Question about Ricoh 5125A Bare drive DVD+R+RW (ELRIC5125ABARE) Burner
Replacement drive for Ricoh rw5240v24t
I have an RCA DRC8300N with a dvd that is illiterate (can't read or write :-) wondered if it was worth replacing the drive- if so, what drive do I use and how do I get the right software (if needed) to get it to run corectly. I bought the unit used and so I have no documentation or discs orig to the product.
I replaced an HD on my tivo succesfully, but it was pre formatted by Weaknees!
Thanks!
  • perryking Feb 17, 2009
    same problem here. I bought the RCA new, its always had troubles, especialy reading its own recordings. Now its Jamed up. I may just try any Generic IDE DVD burner.
  • Anonymous Feb 25, 2009
    I have same problem. Generic ide dvd burner will not work I tried it.
SOURCE: Ricoh CL7200D Replace Fusing Unit (type C)
press the two arrow for 10 sec. hit enter you are in service mode
go to engine and diagnostic1 and sp7804 and go to 16
reset fuser change. enter
Posted on Dec 11, 2008
  • 9 Answers
SOURCE: Ricoh Aficio 2238c: Fuser Oil Unit
you really can not refill the bottle but I would recommend two things. One find a fuser oil unit on ebay and order it quickly. Next hit the yellow clear modes button, then hit the numbers 1 0 7 , then hold the red clear stop button till the display panel changes. hit copy sp, select 7 data log. now use the page down arrows located in the middle of the disply till you see 7804 push it then go to #10 oil supply and hit execute. this will reset the oil counter and allow you to use the machine till you get the new unit.
Posted on Dec 16, 2008
  • 400 Answers
SOURCE: Ricoh aficio 1515mf photoconductor reset
Found some information here:
http://www.fortc.com/2007/06/17/ricoh-cl4000dn-error-code-sc542/
Try the following
press the yellow “C” button
enter 107
press the red “C” button and keep it hold till the display changes
turn the power off with the big red switch on the front side
turn power on again.
OR
  • Press and hold online + escape, then power on.
  • Use up and down arrow keys to select SP2
  • Press Enter
  • Use up and down arror to locate SP5
  • Press Enter
  • Use up and down arrow keys to select 810
  • Press Enter
  • Confirm the selection
  • Power off and on.
Posted on Jun 01, 2009
  • 114 Answers
SOURCE: I need to replace hard drive for a ricoh copier
you ca try and do HDD Format in servce mode
SP4 Mode Number Function and [Setting] 4911 HDD Enter the Copy SP mode, select the desired SP, and then press Execute on the touch panel. (☛5.1.1) Note: After execution, you must cycle the machine off and on with the main power switch. 1 HDD Formatting (All) Initializes the entire hard disk. 2 HDD Formatting (IMH) Initializes documents stored with the document servers, stamp print data, scanner send data, fax send data 3 HDD Formatting (NFA) Initializes NetFile thumbnail images. 4 HDD Formatting (Job Log) Initializes job logging data (for popular server) 5 HDD Formatting (Printer Fonts) Initializes printer and stored fonts. 9 HDD Formatting (Debug) DFU
Posted on Mar 22, 2010
Rca8320 powers on vhs plays and record.dvd player not working
Hello
Check whether the DVD spins inside the mechanism after load. If it does not spins, repalce sled motor. if it spins and still not read any discs, the laser pickup unit is faulty, should be replaced with same type and number.
Feb 29, 2012 | RCA DRC8300N DVD Recorder/VCR
I need a manual for this product. Any chance I can download one? RCA DRC8300N DVD Recorder / VCR Combo
I see RCA no longer has any manuals for that unit. But, is this the exact model number? I mean like I have an RCA DRC8335 VCR/DVD recorder, so I am wondering if it is similar? If so I could work out something for you. Email me at jmsekola@citizens-tel.net if you think I can help with my manual.
Jan 01, 2010 | RCA DRC8300N DVD Recorder/VCR
How do I replace the C232 capacitor on DRC8300N
I posted a solution Dec 4 '09. The C232 cap # is written on the board .Heat up the 2 solder connections below it and PULL the cap out.Reverse the procedure to install new one. (it is black/blue,round, an inch long with a silver top).
Good luck
Nov 15, 2009 | RCA DRC8300N DVD Recorder/VCR
I need a new power cord where can i find one
majority of these plug in modals use this type plug
Power cord (part number 218104)
http://www.proscan.newremotecontrol.com/catalog_item.php?catnum=218104
here is a manual for you also
http://tv.manualsonline.com/manuals/mfg/rca/drc8300n.html
good luck and thanks for using fixya service.
Sep 21, 2009 | RCA DRC8300N DVD Recorder/VCR
It says "Disk error" on any disk. It won't read disk
turn off and, unplug your DVD recorder remove the six screws holding on the top tilt the back of the top up disengage the front of the top and set it aside look for a small laser tag this will point to a 1/4 inch glass lense this is the laser taking rubbing alcohol on a q-tip gently clean the lense with a twirling circular motion
Apr 28, 2009 | RCA DRC8300N DVD Recorder/VCR
Disc Reading Error
my remote wont work recorder
Mar 24, 2009 | RCA DRC8300N DVD Recorder/VCR
Won't read the disc and will auto shut off after inserting the dV
search the solution for replacing the capacitor which relates to the 8200n also.....nothing to lose doing it.
Drc8320n vcr dvd combo says hello and pls wait over and over again.
Replacing a simple capacitor on the power supply just brought my unit back from what I thought would be the junk pile....
Read this.
Yes you can do this yourself....
http://forums.afterdawn.com/thread_view.cfm/707232
Jan 26, 2009 | RCA DRC8300N DVD Recorder/VCR
I have a drc8320n combo I get Hello and the pls wait over and over again
Read this.
RCA recorder just purchased
I ckd the internet and found that this recorder had a lot of problems and solved the problem by returning it to the store.
Nov 17, 2008 | RCA DRC8300N DVD Recorder/VCR
Computers & Internet Logo
845 people viewed this question
Top Ricoh Computers & Internet Experts
Chris Braid
Level 1 Expert
Are you a Ricoh Computer and Internet Expert? Answer questions, earn points and help others
