Question about Desa International HRC201-4 Remote Control
I have a desa hrc 200 remote the room temp doesn't work
The remote will only work on manual, because the room temp doesn't display the temp. It's only a year old. can it be repaired?
  • 188 Answers
It cannot be repaired. Replacement parts are no available for this unit and it only had a 90 day warranty. You will just need to purchase a replacement. You can contact Master Parts at www.masterparts.net or by calling 800-446-1446. I hop this helps!
Posted on Jul 13, 2009
How can i set airworks aircondition pacra9000 to 17c cos it always stay at 29c i cant put it to 17c pls. Help thanks
First check you keep cool mode in your remote. If dry or fan mode, it will not turn to 17.
Still problem, replace with new battery in ur remote and check again.
(In some a/cs display shows the room temp. Even you keep required temp, it accepts but shows the room temp.)
Sep 08, 2015 | Heating & Cooling
Remote control doesn't work
Have the remote itself first checked---most tv shops have a tester--point remote at it and press buttons and it reacts-----Many digital cameras will react on their display screen in a very dark room in the same way.
If remote itself tests good the set has a receiver that takes the signal from the remote and it may be bad.
Aug 29, 2012 | LG 37LD450 37 in. TV
Remote doesn't work
Have it tested with a tester or with a digital camera since many will react on their display screen in a dark room.
Jun 11, 2012 | Samsung AK59-00104R Remote Control
I have a NY116 (DESA/Comfort Glow) heater w/ remote control. The remote control doesn't appear to show the room temperature while in Progrom Mode... preventing the heater from turning on. It works fine in...
The remote control was made by Skytech. You should get the information off of the remote and the valve and contact them for parts.
email
support@skytechsystem.com
fax
888-672-8024
phone
888-672-8929
address
9230 Conservation Way
Fort Wayne, Indiana 46809
Jan 05, 2010 | Desa International HRC201-4 Remote Control
I replaced the battery in our HRC200 handheld it still does not work. We can turn the fireplace on with the manual control at the logs. The fireplace was used last season for the first time. Can you help?
The remote works once the right room temperature is
sensed (66F) by the remote, This is a room temperature
triggered remote.However, if the thermostat at the
remote becomes defective, then there is no way that the remote will function. You have to do it manually.
Oct 13, 2009 | Desa International HRC201-4 Remote Control
HRC 200 does turn on flame.It can be turned on manually only
The sensing device on the remote does not reflect the right room temperature to trigger or activate the remote igniter for the flame.
"The remote igniter is triggered by the room temperature". I'll get
back to you if the there's a way we can reset the trigger temperature.
Oct 02, 2009 | Desa International HRC201-4 Remote Control
Desa International Self Venting Fireplace manuals
Try Googling (desa)(CGFB32CA)(manual) without parens.
Jun 30, 2017 | Ovens
HRC200 remote thermostat for gas fireplace
To turn on the remote you must press the POWER and LOCK buttons together.
Nov 02, 2007 | Desa International HRC201-4 Remote Control
Desa International HRC201-4 Remote Control Logo
293 people viewed this question
Top Desa International Televison & Video Experts
Electro Med Services...
Are you a Desa International Televison and Video Expert? Answer questions, earn points and help others
