Back to:
Tags:
Evenflo Embrace - Rainforest
Shoulder restraint adjustment
posted by Polola on Jul 31, 2007
I lost the manual for my Evenflo Embrace car seat, and now I can't figure out how to move the shoulder restraint straps up to the next level. I got the black plastic parts at the end of the straps to disconnect from the back of the car seat, but I can't get them to detach from the straps so I can pull the straps back through the back of the car seat and move them to the next notches up. Can you help me?
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jul 31, 2007
Helpful (85)
sgregg
Rank:Guru Guru
Rating: 88%, 186 votes
theres a way in the back of the carset to unhook your straps and feed them thru the higher level. just look inside the back of the carseat.
Comment by sgregg, posted on Jul 31, 2007
should b a bar they r hooked to, just undo the bar and release the straps...mabe im not understanding your question?
ok bad rewiew so ill make it up to ya! Here the WHOLE instructiond, not a bar but i was close... heres a link also!!!
https://plweb.evenflo.com/faq_detail.aspx?faqid=4407
This should be worth a solved!!!!
If you have two plastic harness adjusters located on the back of your seat please follow the following steps: On the very bottom of your car seat locate two metal anchors one on each side of the seat, pull the metal anchors out of position and turn them sideways and feed them through to the front of the seat. Release the buckle tongues and chest clip and pull the harness straps to the back of the seat while pushing the chest clips, buckle tongues and harness anchors through to the back of the car seat. NOTE: You may find it easier by pulling down the seat pad when feeding the straps through. All pieces will fit through the harness slots. Choose the appropriate slots for the new harness position. Push the harness anchors, harness straps, buckle tongues and chest clips back through to the front of the seat. Once the straps are completely pulled back through to the front of the seat, make sure the straps are not twisted by clipping the chest clip together and buckling the buckle tongues, then feed the metal anchors through to the bottom of the seat and clip anchors back into place. ********************************************************************* If you have an adjustment strap that is located in between the child?s foot area that allows you to loosen and tighten the straps please follow the following steps: Loosen the harness straps by pressing the harness release button that is located between the child?s legs near the feet area; while pulling on the harness straps from the front of the car seat near the shoulder area. Turn the car seat around and from the back side of the seat follow the straps down to the metal splitter plate, remove the ends of both straps from the metal splitter plate. Once the straps are removed, pull both harness straps completely through to the front of the seat. Choose the appropriate slots for the new harness position and feed both straps through from the front of the seat to the back of the seat. Making sure straps are not twisted; hook each end of the straps back onto the metal splitter plate. Tighten the harness straps by pulling the adjustment strap located on the front the car seat between the child?s legs. NOTE: Final adjustment of If you have an adjustment strap that is located in between the child?s foot area that allows you to loosen and tighten the straps please follow the following steps: Loosen the harness straps by pressing the harness release button that is located between the child?s legs near the feet area; while pulling on the harness straps from the front of the car seat near the shoulder area. Turn the car seat around and from the back side of the seat follow the straps down to the metal splitter plate, remove the ends of both straps from the metal splitter plate. Once the straps are removed, pull both harness straps completely through to the front of the seat. Choose the appropriate slots for the new harness position and feed both straps through from the front of the seat to the back of the seat. Making sure straps are not twisted; hook each end of the straps back onto the metal splitter plate. Tighten the harness straps by pulling the adjustment strap located on the front the car seat between the child?s legs. NOTE: Final adjustment of the harness straps must be completed with the baby in the child restraint.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Shoulder restraint adjustment:
I don't want to Accept this solution
Can you Help with these Car Seats problems?
Car Seats
I have a Britax Club Class Extra child car seat and I need...
Car Seats
I am setting my boss' clock and i finally got it changed...
Car Seats
I have a peg perego high chair, but no manual. I need to...
Car Seats
The car runs fine in petrol, but when changed to gas, the...
Car Seats
I need 1 bracket for a bebecar car seat to fit on the...
Loading problems.
Repair Service
Find Car Seat Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
