Question about HP Pavilion dv6000z Notebook
Hp pavilion ze5500 display monitor still doesn't work
Hi.
There was no image in the laptop display, but I could see everything in an external monitor bright and clear. Windows was working good too.
So I figure that the problem wasn't the laptop video card, but the LCD.
So I change it for another hp pavilion ze5500 display in stock. But no image. Try setting the brigness with fn + f1/f2 but nothing at all.
I said: "Ok, this other LCD is also bad, I'll have to buy a new one".
So went to ebay and buy a used hp pavilion ze5500 LCD display for $78.
I instaled everything correctly: ground cable; antena cables on the two sides; the power cable; and turn on the laptop. Still no image in the laptop LCD, still everything works fine in a external monitor.
Could the problem then be the video card? I tought that if you can see stuff clear in an external monitor the video card is ok.
Is the LCD I bought from ebay is also defective?
Don't know what to do next. Please help. I'll apreciate your answer.
Thanks.
God bless
  • 3 more comments
  • EdPC Feb 02, 2009
    I see. Thanks.
    Is there a way I can fix this without the need to buy a motherboard?
    Thank you very much.
  • EdPC Feb 02, 2009
    Hi, eifion_edwar.
    The screen is permenantly blank right from the get go.
  • EdPC Feb 16, 2009
    Hi again.
    Well I change the Motherboard and it works fine. So, I guess it was the function key circuitry on the motherboard that controled the back lighting levels on the LCD as stated by Geekman.
    But I'm wondering. Is there a way you can target this problem without the need to test/buy a new LCD or a new MOBO? Cause I think the first thing that comes to mind is that the MOBO video card is ok and that the first choice is to test or buy an LCD.
    Can you identify the problem with the same laptop or you'll always need replacment parts?
    Can I change those function key chips so I can fix the old MOBO?
    Thanks a lot
    God bless
  • EdPC Feb 18, 2009
    Yeah, I see. Thanks
  • Eifion Edwards May 11, 2010
    Does the screen go blank when you log on? or is it permenantly blank?
  • HP Master
  • 32,281 Answers
IT could be a motherboard problem with the function key that controls the switching of the video infomation between the LCD screen and the external video connector.
It could be the function key circuitry on the motherboard that controls the back lighting levels on the LCD.
Posted on Feb 01, 2009
  • Chris Hingee
    Chris Hingee Feb 02, 2009
    You could try to reseat the connectors on the motherboard that connect the LCD screen, that is your only hope, but I think it is a motherboard problem.
    The cheapest option is to use an external monitor with the laptop.
  • Chris Hingee
    Chris Hingee Feb 17, 2009
    Usually you need to change parts and or motherboard to solve the problems. To identify and to purchase the SMD chips is difficult and if you could purchase the chip, you need special gear to remove the defective chip and to solder the new chip. You will find the repair shops just replace the defective motherboard and components, it is the most cost effective method and least time consuming.
    In some cases it is better to buy a new computer and use the old components such as the hard disk, insert it into an USB drive enclosure and use it as an external hard drive for backups etc.
Hp pavilion dv4 laptop display works with external display only
Switch the display to the laptops screen. Shine a flash light on the screen and look very carefully for a faint image of what should be displayed. If you see it then either the back light or inverter board is dead. Usually the inverter board. These are housed inside the lid usually runnung alone the bottom of the display. If there is no image then the display is bad. The easiest fix would be to remove the entire lid and replace the whole thing. This will effectively replace all three parts I mentioned, but will be more expensive.
Dec 15, 2012 | Computers & Internet
My laptop comes on but the monitor is blank
Your backlight is probably burnt out or the inverter needs replaced. The backlight will be a pain in the rear to do so you might want to try a new / used (working) inverter in it first. Hook your laptop up to a external desktop monitor. If you computer boots up, and you can see everything on the external display, you've got an inverter or backlight issue. Shine a flashlight on the laptop screen. You'll see a very dim image of your desktop.
Sep 09, 2012 | HP Pavilion dv4000 Notebook
Hp dv9700 pavillion entertainment laptop, screen won't light up, no sound on start up,
I suggest try to use an external monitor to see if the machine will display an output through the external display, if you have display to your external monitor, it means the LCD on your machine is not working.
Feb 22, 2011 | HP Pavilion DV9700Z notebook PC
HP Pavilion dv9000 Screen Black - fan runs, hard drive is spooling, Yes you can see an image on a second monitor. Yes i tried the reboot with battery out and holding down the power button etc... I...
hello
these links below have information (drivers, solutions) for your laptop, that will assist you.. review them , i am sure this will give you background causing BLACK display on your screen.
If there is a problem with the LCD display's back light or a corrupted graphics driver, the display may appear blank but the notebook may be displaying information. Attach an external monitor to test the display. If the image displays on the external monitor, there may be a graphics driver conflict. To resolve this, turn on the computer and press f8 key, then select Enable low-resolution video . If the image displays on the LCD display in low resolution, you can download and install the latest drivers for your specific graphics driver. If there is an image on the external monitor but the notebook display remains black, contact HP for technical assistance.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01997899&lc=en&dlc=en&cc=ca&product=3224049
http://h10025.www1.hp.com/ewfrf/wc/product?product=3224049&lc=en&cc=ca&dlc=en&lc=en&lang=en&cc=ca&submit=GO
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=27870&tmp_task=solveCategory&lc=en&dlc=en&cc=ca&lang=en&product=3224049
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01881110&tmp_task=solveCategory&lc=en&dlc=en&cc=ca&lang=en&product=3224049
Nov 08, 2010 | HP Pavilion dv9000z Notebook
I have an hp pavilion n5430 that wont power up. The lights on the front light up but thats it. What could be wrong?
Hi Friend,
If You have External monitor at your place pls connect to your laptop and check whether you are getting external display on monitor screen, if there is no display on external monitor that means motherboard of your laptop might have some problem. if that is the case you have to visit service centre.
Jun 30, 2010 | HP Pavilion N5430 Notebook
HP DV600 when switch on everything working but no display to De screen & no display to external monitor
i guess the motherboard has gone bad!
try reseating the RAM and check, if it starts working then you are lucky or else..... u need to replace the motherboard.
for further help, mail me at L2support.hp@gmail.com
Jun 11, 2010 | HP Pavilion dv6000z Notebook
HP pavillion dv9005 no display - works fine on external monitor
If the notebook's video card (which may be on the motherboard) is successfully displaying images on an external monitor it sounds more like a problem with the notebook display or its connections. Probably the motherboard is OK.
Jul 09, 2009 | HP Pavilion dv9000z Notebook
My external monitor suddenly has a blue tint
Try a different monitor, if it is OK then your 19" monitor is faulty or the video cable is faulty.
Apr 06, 2009 | HP Compaq Presario F730US Notebook
Display Problem for HP DV8230us laptop
hi there,
sounds like you have a driver or internal video card problem...but first have u tried changing the screen size/resolution and color depth/quality in your display settings...
Apr 09, 2008 | HP Pavilion dv8230us Notebook
HP Pavilion dv6000z Notebook Logo
340 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
