Question about HP PSC 1210 All-In-One InkJet Printer
How to fix a missing' print spooler service'
Automatically printer hp1210 stopped working .I tried to add a printer . But ' print spooler service ' missing message appears.
pl help
khanmohammad
  • 188 Answers
SOURCE: HP PSC 1400 series printer won't load
Hi Flame,
Please click on the web link given below and perform the steps as provided in the web page to fix the installation issue.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00625472&cc=us&lc=en&dlc=en&product=441115
Make sure that you have completed all the steps perfectly and carefully.
Please perform this additional step.
click on start >> Run
In Run box type services.msc /s and press enter.
You will see a services page.
Search for print spooler
Double click on print spooler.
Make sure that start up type is "AUTOMATIC"
CLick on stop and then start the service.
Then start installing the printer software, this should fix the issue.
Have a great day!
Posted on Mar 27, 2008
  • 8 Answers
SOURCE: 1020 Spooler SubSytem
ok, so for this, always had an issue with this one,
so, what i did is started the spooler, the way to do this is you have to go into control panel>>>admin. tools>>> services>>>printer spooler>>> and then you have a blue icon on your left where you have to click on the button that says start the spooler, now i recommend you minimize this window,
next step is that you add the printer through the add a printer wizard in most cases the printer should already have the basic driver installed into the computer. and way to add it to to start the add a wizard, click on add a port make sure the box where it reads plug in play is unchecked, so the only icon you have checked is the local port, next you choose the port that is usb001 from here you choose hp>>> then laserjet 1020, let the printer driver install and finally your done.
Posted on Jul 10, 2008
Scott Ellin
  • 558 Answers
SOURCE: print spooler service not running
This means your printer is not correctly installed. Please remove the installed driver and printer from the PC and then follow the steps given in this TIPs N Trick by me:
http://www.fixya.com/support/r1133275-drivers_installation_problem
Posted on Nov 04, 2008
SOURCE: HP print spooler problem and error 1068. Want my printer back!!!
Unplug HP 1022n printer.
In command line >> net stop "print spooler"
In command line >> net start "print spooler"
(Reason for command line: Service normally times out while stopping in services list)
Open regedit and go to HKEY_CURRENT_USER --> Software --> Microsoft --> Windows NT --> CurrentVersion --> PrinterPorts
Deleted HP 1022n printer there
Open regedit and went to HKEY_LOCAL_MACHINE--> Software --> Microsoft --> Windows NT --> CurrentVersion --> PrinterPorts
Went back to Printers and Faxes page. File --> Server Properties --> Drivers tab
Deleted HP 1022n print driver
Go to HP.com and downloaded the driver from website
Plugged printer back into docking station
In Printers and Faxes --> Add Printer --> Local Printer Attached to this computer --> Unchecked Automatically detect and install my Plug and Play printer
Name queue whatever you would like, share printer if you want. Loaded driver that you downloaded from HP. Finish install.
Posted on Apr 01, 2009
ginko
  • 19396 Answers
SOURCE: Printer Spooler Service not working
Reinstalling drivers usually fix this problem.
Reinstall drivers with printer connection cable unplugger, either using driver CD or download from the link below.
HP LaserJet 1020 Printer series - Download drivers
Posted on May 21, 2009
Wireless printer stopped printing
Try resetting your print spooler que and restarting service. You can download a batch script to do this automatically. Reset Printer Spooler Tool for Windows Vista 7 and 8 Appuals
If this doesn't works, then try to reconnect your printer to the router and add it back to the computer.
Jan 17, 2014 | Acer Aspire 5500 5570-2609 Laptop
Tip
HOW TO CHECK AND FIX PRINT SPOOLER SERVICE THAT CAUSES UNABLE TO PRINT FILE...
Print spooler service is a computer service that loads the print jobs into the printer memory for later printing and it acts as intermediary between a computer and a printer. When the print spooler service is stopped or malfunction, printing is not possible.
Here are the possible reasons :
1. Virus or Malware infection.
2. Spooler service was stop by accident or turn off to manual/disable mode.
3.Faulty installed printer driver that contains error or incompatible with previous printer drivers installed in your computer or system.
4. Print jobs and drawing jobs were corrupted by accident which caused print que lock and resulting print spooler service to crash.
5. Your printer had printing problem issue with pdf files.
To fix this problem, you have to check if the print spooler service had stop.
Here's how to check and fix the print spooler service.
Go to START
Choose RUN
Type SERVICES.MSC
Click on PRINT SPOOLER and check if the STATUS IS STARTED
If not, on the upper left side, click on STOP to stop the spooler service
Then click on RESTART to restart the spooler
Restart your printer and your computer
Then try to print again and it will surely solve your printing problem.
Another procedure :
Go to START
Right click on DOS command prompt and run as administrator
You should be in this command directory before you
Type CMD and be sure you are in this directory C:Windows\System32
And if not, type this to change the directory, CHDIR C:Windows\System32
Type NET STOP SPOOLER and message will appear like this
Exit and go to C: DRIVE
Choose WINDOWS and click show content if not view all the folder files
Choose SYSTEM32
Choose SPOOL
Choose printer and delete printing jobs if any
Again right click on Command prompts and run as administrator
Type NET START SPOOLER
Exit and restart your printer and your computer
I will works fine right now.
NOTE : You can bypass the C:Drive procedure and just type NET STOP SPOOLER AND NET START SPOOLER in the DOS COMMAND PROMPT if you believe that there are no printing jobs pending.
Another procedure is to download this troubleshooting software and follows the troubleshooter wizard and it will fix your print spooler service automatically and some common problems as well.
Click here to start downloading.
I hope it helps you solving your print spooler problem. Regards to all readers.
on Mar 24, 2011 | Office Equipment & Supplies
Printer stop printing
It could be the Print Spooler service on your computer that's not properly working. Try these steps to fix the problem:
  1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
  2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
  3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
Try to print a document again to verify that the problem is fixed.
Mar 11, 2012 | Lexmark X5470 All-In-One InkJet Printer
On command to print with my epson lx-300+, message reads, "No Printer". When searched on fax and printer and double-clicked "Add Printer", a message came out saying, "It can't...
Hi Basti here,
Try this...
If you are receiving SPOOL.SVC or PRINT SPOOLER ERRORS when trying to uninstall/reinstall your printer, or when trying to print a document or access the printer properties, please follow the steps below.
The following are examples of some of the messages you may be receiving:
Spool.svc is not running. Make the service active and try again.
Printer Properties cannot be displayed. The print spooler service is not running.
Printer cannot be removed. The print spooler service is not running.
Windows cannot print due to a problem with the current printer setup.
(When clicking Add Printer) Operation could not be completed.
NOTE: Only these types of errors warrant the troubleshooting steps clearly defined below.
Resolution:
SPOOL.SVC is an operating system function which carries files through the operating system for printing. It must be STARTED (active) to be able to print or access any printer's functions. This file usually starts automatically with Windows, however operating system issues may cause it to become stopped. You cannot uninstall or reinstall a driver while this service is stopped.
Please try the following to start the service again:
1) Click on START, right click MY COMPUTER, left click MANAGE.
2) On the left column, double-left click SERVICES AND APPLICATIONS, then click SERVICES.
3) Locate and highlight the PRINT SPOOLER on the list of Services.
4) Click START THE SERVICE.
If errors occur and the service cannot be started, there is another issue within the operating system itself.
May 23, 2011 | Epson LX-300 Matrix Printer
Print spooler stops / Printers missing from machines
try C:\WINDOWS\System32\spool\PRINTERS
this path in spooler path
Jul 14, 2009 | Ricoh Aficio MP1600SPF Copier
Printer Spooler service!
Click on "Start, Run", type "services.msc"
On the right side of the services window, scroll down to "Print Spooler". Double-click it.
If startup type is "disabled", click the drop-down and set to "Automatic" and then click "Start". If already on automatic, click "Stop" to stop the service. Once stopped, click "Start" to restart the service.
Reboot and try again :)
Hope this helps - remember to rate!
Oct 01, 2008 | HP DeskJet 5550 InkJet Printer
Spooler servis dont work
Resolution:
Aug 25, 2008 | HP Office Equipment & Supplies
Just go to your Server or Desktop PC and enable the RPC service (Remote Procedure Call)
Right click in "My computer" icon, from the manu select "Manage" then go to "Services and Applications" and expand that, after that select "Services" you will find that services in the right pane, just click in "Start"
I hope this work for you, good luck!!!!
Jul 28, 2008 | HP LaserJet 1022 Printer
SPOOLER SERVICE IS NOT RUNNING
Resolution:
Pls Rate as Fixya if this helps, Thanks!!
Jun 26, 2008 | Dell A940 All-In-One InkJet Printer
Printers vanished and can't add printer
Your shell extensions have a software conflict. The offending piece of software will have to be determined and removed, or at least stopped, before re-booting the computer. You may be able to repair the problem using the System Restore option.
Oct 10, 2007 | Adobe Acrobat Distiller Server V6 for Win...
HP PSC 1210 All-In-One InkJet Printer Logo
429 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
