Question about Robert Yick Co. RanRYC168 Gas Kitchen Range
Fire Safety Concerns
I intend to install the Robert Yick Wok Range in my solid oak butcher block kitchen work table. I have plenty of space but I am concerned that as it will get very hot it might not be a good idea for it to be surrounded by wood. Thanks for your ideas. Mundi
  • 944 Answers
Check this link; http://www.selectappliance.com/exec/ce-product/ry_ryc168 The wok model is approved for zero clearance installation by the AGA and CGA. That means that regardless of worktop etc material, it can be right next to the unit, so long as you do not modify the casing of the unit in any way. here's the link to contact the AGA if you want more info; http://www.aga.org/contactus.htm The other thing to try if you want reassurance would be to knock up a simulated worktop out of cheap wood/plywood just to represent the bit near the range, and use it carefully for a couple of days just to see if there is any problem. It should be fine. Hope this helps :)
Posted on Jul 31, 2007
SOURCE:
I left a clay pot on my patio glass table top. It now has square stain. How do I make it gone? The stain is not raised, the edges are not smooth. They are light gray. The pot sat on the table...
Typically MURIATIC ACID is very useful in cleaning stains from masonary and should work to clean a sudo-masonary stain off of glass. MURIATIC acid is normallly in stock at just about all hardware/big box home improvement stores
Aug 29, 2011 | Robert Yick Co. RanRYC168 Gas Kitchen...
Have a glas fireplace insert that a kids rubed a acrylic blanked up against when extremely hot and now it is baked onto glass surface.
Chip it off with a single edge razor blade ... I suggest you get the holder for this blade at your ACE or other fine hardware store in your area. Spend about $4.00 to prevent injury.
Feb 14, 2010 | Robert Yick Co. RanRYC168 Gas Kitchen...
Stove top fire , cleaning my GRXL44 oven,
un plug the range and after 5 min plug back in . the oven should be off but the oven may still be locked . you can open it with a thin hanger .. the clock can bee replaced and back panel if needed . will need model # to help you with parts & prices ..****
Dec 26, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Melted plastic *bread wrapper*
mix vinegar and water in a container,turn the element on to the highest setting.get a METAL paint scraper pour the solution onto the element while scraping off the plastic.hope this helps.
Dec 02, 2007 | Robert Yick Co. RanRYC168 Gas Kitchen...
Water Stains on GE Spectra Ceramic Glass Top
TRY CLR (CALCIUM LIME REMOVER) FROM HOME DEPOT--LOWES
Aug 28, 2007 | Robert Yick Co. RanRYC168 Gas Kitchen...
Robert Yick Co. RanRYC168 Gas Kitchen Range Logo
Top Robert Yick Co. Kitchen Ranges Experts
Craig Butler
Craig Butler
Marvin
Marvin
Paul Carew
Are you a Robert Yick Co. Kitchen Range Expert? Answer questions, earn points and help others
