Question about Hampton Bay 24750 Huntington III Ceiling Fan
Hampton bay fan with two wall switches and fan does not work
One wall switch has all four (red, blk, wht, and ground) wires but the other only has two black and one white with the ground. trying to run another line with no red wire only blew the switch with the red wire attached to it and won't turn off the light. the other switch still works.
  • 323 Answers
That is because you need both switches wired exactly the same way in order to have a two way switch. The switch that blew had the necessary wires but was wired wrong. One of those two black wires has to be used as a red one. You will have to check the wires for continuity to find which black connects to the red wire on the other end.
Posted on May 26, 2009
By-pass 3 speed fan switch
Why don't you just throw it away and get a good fan? I don't think you can wire it without the switch.
Jul 02, 2013 | Hampton Bay 24002 Ceiling Fan
Hi, I opened a junction box that operates 3 lights,from 3 diferant swicthes, there are red, white &blk plus ground i need to tap off of that & instal a gfi & vanity light w/s witch can you tell...
You need to find the hot leg and the nuetral leg . Hot is black and neutral is white . You need to make sure you have 120 volts between these wires cause some of the blacks could be switch leggs for the lights you talked about . Tie your recep. To those wht to wht and blk to blk .
Jan 24, 2012 | Hampton Bay 44 In. Bistro, Copper Kitchen...
I bought a Hampton Bay ceiling fan and I have
Hi ,, the usual wiring for the fan / light is that in the ceiling the white wires connect together , the black house wire connects to the black fan wire, the red house wire connects to the other fan wire, usually blue or black with a blue stripe. If this does not resolve the issue, then check the wall switches and see that there is a power wire to each switch and that there is a red wire from the fan on one switch and the black wire from the fan on the other switch ..
Apr 07, 2010 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Trying to rewire a hampton bay light fan. I have
Try switching the red and white wires
But it should be working if the light is.
Make sure all the wires to the remote are connected good. You may just have defective remote.
Nov 29, 2009 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
52in nassau indoor/outdoor fan 129-909 floor model no instr
white definately goes to white. however you configure the red, black and blues will only determine which switch on the wall controls the fan or light. as for the bare copper, the fans typically come from the factory with a green pigtail screwed into the top of the downrod
Aug 17, 2009 | Hampton Bay 24002 Ceiling Fan
Hampton Bay Wiring?
You have two switches right? One for the light and one for the fan? White should be neutral. Green should be ground. Black should be hot from one switch and red should be hot from the other. Hook black to black and blue to red. If you wire blue and black together then one switch will turn on the fan and the light at the same time.
Feb 17, 2009 | Hampton Bay 48670 Flemish Pewter Finish...
Ceiling Fan wires
you don't have the necessary wires. you need to run a 3-wire cable (wht, blk, red, grd) between fan+switch. then post bac for instructions...
Dec 12, 2007 | Hampton Bay 46175 Cameron II Plus Ceiling...
Wiring ceiling fans to wall switch
Hi Bigelow,
You need two switches.  It sounds like the Electrician set up the junction box for two circuits(Lights and Fans).  i say this because your supply has 4 wires, Red , Black, White and Bare. We may be able to oversome this with one Lutron Switch. Allow me to investigate, and I will be back.
Oct 20, 2007 | Hampton Bay 24002 Ceiling Fan
Wiring Hampton Bay Fan
The blue wire is for the light.This should connect to the other switch instead of being combined with the fan switch.
Sep 09, 2007 | Westwind Classic Hugger Polished Brass 52"...
Hampton Bay 24750 Huntington III Ceiling Fan Logo
195 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
