Question about Toshiba Satellite A135-S4527 Notebook
Dear sir, i have toshiba SA50-543 i need wirrlas and pmi cared driver
  • Toshiba Master
  • 4,338 Answers
Here is the Toshiba download page for all the drivers on the Satellite A50:
http://il.computers.toshiba-europe.com/innovation/download_drivers_bios.jsp?service=IL&selCategory=8&selFamily=192&selSeries=236&selProduct=535&selShortMod=380&language=null&selOS=null&selType=null&yearupload=&monthupload=&dayupload=&useDate=null&mode=allMachines&search=&action=search&macId=&country=null&page=2
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Jan 31, 2009
2008 ford f-350 passenger air bag flashes 1-7 code than stays on when truck is started.What does the code mean and can the code be reset without tearing air bag out of truck?
If a SRS fault exists, the RCM sends a message to instrument cluster module to flash a coded sequence which is called a lamp flash code (LFC) on the air bag warning indicator. Each LFC is flashed 3 times after which the air bag indictor will remain lit for the remainder of the key-on cycle. In addition to the self-test at start up, the RCM continuously monitors all of its external and internal circuitry for faults.
While the LFCs are an indication of a general concern in the supplemental restraint system (SRS), the DTCs are more specific. The DTCs can be retrieved from the RCM with a scan tool via the DLC.
DTC a c LFC b Description Action To Take - Continuous Lamp The Air Bag Warning Indicator is Illuminated Continuously (RCM Disconnected or Inoperative, Loss of Battery Feed or Loss of Signal Ground) Go To Pinpoint Test A . B1048 c - Passenger Side Air Bag Cross Link to Another Firing Loop Go To Pinpoint Test B . B1049 c - Passenger Seatbelt Pretensioner Cross Link to Another Firing Loop Go To Pinpoint Test C . B1054 c - Driver Seatbelt Pretensioner Cross Link to Another Firing Loop Go To Pinpoint Test D . B1057 c - Driver Air Bag Cross Link to Another Firing Loop Go To Pinpoint Test E . B1231 13 RCM Crash Data Memory Full INSTALL a new RCM and CARRY OUT programmable module installation (PMI). REFER to Restraints Control Module (RCM) and Inspection and Repair After a Supplemental Restraint System (SRS) Deployment in this section. B1317 Continuous Lamp Battery Voltage High REFER to Section 414-00 . B1318 Continuous Lamp Battery Voltage Low REFER to Section 414-00 . B1342 24 RCM is Faulted INSTALL a new RCM and CARRY OUT programmable module installation (PMI). REFER to Restraints Control Module (RCM) in this section. B1871 25 Passenger Air Bag Deactivate Module Fault Go To Pinpoint Test F . B1884 27 Passenger Air Bag Deactivation (PAD) Warning Lamp Circuit Failure Go To Pinpoint Test G . B1890 27 Passenger Air Bag Deactivation (PAD) Warning Lamp Short to Battery Go To Pinpoint Test H . B2292 33 Restraint System - Seat Belt Pretensioner Fault (Driver Pretensioner Circuit Fault) Go To Pinpoint Test I . B2292 34 Restraint System - Seat Belt Pretensioner Fault (Passenger Pretensioner Circuit Fault) Go To Pinpoint Test I . B2293 19 Restraint System - Air Bag Fault (Driver Front Air Bag Circuit Fault) Go To Pinpoint Test J . B2293 21 Restraint System - Air Bag Fault (Passenger Front Air Bag Circuit Fault) Go To Pinpoint Test J . B2296 42 Restraint System - Impact Sensor Fault Go To Pinpoint Test K . B2434 53 Driver Seat Belt Buckle Switch Circuit Short to Ground Go To Pinpoint Test L . B2435 53 Driver Seat Belt Buckle Switch Resistance out of Range Go To Pinpoint Test M . B2477 54 Module Configuration Failure This DTC indicates programmable module installation (PMI) has not been done to a newly installed module. CARRY OUT PMI. REFER to Section 418-01 . CLEAR the DTC. CARRY OUT the self-test. B2607 57 Harness/Configuration Mismatch This DTC indicates the RCM is configured incorrectly. CARRY OUT programmable module installation (PMI). REFER to Section 418-01 . CLEAR the DTC. CARRY OUT the self-test. If DTC is retrieved a second time, INSTALL a new RCM and CARRY OUT PMI. REFER to Restraints Control Module (RCM) in this section. B2691 53 Seat Belt Buckle Switch Circuit Fault, Front Driver's Side Go To Pinpoint Test N . C1414 29 Incorrect Module Design Level VERIFY RCM part number is correct for vehicle.
CARRY OUT programmable module installation (PMI). REFER to Section 418-01 . CLEAR the DTC. CARRY OUT the self-test. If DTC is retrieved a second time, INSTALL a new RCM and CARRY OUT PMI. REFER to Restraints Control Module (RCM) in this section. U0100 14 Lost Communication With ECM/PCM REFER to Section 418-00 to diagnose the communication concern. U2023 14 Fault Received From External Node REFER to Section 418-00 to diagnose the communication concern. U2050 14 No Application Present This DTC indicates programmable module installation (PMI) has failed. CARRY OUT PMI. REFER to Section 418-01 . CLEAR the DTC. CARRY OUT the self-test. If DTC is retrieved a second time, INSTALL a new RCM and CARRY OUT PMI. REFER to Restraints Control Module (RCM) in this section. a DTC: Diagnostic trouble code, retrieved using scan tool.
c Cross-link DTCs will be retrieved in pairs to identify the cross-linked components.
b LFC: Lamp fault code, flashed on air bag warning indicator.
Apr 18, 2017 | Ford Cars & Trucks
What is PMI?
PMI protects lenders against deficits that may occur whenever a customer defaults on the mortgage. PMI is needed on first mortgage purchase transactions once the customer has under a 20% lower payment. Likewise, it's needed on first mortgage re-finance transactions once the customer has 20% equity within the property being refinanced. The price of the mortgage insurance coverage is typically put into the monthly loan payment.
Dec 21, 2015 | Retail Supplies
Toshiba drivers
hi..hello...try this web site to get the vista drivers>>(http://drivers-download-driver.com/tag/satellite-a200-24a)>>good luck and have a nice day
Jun 17, 2009 | Computers & Internet
Wirrlas
For drivers you should look for your specific modell in the Toshibas suport site!
Try this link, the language is in German but the drivers should work for english:
http://ch.computers.toshiba-europe.com/innovation/jsp/SUPPORTSECTION/discontinuedProductPage.do?LNG=8&service=CH&BV_UseBVCookie=yes&PRODUCT_ID=95811
BR
/BS
Jan 30, 2009 | Toshiba Satellite A135-S4527 Notebook
My laptop is no lan drive so i want to download driver
hello sir
i have laptop for LG RD405 so i want to Motherboard driver but no have driver cd so i need the Motherboard driver.
Oct 23, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite A135-S4527 Notebook Logo
165 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
