Oil the lock push rod at front and back ends. The steel rod in the pot metal glide holes. Mine kept locking and after replacing some of the parts it did the same thing, so I pile the rod and all works great!!!
Try a squirt of wd-40 or crc to free up the button. The anti rust spray used in assembly has probably got sticky and is jamming the shaft of the button
SOURCE: HOw to lift the saw in the up position
i have a bosch it has a little knob on the side that i pull and give a half twist and release then the arm will raise and fall until time to store it again
SOURCE: I have a Makita 10 inch compond mitre saw. My
You can get it at Makita.com, type in yr modal number in the search bar, download a parts breakdown or a manual, if not u can order a new sticker from makita.
SOURCE: I bought a ls1016 coupond mitre saw this week. I
Sounds as if the blade is dull. Or perhaps bent. A dull or bent blade blade will 'grab' the wood, rather than cut it, resulting in binding, or kickbacks.
Solution; replace the blade with a fine-toothed, good quality blade. If the blade is new, then check that the blade is bolted tight on the arbor. If the blade is loose, it can result in kickbacks.
Also, check that all the bolts/fasteners/locking mechanisms on the saw are tight, and in good working order. Sometimes a tool new out-of-the-box will have loose screws/nuts/bolts that need to be tightened up.
Also, when cutting, use a smooth, slow, motion, being sure to give the saw the time it needs to make the cut.
Testimonial: "Thank you for the the answer. I will try tightening the screws. I will check the blade also. "
