/docMgt/public/art/313/vt9118.pdf
Jan 17, 2008 | Vtech VT-9118 Cordless Phone
Samsung SGH-E530 Cellular Phone Logo
47 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
