Question about Canon imageRUNNER C3200 Copier
Imagerunner 1310 drum change
I need instructions to change the drum for my Cannon Imagerunner 1310 copier . The small screen shows the message that the toner waste is full and requires to change the drum.
  • 318 Answers
To change the drum you have to slide the plattened cover to the left,like you do when removing a paper jam,open the top cover,you will see a handle that you pull to remove the defeloping and drum unit,remove the drum and def unit.
The drum is attached by two clips on top of def unit,unlock the drum from the def by releasing that clips,slide te drum protecktion plate to the rear and remove the drum.insert the new drum by reversing this steps.
If your image of your copies is not bad you can remove the waste toner in the drum unit before replacing it.On top of the drum there are two plugs open them and remove the waste toner,make sure you remove all of the waste toner.Then that message will go away.
Posted on Feb 02, 2009
I have a Canon Imagerunner 1310 and I am getting a message that my waste tomer is full and that I need to prepare a new drum. What does this mean? Can I do it on my own? Will I need to buy something?
Most of the time, if your copies are good, all you have to do is dump the waste toner from the drum. Slide the top to the left and raise the blue cover on the right. Lift the drum and developer unit out of the copier. At the top of the drum you will see a quarter size white plug that should be removed and gently turned over and gently shaken over a trash can to empty the drum. It doesn't have to be emptied completely. If your copies are bad then the drum has to be replaced. Not that hard for the lay person. Lift blue clips and the drum separates from the developer assembly. There was a Canon modification to use two small screws to keep the drum and developer together should the blue clips move out of position. These may have to be removed and put back. Raise the drum guard to make reassembly easier.
Oct 20, 2010 | Canon imageRUNNER 1310 Copier
ERROR MESSAGE 810?
E810 and/or "CHECK TONER/DRUM CRG" message on control panel.
Something is not right in the drum unit. Make sure that the drum unit and developer units are attatched together at the front and rear.
Use caution when removing, the drum is light and scratch sensitive.
If all is well there, either call a service tech or replace the drum unit
Jun 07, 2010 | Canon imageRUNNER 1310 Printer
I need to know what is the kind of drum a Imagerunner 1630 uses.
An OPC Drum is used, you can use Drum of these models image runner 1310, 1330. 1370, 1510, 1530, 1570
Mar 29, 2010 | Canon Image Runner 1630 Copier Copier
Blank sheets when Copying on the Canon Image Runner 1310.
Hello sir; I would like you to check the charge corona wire inside the drum cartridge or you just replace a new drum cartridge, before you change also check the discharge corona wire at the bottom inside the machine.
Sep 17, 2009 | Canon imageRUNNER 1310 Copier
Copier ha a message that says replace toner drum.
It means that the internal drum unit is full of waste toner and that the drum is worn out too. The people at cannon made the drum unit to last when the waste toner internal compartment is full.
When you buy a new drum the instructions are in the box and very easy to install.
hope it helps
Mar 24, 2009 | Canon ImageRUNNER 1670F Copier
Change drum in Cannon Imagerunner 1310 copier
first you should be a technical geek on mechanical, if I were you let the service men do their job, replacing a drum is cautious coz when you make scratch on it, kkaapppiiiisssshhhh! you are going to buy a new one
Jan 31, 2009 | Canon imageRUNNER 1310 Copier
Imagerunner 2016, waste toner full error message
hey, wel if the copier is showing a message saying that the waste toner is full it means the waste toner deposit is attached to the drum unit.
so, open up the frotn cover, pull down the (drum)-lock lever, it should release the left cover, then pull towards you the drum unit, and there you go.
the black case with a small trasparent cap is the waste toner deposit.
you have two ways to go.
1 you may remove that rounded transparent plastic cap and be able to vaccum the waste toner (dont even try reusing that toner, it wont work ok) or
2 you can go the other way wich allows you to easily vaccum it: remove the drum (the roller itself) then the charger roller, then the cleaning blade and there yo go again, but now you got more space to vaccum and believe me it is easier this way.
an additional choice would be to buy a new drum unit gpr18 i think (check please) and forget all about vaccum-ing.
Jan 23, 2009 | Canon imageRUNNER 2016 All-In-One Laser...
Paper jam
Hi usually paper jam at paper input area a or transfor section(photo drum area or fuser unit area, so you may try:
1) take out paper tray and open the cover that you can change toner cartridge there (see manual) looking for any paper inside paper input area or around the cartridge, then take out jam paper.
2) open fuser unit at paper output area ckick a locker at somewhere (see maanual) looking for any paper jam
Dec 22, 2008 | Canon imageRUNNER 1310 Printer
Imagerunner 1310 does not photocopy
Do you have toner/drum cartridge in machine installed?
May 14, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Canon imageRUNNER C3200 Copier Logo
1,431 people viewed this question
old marine
old marine
