Question about Samsung DVD-VR300 DVD Recorder/VCR
Samsung DVD-VR300 - cannot get VCR or DVD to play
Not sure how to configure "setup"...i think maybe the "channel" setup is incorrect. TV and DVD/VCR are hooked up via basic "cable", and I'm just not sure all "setup" is configured correctly...
    President:
  • 1,285 Answers
Cable from wall/outside to cable box in, cable box out to dvd/vcr in ...dvd/vcr out to tv...........set both tv & dvd/vcr to Ch 3.........
note you will not be able to record (probably) HBO on to DVD (vcr yes)
Posted on Aug 28, 2010
Sanyo DVW 7200 PS2 won't work
Tune the DVD/VCR to "channel 3".
Dec 18, 2013 | Sanyo DVW-7200 DVD/VCR
VCR/DVD & Samsung TV: "weak or no signal"
Take the VCR remote, check VCR output settings ( scart1, scart2 , RCA) and signal format (PAL) etc
Jul 26, 2008 | Samsung TX-T3093WH TV
I have a model dvd-vr 357 samsung dvd-vcr player recorder to hook up to a 2002 hitachi, and i must have it hooked up wrong.the tv is a 52 inch large screen h.d. the dvd -vcr turns on and when play is...
You need to use the video and audio outs located in the rear of the samsung player, or if you want to use the rf connector(atenna in) on the tv you need to select analog channel 3 or 4 to get a picture through, you can down load an owners manual at wwwretrevo.com.
Feb 03, 2010 | Televison & Video
I am unable to get my vcr to record. To use my vcr i have to turn my tv to channel 3. Our cable company uses channel 4. Please help
If the tv is working with the cable box with the coax to channel 4 ( then with this configuration to send any signal to the VCR actually it is posible to use a splitter with coax and send the signal to the tv and vcr after the cable box. vcr has tobe in channel 4 also, all channel selection is done in the cable box then anything you see in the tv is recorded in vcr. BUT guess what: You maybe can try something else:
If you send the cable from the wall straight to the splitter and then from splitter to the TV and to VCR, now you can record differnt channel than you are watching in the tv but in this case scenario you need to send the vcr to the video input 1 of the tv to play what is record. Any way to install this TV and VCR you not always need to depend in the cable box.
May 01, 2009 | Sanyo DVW-7000 DVD Player/VCR
I have a samsung dvd vcr combo connected to a jvc tv but when i have press play i get no screen for either video or dvd the dvd runs but no recpetion
If you are connecting the dvd/vcr combo to the tv with coax cable first make sure the tv is on channel 3 and also make sure you have the samsung dvd/vcr combo on channel 3 by using the remote that came with the samsung. You should get picture and sound then if not try channel 4 on tv instead of channel 3. If that doesn't work try to put the samsung on channel 4 as a last option to try. This is only recommended if the combo is hooked to tv with coax cable out of combo to in on tv. Make sure coax is plugged into the out jack on combo and in on tv.
Nov 26, 2008 | Insignia Digital-to-Analog Converter for...
Change TV channel on SAMSUNG DVD-VR350
Hello Giancarlo, You'll have to use the projectors remote for T.V. tuning. I don't think the samsung DVD remote will operate your projector or your T.V. channels, will it? If it does, You just have to switch the input button on the remote to change between T.V. and Video. I hope that helps.
Jun 02, 2017 | Samsung DVD-VR320 DVD Recorder/VCR
I broght a 32 Sharp T.V. 1080P (LC-32D62U)wroks fine. Attached is VCR(RCA) & DVD(GE) works fine except when I record on the VCR. Play back is just snow?
try channel Line 1 or Line 2 on your TV and or VCR... not channel "3" if  you're using "RCA cords".  Also, make sure your VCR and TV are "SETUP" to look for composite input's rather than coaxial.
good luck!
thomseye
May 11, 2008 | Sharp Televison & Video
Configuring I/O cable box, VCR, DVD.
Unfortunately you would need a second digital cable tuner to do what you are trying to do.
The digital tuner only outputs one channel at a time, selected by that box, so you can only record or watch that one channel at a time.
Many people are switching to dual tuner DVR's to cure this dilemma.
Feb 17, 2008 | Televison & Video
Samsung DVD-VR300 DVD Recorder/VCR Logo
145 people viewed this question
Henry  Thomas
Henry Thomas
