Question about Honeywell Water Heaters
Honeywell T403A1174 suddenly doesn't appear to call for heat
It is on a basic Glow Worm boiler with a Master Mind programmer, the hot water side works fine but the thermostat controlling the central heating has failed. The contacts inside had stuck together, I have freed them but, I can't get it to work at all.
  • michel833 Feb 05, 2009
    I have since found that the thermostat is working but, for some reason, possibly because a bridge is missing in the programmer wiring, that the boiler will only work with the HW on. It seems to work OK with the HW on so, possibly a wiring problem after all.
    Problem Solver:
  • 5 Answers
Some times inside the boiler on the internal pipework you will see little sensors, on the central heating piping there sometimes is a thermastic sensor on side of flow pipe with a little reset button on ? i guess with the problem you said the poiler locked out and the pipe work overheated ? this is a safety feature on some boilers not, all and easerly reset via this button ?
Posted on Feb 05, 2009
Glow worm 45-60 standing boiler making banging noises when in operation
The noise you refer to is called Kettling, it is caused by the hot water in your boiler not being able to leave the boiler quick enough, if the problem developed quickly and your system is a "fully pumped " system this would generally point to your pump either has failed or is on its way out, i.e . your radiators would not heat up as the hot water is stuck in the boiler hence the banging......( if you know where the pump is you can generally feel if it is running by a small vibration ) if you have gravity hot water and pumped heating circuit then I would assume that it is noisy when just doing HW, and the banging is a problem that has gradually got worse it can indicate that the boiler is scaling up (are you in a hard water area). if this is correct there are various additives that can be put in the system to help quieten it down, I suggest you really need a heating engineer to diagnose fully.
Feb 07, 2014 | Water Heaters
Glow worm 45 60 boiler
You have to have 12" clearance on all sides.
Apr 02, 2009 | Water Heaters
I've got a pressure problem on my glow worm 35ci combi boiler
check to see if you have a mid position valve or a 3 way valve
the mid position will give hot primary supply to both your hot water cylinder and your heating circuit if both stats are asking for heat.
you cant really get spares for these type of valves you are probably better off changing it if it is causing problems.
Mar 28, 2009 | Water Heaters
The hot water and central heating wont work together
what size of gas line is going into boiler and water heater? is it black iron ? natural gas or propane? have you checked gas pressure at water heater and furnace ? if they work fine individually then you have a problem with incoming gas pressure. Call gas company and ask them if they would come out and check gas pressure.
Feb 03, 2009 | Water Heaters
How water problem
Your should be able to find the information here. Don't forget to check under discontinued products. www.glow-worm.co.uk
Dec 03, 2008 | Water Heaters
How do i servis a glowworm compact boiler
Hi, perrycallow,
I'm Harvey the Master Plumber,
You want to know how to service a Glowworm compact boiler
Glowworm is a United Kingdom company and here is the information you asked me for, to get their technical service line:
Technical Help: 01773 828300
technical@glow-worm.co.uk
Thank You,
Harvey your Master Plumber.
Please give me a good rating before you sign off.
Sep 06, 2008 | Water Heaters
Water Heaters Logo
221 people viewed this question
Top Honeywell Water Heaters Experts
Lickzee
gbob59
Are you a Honeywell Water Heater Expert? Answer questions, earn points and help others
