Question about Netopia (3347NWG-ENT) Router (3347NWGENT)
Open NAT i tried 2 open my NAT by entering my email addreass in2 the url which is suppose to let u change the setting of your modem. the modem i have is bt home hub. i need it open to play xbox live. plz wb ty
    Scholar:
  • 30 Answers
To open NAT on this router your computer needs to have a static ip address.Enter the ip address of your router in the address bar of your browser. You should see a box prompting you for your username and password. Enter your username and password now.Click the Expert Mode link near the left side of the page.
Click the Yes, enter expert mode button near the center of the page.
The menu on the left should change. In this new menu, click Configure.
You should now see a new menu. In this new menu, click NAT.
Put a dot into the Port Forwarding: Range of Ports radio button.
Service name enter as Xboxlive.port 3074-3074 in global port range and 3074 in Base host port,click TCP as protocol,similarly use the same for UDP and port 88 in UDP.
Click the Enable button.
And that is it! You are done!
Posted on Apr 09, 2009
How do i change my nat to open
1 Make sure your ZyXEL Device hardware is properly connected (refer to the Quick StartGuide).
2 Prepare your computer/computer network to connect to the ZyXEL Device (refer to theQuick Start Guide).
3 Launch your web browser.
4 Type "192.168.1.1" as the URL.
5 A window displays
6 For administrator access enter the default admin password 1234 to configure the wizardsand the advanced features.(or if you already changed your password, enter that password)
7 On the right hand side of the screen you will see a drop down menu. click onNETWORK.
8 Then click on NAT.
You should be able to adjust your NAT settings from this page.
Sep 25, 2011 | Zyxel P660HW-D1 Router
How to change NAT status to open?
5 A window displays
7 On the right hand side of the screen you will see a drop down menu. click on NETWORK.
Sep 04, 2011 | Zyxel P660HW-D1 Router
How do I change my NAT settings on this modem
Your NAT settings have to do with your router, not the modem. Log into your router's control panel. This is normally done by typing 192.168.1.1. If that doesn't work, go to Start, type in cmd, hit Enter, then type in IPCONFIG. The Gateway Address is what you want to type into your Internet Browser. You will need to log into the router's Control Panel once you type this in. This is usually done by typing in "admin" as the username, or the password, or both.
This will be different depending on the manufacturer of your router, but once you log in, look for two advanced settings called NAT and UPNP. They should be near each other. You want to change NAT to Open.
If that doesn't work, go to http://www.portforward.com and check the port codes from the service you are trying to connect to. You can enter these codes into the Port Forwarding section of your router's control panel.
Hope this helps!
Feb 14, 2011 | Arris SURFboard® SB5101 Cable Modem
How do you bridge a modem ? i have a problem trying to change my nat 3 to nat 1. i have opened my router settings and reset my ps3 settings.i have been told that my problem can be fixed by bridging the...
Bridging the modem actually disables the dhcp server on your modem...
If you bridge the modem, then the dhcp will get disabled which in turn disables NAT on your modem...
If you contact your ISP they will help you to bridge the modem... because bridging varies according to the ISP...
Jan 23, 2011 | Arris High Speed DSL Modem
How do i change my nat type
go on a computer.
1. in the internet address bar type in 192.168.1.1 or routerlogin.net
2. enter admin and password in the fields
3. your now in your routers setup
4. find a setting called nat
5. set it to open instead of secure
this changes your nat type to 2
if that doesnt work
1. login to router as usual, but find a setting called default dmz server
2. enter the IP address of your PS3 as the dmz server (to see what your ps3's ip is go to network > connection settings and have a look.
this should definitley make it a nat 2 - but try the first method
Apr 27, 2010 | Sony Playstation 3 (PS3) Console
I am having trouble opening the NAT settings so i can play xbox live with this modem/router..I can log on to xbox but I can't play with some of my friends due to the modem/router settings.. When I go to...
The problem in this scenario is entirely not NAT issue . To overcome the issue open some of the port ports viz 80,3074 for tcp/udp on the router and enter the ip address on the router which is the ip you have for the x-box and then try the connection test.
Nov 18, 2009 | Computers & Internet
Change NAT to open
First make sure your security type on the router is WEP-Personal. You may need to get the port range for that game or manufacturer. Then enter them in to the gaming tab. This will keep ports open all the time. NAT 2 is acceptable but you want NAT 1. Some internet connections cannot get NAT1.reply if you need further assistance
Mar 13, 2009 | Dynex DX-E401 Router
Change NAT to open
You need to call xbox live tech support. From there they will give you a code. This code will need to be entered in the settings for you wireless interenet product under "Port range forwarding."
Dec 28, 2008 | Arris SURFboard SBG900 Wireless Router...
NAT
First question is do you know what NAT stands for? It is Network Address Translation. In simple terms, it assigns IP address to your network. Unless you've fooled around the settings should be unchanged.
For the simplest possible solution, try shutting down ALL the equipment. Then boot in this order: the cable/DSL modem, the router, the switch, the Xbox console. Give the modem and router plenty of time (30-40 seconds) before booting the next device.
Come back if this doesn't work.
Jeff
Jun 11, 2008 | Computers & Internet
Need to change NAT settings for xbox live
Hey, I've had the same problem too with my NAT but it said medium instead of restricted. I havent tried this yet cause I'm at work but you restart your router by just inpluggin the power cord and waiting 20 seconds than trying again.
Hope that works!
Nov 01, 2007 | Siemens SpeedStream Modem (4100) (SS4100)
Netopia (3347NWG-ENT) Router (3347NWGENT) Logo
197 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
