Question about Kenmore Elite 45986 Front Load Washer
Washer will not go to the rinse cycel.
The Kenmore Elite washer that I have has three stock numbers they are 22052, 22054 and 22056.
This Kenmore washer has a touch pads and when I touch the select cycle for one of the eight configurations such as Heavy Duty, Ultra Hand wash, Normal, Express Wash Permanent Press, Whites whites, Handwash casual and Custom Set.
When I select the Heavy Duty cycle time goes all the way down to 23 minutes at that time it should go from the wash cycle to the rinse cycle but it will not shift to the next cycle.
  • 640 Answers
Check cold water line...onthejob,,,im assuming no rinse cycle only..onthejob,,,no mater the cycle
Posted on Feb 02, 2009
Washer stops after wash cycle, does not cool down and drain water. I turn the knob to rinse it starts up again but does not drain the water. Help
Can you provide the exact Make, Model and Kenmore model number? ..........
Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines.........
The model number on top load washers is usually found by lifting the lid and looking above the tub.
The Fixya numbers are Stock Numbers. Series numbers (70, 80, 90) only designate the number of "Bells and Whistles" that a washer has and don't reflect the model number.
See the following for where to find the model number:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=21&osCsid=c73289e58485c8752675ae1a35ff796b
Since basic top load direct drive, top load electronic and front load washers are very different, the actual Model Numbers are necessary to correctly diagnose the problem.
Jan 13, 2011 | Kenmore Washing Machines
I don't have a manuel
See the following Sears site for PDF versions of their manuals.
You'll have to select the right one for you washer since it appears that there are three different Model Numbers that use the same stock number.
http://www.managemylife.com/mmh/owner_manuals/search?query=45986
Jul 03, 2010 | Kenmore Elite 45986 Front Load Washer
Manual for kenmore elite 45986 front load washer
See the following site and select your actual model number:
The 45986 number is the stock number, not the model.
http://www.managemylife.com/mmh/owner_manuals/search?query=elite+45986
Apr 07, 2010 | Kenmore Elite 45986 Front Load Washer
Fills and Drain...
Check your washer drain line for a possible siphoning condition. The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Read through the link I provided. Your problem may be a simple matter of drain hose placement. If this does not solve your problem, please post back and let me know. I hope this helps you.
Jun 22, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore elite washer problem
sounds as if you have a drain issue, most common cause of fault is theres something stuck in the pump housing. remove the lower acess panel(3 screws along the bottom of the forn of unit) youll gain acess to the pump housing, remove the large cover to the "button trap" by uncscrewimg the cover, it will be righthin front of you in the center of machine when cover removed, im sure youll find your blockage within there
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
The washer stops after it fills with water?
You need a new SWITCH, LID 8318084 the bad lid switch is keeping your washer from sorking.. let me know if you want to repair it yourself.. let me know?
Aug 25, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore two speed automatic washer top[ load
Can only be blocked or a blocked air trap. Regards Engineer
Jun 19, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
315 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
