Question about Whirlpool ER6AHKXPQ Top Freezer Refrigerator
Refridgerator Makes a loud cachuck noise when shutting off
  • 22 Answers
One of the springs that retains the piston in the compressor is broken. Refrigerator may operate for years like this, but check your warranty many refrigerators have 5 year coverage on the sealed system.
Fieldpro Appliance Repair & Installation 503-775-3501
Posted on Apr 02, 2009
How do I stop the loud knocking noises coming from my refridgerator?
Pull the fridge away from the wall and inspect the compressor. Your description sounds like the compressor is hitting something. It is rubber mounted and usually can be pushed away from whatever it is hitting.You do not want to jamb something to stop the noise, as the compressor needs to move freely. Many compressors shake during start up and shutdown, and this is considered normal. Abnormal if the compressor hits something during this movement.
Feb 05, 2012 | Kenmore Refrigerators
My old side by side Kenmore with Icemaker makes a loud rattling sound when it stops running. It is the existing refridgerator from when we bought our house so I don't have any warranty info on it. Any...
If the noise is loud enough that it sounds like somone knocking at your door then it is probably going to be the compressor. There are internal springs and is possible one broke. The only solution is to replace the compressor. It is also possible that the condencer fan motor is hitting something as well when it shuts off. You would have to look at it from the back as it shuts off after running.
Nov 02, 2010 | Kenmore 53642 / 53644 Side by Side...
When the refridgerator compressor turns on the fridge makes a loud chatter and slight ringing noise.
see if there is a fan in the back something could have been caught there
Sep 12, 2010 | Refrigerators
Loud humming noise
try using a spirit level to make sure unit is sitting square,the most common cause of noise.....(also make sure its not touching the wall....)
Apr 13, 2010 | Whirlpool ED2FHSS Side by Side...
My Maytag refrigerator makes a loud popping noise. It woke me up at 1 am. Refridgerator is 10 years old no ice maker. The sound is pretty loud. Is this a bad sign? Is there any danger here? Should I be...
the popping noise you're talking about, could it just be your self-defroster in operation,sometimes if there a lot of ice and it operates a long time, there could be expansion noises,such as the refrigerator walls expanding/contracting from the heat of the defroster,if it's water you will hear a sizzling popping sound,nothing to fear dear
Dec 08, 2009 | Maytag MSD2756G Side by Side Refrigerator
Excessive noise when refridgerator shuts off
Remove the rear cover at the compressor and check for loose mounting bolts on the compressor and fan motor.
Feb 21, 2009 | KitchenAid Refrigerators
My refridgerator rattles loudly
Try to reduce the vibration of the copper refrigerrant tubes that are connected to the compressor by inserting some polysterene insulation material ( the typre you get as packing material)
Nov 11, 2008 | Whirlpool Refrigerators
Refridgerator is not cooling or freezing
If the compressor comes on, then it is most likely working, unless it makes a loud humming noise. However, if it makes a clicking noise, it could have a bad relay. If the compressor gets too hot, it will shut itself off on overload until it's cool enough to run again, which is usually long enough to defrost your food.
You may have a problem in your sealed system. If this is the case, there may be a refrigerant leak somewhere. If this is the case, you should have a technician come out. Your sealed system should be covered under warranty if your refrigerator is under 5 years old.
Please let me know if you have any other questions about this.
Mar 10, 2008 | Refrigerators
Samsung side by side refridgerator making noise and freezing
its a heater cycle problem..the defroster is not working properly. its building up ice in the evaporator that touches the evaporator fan that makes that loud noise but stops when you open a door. it could be either a bad heater, a bad thermo disc or a bad timer.hope i was able to help
Feb 12, 2008 | Refrigerators
Refridge makes a loud noise
are you sure it is the compressor making the noise and what sort of noise is it. if it is the compressor, there is no cure except replacement which is not diy.
Mar 27, 2007 | Hotpoint HTR16ABSR Top Freezer...
Whirlpool ER6AHKXPQ Top Freezer Refrigerator Logo
194 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
