Question about Whirlpool LSR5132PQ Top Load Washer
Washer moves during the spin cycle
Washer moves about 5 inches during the spin cycle, and it eventually gets unbalanced and stops in mid-cycle. This did not happen until very recently. Its been in the same spot for over a year. Is there something wrong with the washer, or do we just need to put a stopper by the legs?
  • Anonymous Mar 10, 2009
    WASHING MACHINE WILL NOT SPIN OUT ON THE SPIN CYCLE. DOESN'T MATTER WHAT CYCLE IT IS ON. THIS IS VERY AGRAVATING AND I HAVE ONLY HAD THE WASHING MACHINE ABOUT A YEAR AND 1/2. WONDERING IF ANYONE ELSE IS HAVING THE SAME PROBLEM.
Due to strong vibration during spinning definitely the machine will stop. All you have to do is to check your load if equally distributed from the tub. To eliminate the vibration and the movement of your washer you need to align the four legs of your washer using level tools. Just put the level on the top of the four sides (front side, left side, right side and backside) then make necessary adjustment if needed on the 4 leg of the washer. Also check the water level of the balancer and the mounting position from the top of the tub.
Posted on Feb 27, 2009
  • 20 Answers
Make sure you are not overloading your washing machine. Also make sure that you load it in evenly.
Posted on Sep 08, 2009
Try a smaller load. Try re-leveling the feet.
Posted on Feb 16, 2009
Washer make sounds, like brake sliding during mid cycle
Could be that your washer is unbalanced internally causing the tub to be rubbing against something else internally. Also check that your fan belt has automatic tensioning when it spins the tub.
Jan 31, 2015 | Washing Machines
Washer stops mid cycle
Hi there if the washer is doing this it may be detecting it is unbalanced or has too much in it and it will stop it from spinning as if it doesnt it will fly apart when spinning, try halving the load you put in it and if that doesnt help it may be the actual balancers and you may have to get an expert to rebalance it
Apr 10, 2012 | Frigidaire GLWS1349A Top Load Washer
Whirlpool washing machine make loud noise after spin cycle quits. Noise continues until cycle winds down. Sounds like a machine gun being fired
Hello,have to tell you that most noises from a washing machine occur during the spin cycle. If you hear loud thumping noise during the spin, the load of cloth may have become unbalanced. Stop the washer and redistribute the cloths, then restart the machine. Repeat these steps if necessary.
Thanks
Jun 04, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
During spin cycle it becomes unbalanced and it beeps and stops
It sounds like the sensing arm of the out of balance switch assembly is wrongly set. Get the guy back to do the job properly at no charge!
Oct 19, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machine Moves in Spin Cycle
There are 2 things you can do.
All washing machines have an off balance shut off, some are touchy, some let it run around the house. With wht machine empty, lean it towards you, on the 2 front feet, about 2 or 3 inches and let it drop. The self leveling feet in the rear must BOTH make good floor gontact and sometimes, just the weight of the machine will not adjust them. The other thing is, make sure the load is evenly distributed. Coats, blankets, small rugs etc. are very heavy when wet and they tend to throw all of the weight to one side.
There is no screw holding the yub in place. It hangs on the center post, where the agitator goes. There is however, what's called a snubber. It is a rubber device that looks like a flattened suction cup, that comes in contact with the tub. It helps keep the tub from jumping around too much.
Feb 02, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Load squeal when it in the agitation cycle.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
for detailed help with diagrams and step by step instructions click the link http://www.applianceaid.com/washerspinnoise.html
Dec 29, 2008 | Admiral AW22 Top Load Washer
Looks like the drum has droped
You will need to get the bearings replaced. Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Sep 18, 2008 | Frigidaire ATF6000ES Front Load Washer
Noisy Spin Cycle
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
Jun 12, 2008 | Whirlpool LSR9434PQ Top Load Washer
Kenmore 80 series washer stopped during unbalanced spin cycle
lid switch is broke lever probley broke off or screw holes broke out due to off balance load forcing tub over against switch lever
Apr 29, 2008 | Kenmore 20172 Top Load Washer
Excessive shaking during spin
hi thanks for the question is the washer on the main floor on a wooden floor if it is re level washer next pull washer towards you tipping towards you lift from floor a few inches and let drop to floor this will re level the back legs thanks the appliance doc
Mar 17, 2008 | GE Profile WPRE6100G Top Load Washer
Whirlpool LSR5132PQ Top Load Washer Logo
969 people viewed this question
Dan Webster
Dan Webster
Sal De
