Question about Xerox Office Equipment & Supplies
CLEAR J2 CODE
I am trying to clear the j2 code from my xerox 105F COPIER. I replaced the image drum and now need to clear the j2 code so I can use the copier. There is nothing in the user manual.
    President:
  • Xerox Master
  • 990 Answers
Hello sir; After replaced drum need to reset the counter,the procedure as follow;
1, press "clear", "Exposure","clear" "exposure" keys.
2, enter 24, press print key.
it should remove J2.
Posted on Jan 31, 2009
I needed a new drum (j2 error) so I bought one, installed it correctly, but the machine still shows the j2 error and will not clear itself or let me make copies. What can I do? I really need it to be...
Found old post for diffrent printer see if this info helps.
Drums may worj the same even though diffrent models.
Problem with the Xerox Printers Xerox XD130DF J2 error replace
By lgrey on Jun 20, 2008
Xerox XD130DF J2 error replace drum Best Solution posted 3 years ago
cbb7438.jpg rytech uk
  • Rank: Wiz computers_small.png
  • Rating: 80%, 98 Votes
Im presuming that your have replaced the drum??
if so :
Remove the new drum.
On the front of that drum, there is a green cover. Take it off and what has happened is the flag on the gear had dropped in shipping.
You will see a flag like piece of plastic on one of the gears, reset it to up and somewhat to the right.
Then put the green cover back on
That flag has to be in the up position when new. It passes down and actuates a drum reset switch on the machine.
When that is back in the up position. re insert the drum and on the first revolution it will turn on the switch.
Jul 06, 2011 | Xerox WorkCentre XL2140df Laser Printer
I have purchased a remanuf toner drum for my xerox xl 2130f copier and installed-- everything fit very well and seems to seat well/ only I still get a j2 signal upon the startup and I am lacking for...
Most likely the "remanufactured" cartridge does not have the counter reset flag in the proper position or is missing completely. Just reset the counter via the service mode by pressing these keys in sequence and as quickly as possible (within 4 seconds).
Press Clear, then exposure mode (far left key) the clear then exposure mode again. So in short form C, Far Left, C, Far Left. If done properly the display will go blank. Now key in 24 as if you wanted to make 24 copies. Now press the print button. Now enter 7 then press print again. You should now see flashing 000.
Press C a few times to exit and the drum light/J2 should now be gone.
Good Luck and Thank You for using Fixya.
WheatlandServices
Jan 31, 2011 | Xerox WorkCentre XL2130f Laser Printer
I have a Xerox XD125F Workcentre. The J2 toner
1. turn off XD125f
2. Turn on
3. within 4 seconds press, clear, auto, clear, auto. LED Should go blank,
if not try again
4. use copy quantity keys to enter 24, then push start
5. Again use copy quantity keys to enter 7, then push start
6. turn off
when you restart the cartridge count will be set to zero
I have done this twice and never replaced the drum cartridge.
Jul 24, 2009 | Xerox Office Equipment & Supplies
Xerox XD100 that is showing a code J2
No. The CRUM is integral to the Drum Cartridge. The only way would be to swap CRUM from a cartridge that failed for a reason other that it reached end of life.
Jul 02, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Shut down at 18,000 pages, J2 code
that is the exact life of a drum for that machine.
Feb 20, 2009 | Xerox WorkCentre XL2130f Laser Printer
Drum Cartridge XE Series P8 part number 13R553 Printer code J2
With "J2" flashing, press:
1. "CLEAR" button
2. "AUTO" button, then again
3. "CLEAR" button
4. "AUTO" button
Do it fairly quickly. If it's done quickly enough the display goes off. When it does:
5. enter "2" and "4" (see "24" on display)
6. Press "START/COPY"
7. Press "7"
8. Press "START/COPY"
DONE
If display doesn't go off repeat steps 1 to 4 but faster, until display is off.
Nov 07, 2008 | Office Equipment & Supplies
We have a xerox 2520, that has a J2 error code. We can't fix a service rep locally.
1. turn off XD125f
2. Turn on
if not try again
6. turn off
Sep 16, 2008 | Xerox Office Equipment & Supplies
Printer Stopped
J2 is the drum cartridge, or some people call it print cartridge has reached the end of its life.
J1 is the toner cartridge, J2 is the drum.
Jul 17, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
I need help with workcentre XD130df
J2 means the life of the drum has expired.
If replacing the drum does not fix it let me know.
J2 means the drum has met it's 18,000 page life.
Apr 04, 2008 | Xerox WorkCentre XD130DF Laser Printer
J2 Error ? Xerox Pro 215
J2 means your drum needs to be replaced. The life of the drum is expired.
Mar 13, 2008 | Xerox WorkCentre PRO-215 All-In-One Laser...
404 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
