Question about Lexmark X4270 All-In-One InkJet Printer
I can't install my 4200 printer/fax. i get to the part where it says plug in usb cable, and it doesn't go beyond that. the cable is plugged in
  • EricDaniels
    EricDaniels May 11, 2010
    If the person who just started a Live Chat with you is not able to help just start up another and I can give you a walk through.
  • 628 Answers
Just for fun, try this: abort the installation process. Then plug in the printer in any USB port. Does the computer see the device? It should and then ask for a driver. If the system doesn't see the printer, then make sure the USB port is all right. Plug in some other USB device, such as a mouse, into the port. Does the computer see it? If not, then the trouble is in the PC. If it does, then your printer or the USB cable is bad. You can also take the printer to another computer and plug it in to make sure that it's all right.
Posted on Jan 31, 2009
Printer will not print
If unplugging and re-plugging the printer into your computer doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/eVzv1x. Select your operating system, download and execute the file.
Feb 14, 2012 | Lexmark X5650 All-in-One InkJet Printer
The compuer is not connected
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  4. Reboot computer.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/hsBChY. Select your operating system, download and execute the file.
Feb 10, 2012 | Lexmark X5495 All-in-One &USB...
Changed the ink cartridge and now the printer doesn't recognize the computer.It says the printer is idle. What do I do?
  4. Reboot computer.
Jan 29, 2012 | Lexmark X4650 InkJet Printer
Not able to print
  4. Reboot computer.
Jan 25, 2012 | Lexmark X8350 Print, Scan, Copy and Fax...
Lexmark X4550 Scanner not working
  4. Reboot computer.
Jan 05, 2012 | Lexmark X4550 Multifunction Wireless Color...
Cannot get my Lexmark x7170 to scan.
  4. Reboot computer.
Jan 04, 2012 | Lexmark X7170 All-In-One InkJet Printer
I got a new modem/router and now my fax does not have a dial tone. It is a Lexmark 4200
Fax cable should be plugged into the wall (phone jack) - not the router. Only the printer cable should be plugged into the router
May 06, 2009 | Office Equipment & Supplies
I can't reinstall my Sharp AM-900
Yes that is possible. Did you plugged the usb cable during driver installation ? During driver installation the usb cable must not be plugged. after the installation step asks you plug it in, then you plugged it. If not, the system wont recognized your printer. Be sure to uninstalled the previous installation before you re-install the driver
Apr 17, 2009 | Sharp AM-900 All-In-One Laser Printer
Macbook, lexmark f4270 driver
Apparently, the drivers for your printer is bundled in with the MAC OS CD. There are no MAC drivers on the Lexmark for your model. And the 4200 series should work.
Follow the instructions below.
Installing the bundled driver
Plug and Play
Steps Action 1 Power on the printer. 2 Plug the USB cable into the printer and into the Mac. 3 The Mac OS will automatically create the printer queue and install the printer.
Manual installation
If you plugged in the USB cable and the print queue was not created, follow these steps:
Steps Action Illustration 1 Plug the USB cable into the printer and into the Mac. ... 2 Launch System Preferences and select Print & Fax. Image 3 Click + to add the printer. Image 4 Select the printer, click Print Using and select your printer from the list. Then click Add to create the printer object. Image 5 Once the printer has been added, close System Preferences. The printer is now ready to print. Image
Troubleshooting
If you installed the driver from the printer·s installation CD or from a web download, uninstall it and follow the instructions below for recovering the driver from the Mac OS 10.5 (Leopard) CD.
Steps Action Illustration 1 Uninstall the installed driver. ... 2 Delete the Lexmark folder found in Library/Printers.
... 3
Insert the Mac OS 10.5 (Leopard) CD to recover the bundled driver and then click Optional Installs. Image 4 Click Optional Installs.mpkg. Image 5 Go through the installation process. ... 6 In the Optional Installs screen, select first Printer Drivers and then Lexmark Printer Drivers. Image 7 Click Continue and complete the installation process. ...
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 05, 2008 | Computers & Internet
How to install new brother printer 2820
How to install it as what? A fax machine? Or a printer/scanner?
To install as a FAX, just plug a phone line cord into the port that says "Line", plug the power cord in and you're done.
As a printer, go to Brothers web site and download the software for your machine. Install the software, plug a USB cable into the machine and the computer and follow the on screen instructions. It's really that simple.
Please try to be more verbose with your questions.
Dec 27, 2007 | Brother IntelliFax-2820 Laser Fax
Lexmark X4270 All-In-One InkJet Printer Logo
32 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
