Question about Inter-M R-500 2-Channel Amplifier
Can I jump the amp hooks in back for stereo
I have a amp Inter-M 500plus and I wanted to know if I can put in in stereo mode, and jump both postives and jump both negatives, and hook it up.
  • imraja12 Jan 31, 2009
    Thanks, I have it in the stereo mode right now. Bascily my receiver I have 2 outputs and have in the AMP in Input 1 and Input 2, but then thier are 2 seperate outputs for each channel, can i just combine both channels into 1 by jumping them together.
    Champion:
  • 211 Answers
On teh back there's a mode switch, you can put this one on stereo. Then you have a normal stereo amp.
regards,
Gerard
Posted on Jan 31, 2009
  • Gerard Jan 31, 2009
    You can take line-out or rec. out of your receiver and connect them to the amplifier. You can connect the left chan. to input 1 and the right channel to input 2 of the Inter-M. Then you can connect your speakers to the binding post outputs. So output 1 will be your left. chan. and output 2 your left channel.
    Please watch the inputs on the Inter-M, those are XLR connector's.
    If you are using them, then you have to have to solder the inner cable to point 2 and the shield on point 1. Then you have to make a link from point 1 to 3. That's the right way to connect a unbalanced pre-amplifier to a balanced amplifier.
    Maybe you can also use the jack inputs (if there are some on the amp).
    I hope my story is clear, if not, please let me know.
    Regards,
    Gerard
Can I run two stereo amps from same preamp?
yes, and do tell, what speakers are you powering with these amps?
Jul 09, 2013 | Bose 901 EQ1915 Home Equalizer
When battery was jumped hooked up backards
Whats the question, if the battery didn't blow up it should be fine, unless it blew a 15 amp or higher fuse in your main fuse box and will not start.
Feb 15, 2013 | Jeep Grand Cherokee Cars & Trucks
Put new alternator on 2000 jimmy envoy 4.3 now I get 7.3 volts my instrument panel flickers. had no preveise problems. put old one back on and now it does same thing. how do I know what wires to trace
I dont know if this will help but my sister had 2001 envoy and had similer problem we found wiring harness next to exaust was burnt and stuck to it. we pulled it off and blacktaped wires. this fixed her car. good luck
Feb 14, 2012 | 2000 GMC Jimmy
PYLE PT2001X 3300 Watt Professional DJ Power.just had question about running this amp in bridged mode 4 ohms, here's some amp info 3300 watts total power bridged in 1 ch only.1650 each ch in stereo mode...
In bridge mode the minimum load will be 8 Ohm.
If you are using 4 Ohm speakers, it will mean you will give each side of the amplifier a 2 Ohm load.
Thats to much for this model.
Kind regards,
Gerard
May 13, 2010 | Pyle PT-2000 Amplifier
Stereo wont stay on and only couple speakers work
on the back of the stereo you should have an rca inputs in the back, it should say either rear, subwoofer, or non-fade. all of these are acceptable, run rca's to the amp from the deck.
also on the deck in the wire harness is a blue wire with a white stripe.
hook a wire up to this and run it to the REM. terminal of your amp. this wire tells the amp to turn on when you turn on your key.
these are the only two wires you hook up the back of the stereo.
hope this helps
Jan 07, 2010 | Sony Car Audio & Video
PHOENIX GOLD RYVAL V1502
Most the time want happens is the postive wire is not the right gauge or the amp cant handle pusing two speakers you m have to put in two amps try hooking up one sub and see want happens if it dosent die out the amp not strong enough for the 2
Jul 08, 2009 | Car Audio & Video
Legend Amp hook up manual.
Pretty Straight Forward get a 8 or 4 gauge amp wiring kit.
Run your hot wire to the +12V from the battery make sure to install the supplied inline fuse near the battery don't connect to the battery until installation is complete.
Run the REM to your stereo power ant. Wire. if available.
Run the GND to Metal Chassis Ground keep it as short as possible.
Run the RCA Cable from the back of the Stereo to the RCA Inputs or Low Level on the amp.
This amp is 2 Ohm Stereo Stable which means you can connect 2 (4 ohm) speakers in parallel to each channel or 1 (4 ohm) speaker on each channel or you can connect 1 (4 ohm) Speaker in bridged mode.
There are other speaker configurations you could use but you cannot drop the load below 2 Ohm in stereo mode and no lower than 4 ohm in bridged mode.
Hope this helps
Mar 25, 2009 | Legend LA1490 - American Legacy Series 2 -...
I cant figure out how to jump start my 1993 BMW 325is
Either hook the jumper cables to the battery in the trunk or hook the postive to the postive stud under the hood( passenger side near the firewall) and the ground to the block.
Mar 25, 2009 | 1993 BMW 3 Series
Battary
is it not inside your engine compartment? if it is not there, the best place to look for it is the trunk.
tnx 4 using fixya,
drcool
Sep 27, 2008 | 2001 Oldsmobile Aurora
My subwoofer will not go
Is the SUB connected to both channels? I will give you detailed instructions on how to connect a sub. Check out this website.
http://www.ehow.com/how_5829_wire-car-stereo.html
Mar 03, 2008 | Pioneer TS-W307D4 Car Subwoofer
Inter-M R-500 2-Channel Amplifier Logo
169 people viewed this question
Top Inter-M Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Inter-M Audio Player and Recorder Expert? Answer questions, earn points and help others
