Question about Samsung Yepp YP-T9 Digital Media Player
Problems! My yp-t9 all of a sudden froze and started buzzing. After a while of trying to get it going again I reset it.. But now it won't let me put any more music on it. It also doesn't always connect to the PC..Often coming up with USB device not recognised, yet my sisters K5 connects fine. This has happened for probably 2 of the 4 months I have owned it
    Scholar:
  • 67 Answers
You need to reformat the device and then upgrade it to the newset firmware. You should be able to find instructions on how to do this on the Samsung website.
Posted on Jul 31, 2007
SOURCE:
My YP-S3 froze ! what do i do?
Hold down the RESET hole at the back of the player until the unit shuts off.
It should work fine once turned back on.
Hope this helps!
Jul 10, 2009 | Samsung Yepp YP-T9 Digital Media Player
My samsung Yepp T9 froze and won't unfreeze
To turn it off try emergency "turn of combination": Menu + Record buttons. This also will help you to reset wrong parameters in your device.
Mar 26, 2009 | Samsung Yepp YP-T9 Digital Media Player
How do you put videos into the YP-T9 mp3 using windows media player??? Would I have to convert the videos somehow? I've been having trouble with this, please help!
Look sir.The yp-t9 can only play svi files.In order to put the videos into your yp-t9 you must hav samsung media studio and also the videos must be in either mp4,avi or wmv format.And then use Samsung media studio to put the videos into your yp-t9,samsung medai studio will convert the videos into svi format which your yp-t9 can read.
Feb 21, 2009 | Samsung Yepp YP-T9 Digital Media Player
Samsung yp-s3
stick a toothpick into the reset hole on the back on the unit. It will power off and now you can power back on.
Jan 02, 2009 | Samsung Yepp YP-T9 Digital Media Player
I want to reset my samsung yp-t9
Complete Solution - includes fix for Bluetooth.
You will need to execute a number of steps to do this:
1 - obtain a copy of the latest firmware from http://www.samsung.com/uk/support/search/supportSearchResultView.do?group=&group_cd=&type=&type_cd=&subtype=mp3others&subtype_cd=&model_nm=YP-T9&dType=D&vType=L&mType=&model_cd=&menu=download&prd_ia_cd=&disp_nm=YP-T9
or (even better) - go to the international site and download a copy of YP-T9 V1.80.zip
2 - Reset - Power off the yp-t9 using A-B and MENU pressed together - hold down A-B and press the POWER button to enter the low-level format mode - press LEFT LEFT RIGHT RIGHT UP CENTRE DOWN - the yp-t9 will now reformat - power off using A-B and MENU together
3 - reload firmware - Power on normally and connect to PC as a USB drive. Move the two files you just downloaded (MUON.ROM and SYSDATA.BIN) into the root of the USB drive - Safely remove the drive - Power on the yp-t9 and allow it to re-install the firmware
If you want to restore Bluetooth functionality you will also need to perform the following steps:
4 - pop the four rubber plugs out of the back of the unit - with a small phillips screwdriver remove the four screws - insert your fingernail into the seam of the unit on both sides and pop off the back - gently (slowly) remove the battery taking care not to place any strain on the connecting wires - copy dowm the 12-digit number on the label under the battery (starts 0016xxx...) - replace battery, back, screws and plugs.
5 - using text editor create a file with the 12 digits (use upper-case letters where appropriate) followed by <enter> key - save it as BT_MAC_ADDR.TXT
6 - connect the yp-t9 and open it using Right click on Start and Explore - find the yp-t9 and drag a copy of BT_MAC_ADDR.TXT into the SYSTEM folder - Safely remove - power on normally.
Hope this helps
Chris
Nov 19, 2008 | Samsung Yepp YP-T9 Digital Media Player
Help i have a Samsung YP-T9 and it froze
hold down the menu and play button at the same time to reset, should turn it off, then just turn it back on again
Jun 11, 2008 | Samsung Yepp YP-T9 Digital Media Player
Samsung Yepp YP-T9 Digital-video playback
Yp-t9 can only play svi files.First convert those mp4 files into avi or wmv files.And use samsung media studio to put them into your yp-t9.The samsung media studio will convert ai and wmv files to svi.Or jus try to convert those mp4 files with Samsung media studio.It converts sometimes.
Jun 07, 2008 | Samsung Yepp YP-T9 Digital Media Player
Yp-t9 froze while transferring files now computer doesn't recognize it
This is for David Jorge. I faced the exact same problem. Oddly the stupid thing restarted when I kept pressing all four buttons (on the right side) for a while. Afterwards there was no problem.
Jan 10, 2008 | Samsung Yepp YP-T9 Digital Media Player
Freeze
Congratulations on the purchase of your T9 ! The T9 has won many reviews, and rated very high for value for $'s. Now, depending on how long this unit has been sitting since it's manufacture, all new units usually require a 'wake-up'. The initial wakeup charging is critical to the battery's life, so follow instructions carefully, re charging. Then, "re-set" the T9 (ie hold both 'Menu' & 'A-B' buttons together, for 3 secs to re-initialise the built-in firmware). This procedure will overide everything. If this gets it goin, then download the latest firmware update from Samsung website (download centre/mp3) and save newest firmware onto your T9 - your manual should explain how to do this. Always update your T9 with latest firmware when available (appropriate with your Windows OS), to eliminate any bugs in the firmware. If this doesn't resolve, then use the factory warranty to have it serviced by an approved Samsung agent. Good luck.
Jul 01, 2007 | Samsung Yepp YP-T9 Digital Media Player
Samsung Yepp YP-T9 Digital Media Player Logo
85 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
