Question about Spark Plugs BR4HS Plug 10/BX #3322
99 jetta need to know which spark plug wire goes to which cyclinder
  • 188 Answers
You cna get firing order off line for the car, areyou can call your local autoparts store and also get tthe firing order.
Posted on Jan 31, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
What is order of coils on front of engine/1994buicklesabreplugwires go to.
How To Install Replace Spark Plug Wires 1993-99 Buick ...
? 4:18
www.youtube.com/watch?v=b75Zwl4qVuc
Jun 28, 2013 - Uploaded by 1A Auto Parts How To Install Replace Spark Plug Wires 1993-99 Buick Lesabre3800 ... check them and now I don't know which one goes to each cylinder.
Mar 11, 2015 | 1994 Buick LeSabre
I need jetta 2.8 spark plug wiring diagram
here is the firing order: 1-5-3-6-2-4
Good Luck
Mar 26, 2013 | Bosch 2000 Volkswagen Jetta GLX 2.8L...
I have jetta 99 that report Code P0300
The ECM has detected random multiple cylinder misfiring (code p0300). Possible causes are spark plugs,high tension leads injectors ignition coils wiring and low compression As it is random suspect coils and wiring
Mar 06, 2013 | 1999 Volkswagen Jetta
The battery cables have six wires and I don't no how to install battery. I don't know what wire goes where
first of all there should only be two wires for battery(+) & (-) the six wires if it's a six cyclinder engine, then it sounds like your holding the spark plug wires, which run from your spark plugs to the distributor cap and I have no idea the make or model/year etc so I can't tell you the proper order, if your lucky they'll be numbers on the cap and that will tell you what wire plugs into where there but to which spark plug I'm not sure.
Sep 13, 2011 | Ford F-450 Cars & Trucks
I need to know the firing order for a 1992 oldsmobile cutlas supreme. I need to know what spark plug wire goes in what order on the cyclinders
1992 Oldsmobile Cutlass Supreme FWD 3.1 liter DOHC V-6 VIN "T"
1992 Oldsmobile Cutlass Supreme FWD 3.4 liter DOHC V-6 VIN "X"
Hope help with this (remember rated this).
May 31, 2010 | Symbol Spark LS 1004
I was told by the dealership i needed to replace the ignition coil and spark plug wires because my 99 jetta vr6 was misfiring. I did that and now it wont start.
You must verify your work.
1. Test for spark. Make sure the coil is producing spark.
2. Did you remove the plug wires one at a time? If not then check to make sure the firing order is correct.
Jan 21, 2010 | 1999 Volkswagen Jetta
99 jetta wont start, lights and radio work, windows dont, it just wont turn over, its not the battery
FIRST IS THERE FUEL IN THE TANK, CHECK THE SECURITY AND CONDITION OF THE BATTERY TERMINALS / CHECK THE HT LEADS ARE SECURELY CONNECTED TO THE DISTRIBUTOR CAP / CHECK THAT THE HT LEAD TO THE IGNITION COIL IS SECURELY CONNECTED / CHECK THAT THE LT WIRING PLUG AT THE IGNITION COIL IS SECURELY CONNECTED / FIT NEW SPARK PLUGS / THEN SPRAY ALL ELECTRICAL CONNECTORS ABOVE WITH WD 40 .
Nov 30, 2009 | 1999 Volkswagen Jetta
Spark Plugs BR4HS  Plug 10/BX #3322 Logo
112 people viewed this question
Top Ngk Vehicle Parts & Accessories Experts
Ian Kime
Ian Kime
Zachary Reed
Are you a Ngk Vehicle Part and Accessory Expert? Answer questions, earn points and help others
