Question about HP Photosmart C5280 Printer
Cartrige jam i have a cartridge jam ...how do i fix it plz tell me
You should try to open the door of the printer and push the switch of the door, you can see the switch on the left portion of the printer
Posted on Feb 23, 2009
Jam cartrige Area
Clear jams from the print-cartridge area
1. Open the print-cartridge door, and remove the print cartridge.
Figure 18: removing print cartridge
2. With both hands, grasp the side of the media that is most visible (this includes the middle), and carefully pull it free from the product.
Figure 19: removing jammed media
3. Replace the print cartridge and close the print-cartridge door.
Figure 20: reinstalling the print cartridge
For any other Jam types Visit the following link : HP Lasterjet M1522
Regards,
Shrey
May 30, 2011 | HP LaserJet M1522nf Multifunction Printer...
Sir i have hp 2600n i have a problem my hp 2600n prints blur image or prints double image what can i do plz tell me
Try to fix the paper size from printer preferences, and check whether the printer cartridges are aligned, u can always align the printer cartridges by navigating the printer menu to the settings and then align printer cartriges. good luck
Mar 12, 2011 | HP Color LaserJet 2600n Printer
The best printer ever and now it is screeching and cartriges get jamed. It tells me that the color ink cartridge is missing which it isn't and then it tells me the ink cartridges are jammed and need to be...
Clean the metal rod inside the printer on which the carriage rides. Wipe clean with paper towel then use window cleaner on paper towel to wipe again, then wipe dry. Apply some lubricant to the rod after cleaning. That should solve the problem. Had that in a similar model.
Jun 06, 2017 | HP PhotoSmart p1100 InkJet Printer
I keep getting error message C000 which tells me to shut down the printer and restart it. How do I fix this. Thanks
1) Make sure the tank holding all the ink cartriges is properly aligned and can move side-to-side.
2) If it is crooked or can't move, check below it for a paper jam -- when the jam is that bad, the C000 appears to override the normal Paper Jam warning.
3) Make sure none of the ink cartridges has run completely out -- I tend to use them until they're bone dry, and got the C000 error....inserting a new cartridge cleared it right up.
Jan 29, 2011 | Canon Office Equipment & Supplies
Error signal E1,4. cannon pixma 240 cartrige error signal jamming function, how do I fix.
E 14 mean The fine cartridge may not be the compatible with this machine.Install fine cartridge properly,then solve your problem.
Aug 11, 2010 | Canon PIXMA MP240 All-In-One InkJet...
Cartridge jammed
Check cartrige. If cartrige does not make right contact or its not original,thats the problem.
Oct 06, 2009 | Office Equipment & Supplies
Paper cartrige cradle is stuck.
print cartrige cradle is stuck clear jam then press ok in hpphotosmart 7550
Sep 08, 2009 | HP Photosmart 8150 InkJet Printer
I have an hp T45 and it is telling me to clear the pen cartridge jam, what is that?
Your ink cartriges are jammed, I don't think it's economical to have it repaired.
Jul 31, 2009 | HP OfficeJet t45 All-In-One InkJet Printer
It starts printing, then stops, the printer cartrige is jammed
Try emoving the duplex cartridge on the back (return printer to it's original configuration) and try printing. If the printer prints OK, then re-attach the duplexer checking for anything that could interfere with the print cartridge.
If the printer doesn't print, then I suspect something has fell into the printer and is creating enough resistance for the printer to detect and report. Turn the printer off, Remove all the cables from it. Try inverting the printer and gently shake it to see if anything falls out that could be jamming the printer cartridge.
Jun 02, 2009 | HP OfficeJet Pro K8600 Printer
New Black Cartrige
plz try with another cartridge
Jul 01, 2008 | HP Color LaserJet 2600n Printer
HP Photosmart C5280 Printer Logo
Ben Johnson
