Question about Vapor 2300 LadyBug XL Steam Vacuum
Ladybug XL won't heat
The light comes on but there is no pressure
Steam mop won,t steam. Have tried all suggestions in user guide. Water won,t heat up. Machine becomes warm. Water ' vinegar will slowly drip out of base - so not blocked. Help,,
It could still be blocked, not totally blocked but enough to keep the steam from coming out as strong as it should.
Mar 14, 2017 | Vacuums
Why is the light on switch lighting up but the vacuum wont come on?
It won't work properly if there is a jam or something cought and wound round the roller... even if it's just a lot of string.
Feb 25, 2015 | Oreck XL® Classic Bagged Upright Vacuum
Oreck xl won't start
This could be for various reasons. Check the power cord and try a different outlet first. See if the power cord is loose or damaged. Next check the brushroll and belt that those are in working order. If you smelt burning or electrical fire or your vacuum made an odd noise before stopping it may be the motor going bad. If your power cord is good and the brushroll and belt good, it is probably your motor going bad.
Replacement Oreck Vacuum Cleaner Motor
GoodVac
800-775-6586
Jun 20, 2012 | Oreck Vacuums
Brush doesn't work,red light is on says to see owners manual,belt is not broken.
The belt may have streached so that when pressure is applied to it the belt slips. The belt will not be broken just streached to far.
Mar 13, 2010 | Oreck XL Ultra Bagged Upright Vacuum
Polti steam cleaner
It should go just below the red providing steam isn,t escaping from the cap otherwise you won,t get the pressure build up to enable it to come out when you pull the trigger
Oct 23, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
T2100 S Ladybug Canister Steam Cleaner
Visit the Ladybug Ladybug 2200S Vapor Steam Cleaner page and scroll to the bottom. There's a link that says, "Download owners manual."
Oct 20, 2008 | Vapor T 2200S LadyBug Canister Steam...
Steam cleaner
Most upright steam cleaners like Hoover and Bissell, you put in the hot water, bissell does have a heater, but it only helps get the hot water a alittle hotter. But a model number would help.
Dec 12, 2007 | Vapor PC2200 Ladybug Steam Vacuum
Polti Vaporetto 2400: Water out light comes on when tank is full
Hi you need to put 5ml of Kal Stop fo Polti machines into 1000/1500ml of water into the tank, The stronger solution is better (1000ml) Let it heat up and this should break down the limescale on the solenoid. I tried this today and it has worked saving ££££'s in repair by Polti.
Nov 04, 2007 | Polti Vaporetto 2400 Canister Steam Vacuum
Vapor 2300 LadyBug XL Steam Vacuum Logo
43 people viewed this question
Top Vapor Vacuums Experts
richie46
ray gallant
Tom Chichester
Are you a Vapor Vacuum Expert? Answer questions, earn points and help others
