Question about Caloric 24 in. CDU510C Built-in Dishwasher
Water does not drain completely,water from sink backs up in DW
Caloric Quiet Clean Dishwasher DUS600B-35- Water stays in the bottom of the dishwasher and if water is ran in the sink the water starts to back up in the dishwasher and stinks after awhile. Also dishwasher does not clean dishes they come out very very dull with a white film even after draining all the water out and using a rinse agent. Do I need to get another dishwasher?
  • Caloric Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasherWater does not drain completely,water from sink ba - 2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on Jul 12, 2010
Replace dishwasher
Is your DW plumbed into the garbage disposal as many are? Or does it have the drain line running into a pvc opening in the sink drain line? Remove the drain line to see if water gushes out. If no or minimal water leaves your drain line from the DW, then the problem is internal in the DW. Most likely cause is a plugged screen at the inside bottom of your DW, or the pump is blocked. Best way to resolve is to get a wetvac and just suck all the water out of the inside before you remove the DW. Otherwise you will have water splashing out on your floor. If you can see the screen is plugged up after doing so, then pull the screen out and then turn the DW on. If operating normally it will go into the pump out mode first before adding any water. Turn off the water to the DW under the sink first to eliminate any concern about adding additional water into an already filled up DW. Good Luck!
Feb 16, 2017 | Dishwashers
Electrolux dishwasher overflows
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Aug 09, 2012 | Dishwashers
My Frigidaire dishwasher has dirty water.standing in bottom. Dishes are not clean
Aug 08, 2012 | Dishwashers
Frigidaire gallery dishwasher model#DGHD2433KF1 water droplets remaining on top lower water not draining all the way leaving an odori
Jul 20, 2012 | Frigidaire Dishwashers
Our Bosch dishwasher has water filling back in bottom of dishwasher after cycle is complete. You can empty dishwasher and no water will be in the bottom, but several hours later the water has filled the...
Check the drain line underneath the sink.
It should be suspended just below the counter top.
If it is too low,water from the sink will back fill into the dishwasher.
If the drain is OK,then the dishwasher water valve is defective.
Mar 26, 2011 | Bosch SHU3306UC Built-in Dishwasher
My Kenmore dishwasher leaves water in the bottom of the dishwasher. Is that OK? I notice the water when I clean out the bottom tray.
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
heatman101
Jan 18, 2011 | Kenmore Washing Machines
There is water left in the dishwasher and the smell comes up through the drain
Look under the sink where the dishwasher drain line connects to the waste pipe outlet. The dishwasher connecting hose should be supported higher than the outlet connection. If the dw drain hose is too low the sink drain water is backing into the dishwasher.
Nov 09, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Water in the dishwasher after the the cycle is complete
Nov 19, 2008 | Whirlpool 24 in. GU1200XT Built-in...
Water Stayed in dishwasher
Dishwasher Problems - Water will not drain out
heatman101
Oct 28, 2008 | Frigidaire 24 in. FDB750RCC Stainless...
Fisher & Paykel Dishwasher leaked
From what you describe, drain water from the top drawer is getting into the bottom drawer or waste water from the disposer is backing up into the bottom drawer.
1. Each drawer has its own drain hose. Each hose should terminate at the drain point with a 'Y' adapter.
2. Inspect the drain point (under the sink where the drain pipes are) to make sure this 'Y' adapter is present. (you should see two drain hoses from the DW). If not present, then the DW drain lines are not installed properly. (Someone took a shortcut and installed the 'Y' adapter behind the DW)
3. If terminated properly, make sure the drain hoses extend upward as they leave the drain point.
It is important the drain lines are connected properly to ensure proper drainage from the DW. Consult the installation manual for complete details.
Jun 08, 2008 | Fisher DD603B / DD603W / DD603H Dishwasher
Dishwashers Logo
362 people viewed this question
Top Caloric Dishwashers Experts
Are you a Caloric Dishwasher Expert? Answer questions, earn points and help others
