Question about Bernina Activa 140
Underthread Going Crazy
Hello, I've been having a recurring issue with my sewing machine. Every few pieces it decides that it wants to throw a tantrum. The upper threads will start skipping and suddenly the fabric is tugged. Upon pulling out the sewn fabric the usual result is a knotted mess of threads on the underside. Tugging on this thread mass usually loosens the whole piece and it comes undone. When it doesn't come undone the sewing is still weak and a horrid mess. I've tried what I think is adjusting the pressure and such, but I'm really just guessing here. Any tips? I'm in desperate need to get this sewing machine running asap. Thank you in advance.
  • peg1of5 Oct 29, 2008
    i have had my bernina 140 for 12 years and never a problem, now in the last week the tension has gone crazy and it squeeks like it needs oiled. even tho the manual says it does not need oiled. I have adjusted the tension every way i can think of. she sews a bit then jams, sews a bit then jams. i have probably gone through an entire spool of thread, rewinding bobbins, and cleaning out the feed dog and bobbins housing. help
  • Anonymous Feb 24, 2009
    Same problem- 3 years with 3 hours of work. It will sew fine for about 20 minutes then stops. the needle refuses to go up or down and when you cut the fabric off it have about 10 threads sticking out of the casing onto the plate!
    New Friend:
Our machine has done that since day one. So far nothing fixes it. What a piece of junk. I miss my singer machine. I'll never buy Bernina again.. disappointing garbage.
Posted on Feb 03, 2015
I am having the same problem, and i have tried all of those fixes, many, many times! did you find something else that worked?
Posted on Oct 24, 2008
    Novelist:
    Scholar:
  • 84 Answers
Hi PixelPup....Although I am unaware of what types of fabrics/needle size/project (ie does it have batting or metallic/special threads) your issue involves a fault located above your needle plate with 2 points of interest in particular. 1) Appropriate Needle Size, Type and Insertion. 2) Absence of upper tension. When replacing needles, ensure that the groove along the length of the needle is facing you. For every day medium weight cottons, a universal size 70 or 80 needle is fine. However, ALL OTHER fabrics, especially knits, denims, stretch and very lightweight or sheer fabrics should be sewn with the specified needle types. Your local sewing retailer can help you with exactness if you bring along a swatch/sample when you shop for your needles. Please purchase your sewing machine supplies from a sewing oriented retailer. Needles AND Thread quality matter a great deal in the quality and longevity of your stitches. As for needles, I recommend Schmetz, and Viking for threads. Keep in mind that needles to get dull, and can easily acquire brays which may not only cut your thread, but damage your fabrics as well, and should be changed "regularly". I would guess that misthreading accounts for 95% of all sewing machine problems including lockups, needle breakage, and instant jams. The dial for your upper tension may have a "colored zone" for the universal tensioning starting point usually between 3.5 & 5.5, with the lower number for lighter fabrics, and increasing with weight. If you don't have a colored zone, begin with #4. Completely remove the thread spool from your machine. Ensure that your presser foot is in the up position, and begin methodically threading your machine, paying special attention when you reach the tension area. There are usually 3 or 4 'plates' that provide the tension, and rushed threading by experts regularly causes the thread to miss the discs altogether. The presser foot must be in the raised position, which releases the pressure on the tension discs enabling your thread to slide in. Why not be proactive and remove and rethread your bobbin as well, ensuring that your bobbin thread receives tension from the flat spring on your bobbin case. Unless I have misunderstood your issue, your problems should now be solved......good luck my friend.
Posted on Aug 02, 2007
SOURCE:
Loose underthread and no zig zag
Lower thread tension can be adjusted by tightening (clockwise) the small screw in the bobbin case. The specifications call for 12-20 g resistance when pulling the thread slowly. I suggest tightening in increments of 1/8 turn and trying the machine each time. Also, mark the position of the screw in its original position should you need to return to the original setting and start over (use a piece of tape and place a mark where the slot in the screw is). I don't understand what you're saying about the zig zag problem.
Mar 12, 2014 | Husqvarna Sewing Machines
How to thread singer 57817
here is a link for a free manual, read the manual competely thru
first and then if the machine has been sitting up for years look in
the manual for oiling instructions and then oil where it shows
and then sew on a scrap piece of fabric but don't use any thread
so the oil can move thru the machine and loosen it up,,
try using a new needle--one that is right for the fabric you sew
http://www.singerco.com/uploads/download/118_356508008.pdf
Jan 25, 2013 | Sewing Machines
Problem with foot going over differing heights of fabric at seam joint and feed dogs barely gripping fabic enough
I've been sewing for over 30 years, if it were me & I bought a Bernina & that happened I'd take it back & find out why it happened.
I'd take a piece of the fabric & thread & let them sew it & see what happens.
a machine like that should sew so good, you'd be saying look what I sewed, instead of this can't be happening...
Mar 14, 2012 | Sewing Machines
When i thread the sewing machine and sew, the stitches do not stay
Possible
you need to change the needle, if it is a little broken at the head, it's not grabbing the underthread.
goog Luck
Jun 23, 2011 | Sew Smart Compact Cordless 17390B Sewing...
Motor is spinning- needle not going up and down.
Check that the inner part of the flywheel is tightened up. This has to be loosened when winding a bobbin for underthread. Easy to forget to re-tighten it for sewing.
Apr 14, 2010 | Kenmore Sewing Machines
The needle won't pick up the underthread... meaning it doen't mak
You may need to retime the machine, if you email me I can attach instructions. drivewithken@blueyonder.co.uk
Nov 05, 2009 | Singer Sewing Machines
BerninaMatic 910 Electronic machine. The foot control has broken
Bernina foot controls cost a fortune, have a look on ebay you find someone selling spares, other than that it will mean going to a Bernina dealer
Nov 03, 2009 | Bernina Sewing Machines
Small loops in the underthread
If the hook of the machine has a small burr on the point it can and will snag the upper thread and keep it from locking securely. The hook is what the bobbin case snaps on to. Take some light metal sanding material and polish the point to remove burr.
Jul 19, 2009 | White Sewing 1888 Mechanical Sewing...
Lost sparepart
It is called a bobbin case and most sewing dealers will have this one. It should be a standard case with a finger sticking up from the top. If you have metal bobbins they probably have a lot of holes in them.
sewman7
Mar 19, 2009 | Sewing Machines
Sewing Machines Logo
526 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
