Question about Dell Latitude D600 Notebook
Network Card is Not detectable
Hi guys can anyone help me... I have Dell Latitude D600.. I dont wht happend, my Network card is not detectable by windows. i have tried a lot but havn't solved the problem. It is enabled in BIOS... but in device manager only wireless card is shown.. Kindly help me out from this problem ... my Notebook is not working smoothly due to this problem
  • 3 more comments
  • nerdwijs Feb 01, 2009
    tried on AC power
    tried searching new hardware (has worked sometimes over the past days, but after a while got the blue screen)
    re-installed driver (R133052, v9.52b)
  • shami_masood Feb 04, 2009
    I Know sir.. but i told u people dat in BIOS it is disabled automatically. Now tell me wht to do.. Can i change my Network Card physically.
  • shami_masood Mar 05, 2009
    First of all thanks worldvet for providing me so much information. Boss u want a clarification for BIOS enable. I want to say that personally i have enable it in Bios setup but whenever it reboots, disables the card automatically.
    just to clarify, if you could. In your solution you told that in new models of Dell Latitude D600, network card chips are planting on Main boards. Tell me what ll be the status of Mine, ll it be a miniPCI card or chip on board. Kindly if you have anyother solution without opening the bottom of laptop. Take it as last option.
    Secondly, I have also tried Add New Hardware, all the options goes fail.
    Thanks again for reponding. waiting again for effective solution.
  • Glenn Rogers
    Glenn Rogers May 11, 2010
    Have you clicked on Add New Hardware and then check for hardware changes?
    If the installer has been instructed to ignore the new hardware once, it will forever after.
    Let me know and I can take you to the next step.
  • Glenn Rogers
    The Dell D600 is a very successfull model of laptop and I'm using one right now, but mine was built in 2001.
    Eventually, Dell and other companies started planting the network card ship on the main board. Prior to that, it was inserted into a miniPCI slot that is accesible from the bottom of the laptop. The access panel is fairly large on these versions of the D600. The slot cover is in the center back and is where you will and would expect to find access to the Ram Modules, CPU Fan and CPU. the miniPCI slot is farily noticiable if you have one.
    Just to clarify, if you would. In your original question you stated that the network card was enabled in the Bios. Was that incorrect then? It would help to understand the problem.
    A solution then, would be to remove the miniPCI card, carefully and by reading over the how-to at Dell so you don't damage anything accidentaly. Remove power and the battery both before doing this. Once it is out, reattach the cover. Re-insert the battery and reattach power boot up normally and once the Desktop is stable perform a normal shut down. Then you can follow the same proceedure above to re-insert the miniPCI card and reboot. One this return to the desktop you should but only maybe will you get a add new hardware wizard.
    If you go to Dell online and enter your Service Tag, you can look up drivers for your laptop. I would download the latest driver for your NIC in advance of this procedure so that when and if Windows discovers your NIC again, you will have the driver to point Windows to. Otherwise, try to force the onboard NIC to an on status in teh Bios and then install the Service Pack driver from Dell.
    If all this fails, then you need to repalce the NIC if you have the miniPCI with a NIC installed first of all. After that, you can put any NIC you can find on Ebay in there that comes with a DOA warranty. Just look at the available drivers for the D600 first and then get a NIC that Dell has drivers for, otherwise its a wild chance it will work for you.
    Good Luck,
    Worldvet
    BTW, ask away if you have any other questions.
I have solved the issue by following the instruvtions of worldvet with the NIC unplugged I installed the latest drivers provided by cornyn, now everything works fine again.
The problem came into place when updateing Windows XP to SP3 with all other patches, so I assume there was a wrong dll or something.
I also installed all other drivers updates from dell including BIOS to avoid this behaviour in the future,
greetz,
chris
Posted on Mar 05, 2009
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 33 Answers
I'm going to make an assumption that you are using Windows XP or 2000.
You'll need to acquire the hardware driver Windows cannot automatically supply a compatible driver.
A link to the driver can be found here.
Posted on Feb 03, 2009
How do I upload pictures onto my Dell d600
If your photos are stored on a SD memory card then remove the SD memory card from the camera and insert the memory card into an USB memory card reader. Connect the USB memory card reader into the USB port of your Dell computer. The Dell wiil detect the card reader as an external storage device, you can then open the folder on the memory card that contains the photos and then copy them to your computer.
Feb 11, 2012 | Dell Latitude D600: Pentium M 1.6GHz,...
Where is the wifi switch on my dell latitude d600
Hi!
To Enable wireless adapter for Latitude D600 Press Fn+F2.
Hope this helps.
Mar 17, 2011 | Dell Latitude D600 Notebook
My wireless wont turn on on my dell d600
PLEASE CHECK IN DEVICE MAMAGER IF WAN CARD IS DETECTED OR NOT IF IT IS NOT UPDATE THE LATEST WAN DRIVERS FROM SUPPORT.DELL.COM IF IF STILL NOT ABLE TO DETECT GO TO SUPPORT SITE SEARCH FOR MANUALS OF THE PRODUCT RESEAT THE WAN CARD AND TRY IT AGAIN , IF STILL NOT WORKING WAN CARD HAS GONE BAD CHANGE THE WAN CARD ,
IF WAN CARD IS DETECTED IN DEVICE MANAGER JUST UPDATE THE LATEST DRIVERS AND TRY IT AGAIN AFTER RESTARTING THE COMPUTER ,
May 14, 2010 | Dell Latitude D600 Notebook
Hi,I hv a Dell Latitude D600 Pentium-M 1.6Ghz 1256MB ram 160gb Ati Radeon Mobility 9000 32MB ram. The problem is when i play some game like Warcraft Dota,it lags. Even my IBM T30 wont hv any problem with...
Hi there!
The main problem which is causing your Warcraft Dota to lag is your video card size is too small,
Dota requires at least 256 mb size.
Hope this helps!
Mar 20, 2010 | Dell Latitude D600: Pentium M 1.6GHz,...
My bluetooth and infrared aint working how do i configure
dell latitude D600 only has PC Card slot that supporting wireless cards and Built-in bluetooth, so you have to purchase the bluetooth or infrared device which is of course it is auto detect on windows xp
Jun 26, 2009 | Dell Latitude D600 Notebook
Lan connection has disappeared from network but wireless works
Have you run the Dell Diagnostics test? reboot the computer and hit the F12 key, scroll down to the diagnostic option and run the test, it will check hardware and memory etc.
Apr 04, 2009 | Dell Latitude D600 Notebook
Lan disappears and re-appears
Try downloading and installing the driver again from Dell´s website.
Feb 05, 2008 | Dell Latitude D600 Notebook
Dell latitude d600 bluetooth and infrared devices problems
i have D 600 laptop
my bluetooth is nt working
wht should i do?
Jan 14, 2008 | Dell Latitude D600 Notebook
Inetwork card
Here is the link to the DELL drivers for your unit. I am unaware of what network card you have in your unit and therefore can not point you to the proper driver. However, once you know the network card you have, you can go here and download the appropriate driver for your unit.
D600 Drivers
Nov 22, 2007 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
378 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
