Question about Zenith XBR716
Once dvd is recorded I can only play back on this unit, no matter if I'm going from vhs, TV or camcorder and no matter the brand or type of blank dvd I use
  • shedrick_tho Feb 10, 2009
    This solution worked perfectly. Thanks so much!
You have to finalize the dvd.
looka t page 20 of the Installation and User's Guide
Disc Menu/List
select finalize option.
Posted on Feb 10, 2009
How do I get the DVD to record what is on the VHS tape not the TV?
You can record from an external component, such as a camcorder or VCR, connected to any of the Recorder's external inputs.
1. Make sure that the component you want to record from is connected properly to the Recorder. See page 14.
2. Press AUX repeatedly to select the external input to record from.
• AV1: Audio/Video Input mounted on back panel.
• AV2: Audio/Video Input mounted on front panel.
• DV: DV Input mounted on front panel.
page 37 from manual:
http://resources.jvc.com/Resources/00/01/15/LVT2016-001B.pdf
If this fails, try to disconnect the tv input cable and connect the vcr cable.
Feb 04, 2016 | JVC DR-MV150B DVD Recorder/VCR
I cant get it to play the VHS
What do you mean can't get to play the VHS? did you mean after you record your video from VHS and trying to played using the regular player then it will not played? Had you try to used another brand of blank DVD disc? if ever that your video record and save to your computer had you try to used any dvd player program? such win dvd?
Dec 04, 2009 | Pinnacle Dazzle DVD Recorder
Can't record from camcorder to VHS tape on LG Model VCR
ok,uve gone OUT of cam and IN to VCR player?,then press play on cam and record on VCR,u should see whats recording as long as your on your normal video channel
Aug 17, 2009 | LG V181 DVD Player/VCR
Don't know how to copy video to DVD
blank disk to dvd tray....VHS in deck....PUSH PLAY ON VHS...and RECORD on DVD BURNER....if it is a burner...they weren't all burners....it has to say DVD WRITABLE or some thing in that mannern
May 10, 2009 | Panasonic PV-DM2792 Triple Play 27 in....
Wont burn to disc
I don't you can record because you are going from analog to digital with out a conversion proccesor. need to investigate. .type in google problem.
Mar 12, 2009 | Philips Televison & Video
Playing back a DVD.
Does it do this only from the remote? Or does it do it when using the buttons on the front of the machine also? Even though the unit is only 3 months old-I'd go to the manufacture's website and check support Q&A, and see if there is a Firmwear update.
the problem could also be in the brand of blank disks you are using. Some machines can record on all brands- others cannot. Sometimes the speed rating of the blank DVD can hose things up. Go to www.videohelp.com and put in your machines model numbers- they might have a list of compatable blank disks for your model-if that is the case. Let me know what you come up with. ONE OTHER QUESTION- does the DVD copy you made work in anyother DVD player- that would tell us a lot.
Jun 27, 2008 | Samsung DVD-VR357
Disc Finalize stuck at 99%
press OK button on the remote of the DVD to take finalize 99% off the screen , then EXIT button
Mar 01, 2008 | RCA DRC8335
Memorex MVD4544 VCR will not record
Take the unit back to the store and exchange it for an other unit of the same. The likelyhood of two units not working is very slim, and good luck with your new unit.
Jan 26, 2008 | Televison & Video
Recording Snow
If you hook your VCR up to the RCA jacks on the front of the DVD recorder, push 002 on the remote to use the front input jacks. (001 if you hook your VCR up to the rear input jacks)
Push record on the DVD recorder, and push Play on the VCR.
(Pg. 35 in the manual)
When you push play on the VCR, you should be able to see the movie being played on your TV. If you cannot, make sure your RCA cables are good and hooked up correctly.
That's all you have to do, so if it's not recording I would try to take the unit back for an exchange.
Dec 03, 2007 | Philips Magnavox MWR10D6 DVD Recorder
VHS player stops
VCR is set with blank tape..Bring up vcr control on TV with television set on Chanel #3, go to menu
Follows procedure for progamming date,time start,time finish,chanel and.speed and single recording.finally click on menu and turn vcr off. Vcr lights indicate set for taping,,.Does no start to tape at requested time and lights indication taping ready stays on ??????
Aug 22, 2007 | Zenith DVR413 DVD Recorder/VCR
Zenith XBR716 Logo
89 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
