Question about Whirlpool Kitchen Ranges
Replacing the oven door to the Whirlpool electric range RF375PXE
Pulled out the door accidently. Unable to re-connect door to the range.
Oven door right hinge is connected but the left side came out.
It appears that the hinge on the left side is spring loaded. Not successful yet to re-connect. Spring loaded device keeps retracting with the slightest movement.
There is a hole in the hinge, for placing a pin, to hold fully open. Two man job. One forces the hinge into the fully open position; the second inserts the pin (nail) into the hole.
Posted on Jan 19, 2010
Oven shuts off after closing door
Have you put a thermometer in the oven to make sure it is not heating. They will not always glow red if the oven is at temp.
Feb 12, 2014 | Hotpoint RB757 Electric Kitchen Range
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
F9 error code while cleaning oven
F9 = oven door lock failure
Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch. If that looks good, replace the lock. What is the complete model number? Look in the oven door area.
Feb 14, 2013 | Whirlpool SF315 Dual Fuel (Electric and...
Whirlpool oven door won't open.
You can try unplugging the over for a while and seeing if that helps. But if that doesn't help you will have to let the oven complete the cleaning cycle in order to regain use.
Jun 23, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven Lock stuck open before start of self-cleaning cycle
Sounds like you bent the door where the lock is. You might have to replace the door.
Mar 12, 2009 | General Electric Stove/Oven/Range Chrome...
My oven door came off and I can't get it back on
I have spilt milk flowing down the side fo oven/counter top and needed to pull out the stove to quickly get it wiped up..I pulled the stove out by the oven door handle. The hinge sprang on the right side and the oven door is now off on one side how to get it back on?? My husband lifted the door up and the whole door is now off.
It is very difficult to replace, what are we doing wrong???!!! Please help. I belive it is a whirlpool electronic model. thankyou.
Jan 08, 2009 | Jenn-Air JER8850 Electric Kitchen Range
Stove handle/door
need strong fingers and a helper... lay the door on the floor push open the hinges and there is a hole on the side of the hinge have your helper slide in a small nail only about 1/4 " in to the hole this will keep the hinge out do the same on the other side then reinstall the door open up and remove your nails
Feb 26, 2008 | Whirlpool RF315 Dual Fuel (Electric and...
Power Failure caused by oven door...
It sound like a malfunction door switch that should be replaced. Good luck!
Dec 04, 2006 | Whirlpool RF364 Electric Kitchen Range
Kitchen Ranges Logo
335 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
