Question about Samsung LN32A550 32 in. LCD TV
MY NEW SAMSUNG LN32A550 TV HAS A HUM FROM THE SPEAKERS
EVEN THOUGH THE SOUND IS TURNED DOWN ON THE REMOTE THE SPEAKERS HUM...I CAN'T FIGURE OUT WHY.
In most cases it's the Cable issue. Either bad Cable Box or the Wires are not grounded properly. Disconnect the Audio Cables or the COAX cable from the Cable Box and see if the Humming noise goes away.
Posted on Mar 13, 2009
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
How do i set up a new remote control for a samsung ht ws1 sound bar
2-Function Remote Stopped Controlling my Sound Bar - Verizon Forums
https://forums.verizon.com/t5/Fios...Remote...Sound-Bar/td.../559715
Apr 6, 2013 - It won't even control volume through the TV (Samsung). ... Did theremote ever turn on the sound bar, or have you been controlling ... Does the sound bar or TV have sound (sound but not volume control)? ... NO, UNFORTUNATELY THE FIOS REMOTE NEVER POWERED ON/OFF THE SOUNDBAR - I HAD ...
Your remote reprogramming woes solved - Rogers RedBoard
redboard.rogers.com/.../your-remote-reprogram...
Rogers CommunicationsJun 18, 2014 - Once the TV turns off, press the SETUP button once to lock the code.... the Rogers remote to turn TV on/off but can't get the remote to control volume. ...New Samsung smart TV and I have entered all the proper codes but the ..... Doesanyone have a code for volume control of Samsung Soundbar HW-J250.
Wireless Genie remote Doesn't turn on/off the soundbar - AT&T ..
Jan 08, 2016 | Samsung HT-WS1 Speaker System
For the first time since i bought my 37 inch 2
nadine2433, First thing to do is check your warranty status! Next thing will be research web for other owner's of same model or the 32' size for similar complaints. Try to find out the "root cause of failure" and see if something seems to "match-up" with your symptom. Yes, your cold-cathode-fluorescent-lamp back-lit lcd tv/monitor is no different than any other brand in it's basic design/operation than any other brand. Yes, plasma types are a little different, but not much. If problem gets worse and happens more frequently, the units internal "switch-mode-power-supply / ccfl inverter supply" would be first place I would investigate for a "thermally intermittant" (cold, frosty looking) solder joint on a active or passive electronic component where it is soldered to the printed circuit board. Nadine, your unit not much different than large screen computer monitor w/speakers, Just has a TV tuner circuit added to it and has remote control!!!! If this response was of some help please rate it on fixya. Do some reading in my fixya profile even though it deals mostly with black or blank n black ccfl back-lit monitors. There are hundreds of excellent ccfl back-lit monitor tech's here on fixya. 12fixlouie
Apr 19, 2010 | Samsung LN32A550 32 in. LCD TV
I have a plasma Samsung with picture but no sound
Internal sound board/amp is probably bad. But make sure that the speakers were not turned off in the sound settings menu for the television. You could try hooking up and external reciever to the audio output jacks of the TV and see if you get any audio from there. If you do at least you can still get sound from your tv...even though it is not from the internal speakers.
Sep 26, 2009 | Samsung LN-R328W 32 in. HD-Ready LCD...
Buy Samsung LN32A550 32 in. 1080p LCD HDTV Free shipping Order Today! [Click Here!] Samsung LE32B650T2 32-inch Widescreen Full HD 1080p Samsung LE32B650T2 32-inch Widescreen Full HD 1080p Save On "Buy...
SPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMSPAMv
Jul 02, 2009 | Samsung LN32A550 32 in. LCD TV
Mobile getting switched off often
ME too know
Save On "Buy Samsung LN32A550 32 in. 1080p LCD HDTV" You can Buy Samsung LN32A550 32 in. 1080p LCD HDTV In Stock. Low Prices Samsung LN32A550 32 in. 1080p LCD HDTV Shops & Purchase Online - Quick & Easy.
Discount "Buy Samsung LN32A550 32 in. 1080p LCD HDTV" Free Shipping & Pay No Sales Tax! You can Buy Samsung LN32A550 32 in. 1080p LCD HDTV In Stock Low Prices Samsung LN32A550 32 in. 1080p LCD HDTV Shops & Purchase Online - Quick & Easy.
Jul 02, 2009 | Nokia 6233 Cellular Phone
Samsung TSJ 2799 No sound
Check the audio menu and make sure it is in the stereo mode and that the alt sound is not on. some times the remote button gets pushed by mistake when turning it off. If everything in the menu looks ok it may be the cable converter box. If you can hear anything from the speakers the output is working. Try a DVD to see if you get sound from it.
Feb 27, 2009 | Samsung TSJ2799 27" TV
Samsung LN32A550 32-Inch 1080p LCD HDTV
Best Buy Samsung LN32A550 32 in. 1080p LCD HDTV Free shipping Order Today! [Click Here!]
Save On "Best Buy Samsung LN32A550 32 in. 1080p LCD HDTV" You can Buy Samsung LN32A550 32 in. 1080p LCD HDTV In Stock. Low Prices Samsung LN32A550 32 in. 1080p LCD HDTV Shops & Purchase Online - Quick & Easy.
Discount "Best Buy Samsung LN32A550 32 in. 1080p LCD HDTV" Free Shipping & Pay No Sales Tax! You can Buy Samsung LN32A550 32 in. 1080p LCD HDTV In Stock Low Prices Samsung LN32A550 32 in. 1080p LCD HDTV Shops & Purchase Online - Quick & Easy.
Dec 10, 2008 | Samsung TXJ2879 28" TV
Samsung LN32A550 32 in. LCD TV Logo
414 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
