Question about KitchenAid Architect® KEBS277S Electric Double Oven
Kitchenaid display reads insert temperature probe, and oven beeps does not respond to any command The panel says to "Enter probe temperature or remove probe". The probe is already removed. It will not respond to any other key functions. Model # KEBS277
  • Anonymous Feb 10, 2009
    I have the same problem & they are sending a tech @ the cost of $81 for the forst 15 mins & $19 for every 15 mins after that! RIDICULOUS!
We just had this problem with our Kitchenaid Superba electric oven. It started beeping for no reason and showed the probe symbol. I actually never used this probe, ever! Call to the tech people: go get a service man! right...
My husband, smarty pants, lol, put a bowl of water into the oven, plugged the probe in and dunked it into the bowl with water, set the temperature to 85 C (that would be 200 F, I believe, but better check it in the manual) and let it heat up. (In any case, set it lower than water boiling temperature!)
That actually did the trick! Once it reached the set temperature, it shut itself off and the probe light went off! Yeah! good hubby!
Posted on May 01, 2010
Press "0".
Posted on Feb 26, 2009
    New Friend:
Tried the probe in hot water and pressing "0". Neither worked. Other suggestions? (thanks for the first two, not your fault they didn't work for me!)
Posted on Nov 24, 2014
My Miele oven has a constant alarm going off every time I try to turn it on, it won't let me set the temperature
Oven keeps beeping:
As there is no reprogramming of most control boards try this, disconnect the power and wait 30 seconds and then reconnecting the power.
If it's an "F1" fault code this generally implies an electronic oven control (EOC) failure. Disconnect the power, wait 30 seconds or longer and then reapply power. If "F1" returns upon power-up, replace the electronic oven control.
The oven control can be accessed and replaced from the rear of the control panel.
NOTE:Disconnect the power cord from the power source before removing the panel from behind the console.
If its an F2 ERROR CODE, The F2 error indicates an open circuit in the oven temperature probe.
Your range has a resettable thermostat in series with the oven temperature probe. If this thermostat opens the clock will display F2 and the oven won't heat.
You can reset the thermostat by pushing in the reset button on top of the thermostat.
Some ovens have an alarm that will beep continuously every six seconds to alert you that the oven is still on. Usually, a kitchen timer that you have set will cause the beeping, but occasionally it can be an error with the oven's settings. If it is the kitchen timer, you can simply push the "Kitchen Timer On/Off" button to end the continuous beeping. If that does not stop the beeping, it is probably beeping due to an error. You can turn the continuous beeping off but you may still need to troubleshoot the issue that is causing the beeping noise.
Read more :http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html
Nov 30, 2016 | Miele Ovens
My kitchenaid temperature probe won't turn off
If you mean the probe icon will not leave the display, you need to be sure the probe jack is not coated with food residue that is grounding it, if it is clean- send the control in for rebuild. Help Me Find My Model Number RepairClinic com
Feb 24, 2015 | KitchenAid Ovens
My GE double oven displays a message to set probe. When I press probe it prompts me to input a code (3 dashes)? Can you provide via e-mail what numbers can be used to set probe?
It is asking for the temperature that you want the meat to be. Example if you want your meat to have a medium doneness then usually it is 150F. You would enter 150. The probe will beep when the meat has reached that temperature
Sep 14, 2010 | GE Profile JTP56 Electric Double Oven
Superba convection oven probe display problem
I had a similar problem today with my KitchenAid Superba wall convection oven (2002 model). I was roasting tomatoes at 225 degrees F for 3 or 4 hours when the control pad changed and showed that the probe was in use (never have I used it and had to look for it). I, too, tried to plug in the probe and take it out, but nothing changed. My worry was that I could no longer use the timed bake function. After trying to reset by turning off the oven at the breaker, with no change, I turned on the oven to 400 F and left it on for 10 - 15 minutes hoping that the high temperature would dry out whatever moisture that must have gotten in the place where the probe connects. Then I turned it off and just waited. After a half hour or so the control pad cleared and nothing showed (that is what you want when the oven is off!). Everything is back to working now.
Sep 08, 2009 | KitchenAid KEBC107 Electric Single Oven
Kitchenaid KEMS308 display is saying "enter probe temp or remove probe" No probe is plugged in or has been used in a while. This message came up after cooking for about 3 1/2 hours at 300 degrees. Now...
Apparently this is to do with moisture having affected the oven adversely (I got this error message after baking 50 potatoes with all the steam that generated. Have a look at this page http://www.howtomendit.com/answers.php?id=162257 ....the solution is to set the probe for 160F then turn the oven on for 15 minutes or so at 450F. This apparently should dry out the probe position and all work again.....I am trying it now.....
Sep 07, 2009 | KitchenAid Architect® KEMS308SSS Stainless...
Probe prevents oven from reaching desired temperature
if you had to sandpaper this probe, then this is yoru initial problem, do the right thing and replace the probe with a new probe
Okay
Aug 23, 2009 | Ovens
Oven F10 Problem
PJC,
From the Frigidaire service manual:
"F10: Runaway Temperature.
SUGGESTED CORRECTIVE ACTION
1. (F10 only) Check RTD Sensor Probe & replace if necessary.
If oven is overheating, disconnect power. If oven continues to
overheat when the power is reapplied, replace EOC. Severe
overheating may require the entire oven to be replaced should
damage be extensive."
-hopefully it's just a bad temperature sensor!
www.fixyourboard.com
Jul 24, 2009 | Frigidaire GLEB27S7A Electric Single Oven
KEMS377 Lower electric Convection Oven - no probe, won't work!
"I get a "Door" message when I try to start it. The Message only shows when I try to set the time with one of the function buttons, like and dosent work
Aug 07, 2008 | KitchenAid Architect® KEMS378S Electric...
KitchenAid Architect® KEBS277S Electric Double Oven Logo
2,492 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
