Question about HP PSC 2355 All-In-One InkJet Printer
Editing a scanned document
I need to know how to edit a document that i scanned on my hp2355. I need to and text and change some
    Brigadier General:
  • 6,966 Answers
Hi, You can try use an OCR program. Sometimes it is included/bundled in the software/drivers/application CD that came with your scanner. You can also google for freeware versions. OCR (Optical Character Recognition) will recognize the text from the scanned document, you can copy/paste and thereafter edit. Hope this be of some help to you. Pls post again how things turn up. Kind regards.
Posted on Jul 31, 2007
I have a problem after scanning, I cannot bring the document up in MS Word to edit. The document arrives on my computer screen but I can not edit it
You need OCR software installed in your PC
go to www.hp.com then type OCR application then download it in your pc
OCR Application File name: s.gif 23902_hpcom_OCR_120_003.exe [1/1, 54.84M]
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&dlc=en&lc=en&softwareitem=oj-72836-2&jumpid=reg_R1002_USEN
Text Cannot Be Edited After It Is Scanned to a Word Processing Program
Issue After scanning into a word-processing program, the text in the original is not editable. Workaround The process of changing text from an image to editable text is called optical character recognition (OCR). Text should automatically be converted in the OCR process when the Send To destination is a word-processing program. If it does not, check the items in the following list:
  • Select Editable Text as the image type in Scan Settings . In Windows XP, this setting is automatically selected if Scan Document is selected in the Director program.
  • Scan at a resolution of at least 300 dots per inch (dpi) for correct OCR conversion. Check the default resolutions in the Scan Settings on the Resolution tab.
  • If portions of the scan are cut off, turn off the Auto Crop feature in the Scan Settings on the Scanning tab by clicking to clear the check mark.
  • Tables, text boxes, and spreadsheets might not be editable. The border around them makes the OCR program read them as images. Readiris OCR, which is included with the HP Officejet G and K series, can recognize these images. Instead of selecting the word-processing program in the Send To list, send the scan to Readiris. Use the Table Drawing tool on the right side of the window to change the type of image to a table, and then use the OCR. The text inside of the box should now be editable.
    NOTE: Handwritten messages might not be captured by the OCR process.
Your's Truly,
Christian from HP
Say "Thanks" by clicking the thumb icon in the post that helped you.
Please click "YES" in solution that solves your problem as "was this helpful?"
(Although I am employed by HP, I am speaking for myself and not for HP)
Apr 10, 2011 | HP PSC 1315 All-In-One InkJet Printer
I have a hp 1310 AIO Printer how do you scan documents to computer using such programmes as ms word
MS Word cannot open scanned documents to edit. You need to run a scanned document through an OCR program (optical character recognition program) which converts the scanned document into a text document. Then you open Ms Word and import or open this text document to edit or change the text.
Nov 25, 2010 | HP Hewlett Packard LaserJet 3000dn Printer
Scan document into text
Scanned documents are image documents and they need to be converted using an OCR program. The Optical Character Recognition program converts scanned image documents into a text file which you can open with a Word program and edit.
You need OCR programs such as -
OmniPage 17
ReadSoft
GOCR (freeware)
Tesseract OCR (freeware)
Microsoft Office Document Imaging (included in MicroSoft office Tools)
May 11, 2010 | Epson ACULASER CX11NF All-In-One Printer
UNABLE TO MAKE CORRECTIONS TO DOCUMENT
Scanners put a graphic image on your computer that is a "picture" as far as the computer is concerned and therefore, you cannot edit text because it is seen as pixels and not characters. In order to make a scanned document editable, you'll need to use the OCR function in your software (Optical Character Recognition). This is assuming your printer came with OCR software, if not, you'll need to purchase an OCR software package in order to convert images into editable documents. You should be able to find such packages for less than $50.00. Check your documentation (and help files) and look for OCR in the index or search the help files for OCR to see if such software came with your printer software package.
Jan 30, 2010 | HP Photosmart C4240 All-In-One InkJet...
If I scan a blank application to be completed after its scanned in order to print the completed application, I can't find a way to add and or edit text on it.
if you scan a document it will be a photograph   editing a document is done in a text application like word or notepad   the two are completely different things   i use text bridge  or Paperport Professional  it will read the text off of the scanner bed and convert to a text document   it may make some errors but will still save much time rewriting the document  add the saved text to word and change the font and spacing to try to duplicate the original document  save it  then edit it to your hearts desire
Nov 06, 2009 | HP Compaq Presario SR1303wm PC Desktop
I am unable to edit documents that I have scanned. I have tried to download the OCR driver but I am still having a problem. Please help
If you are scanning text as an image, the image cannot be editred, because the computer doesn't know the image is text.
You have to scan with OCR to edit text.
You can use PaperPort to add text to scanned images
May 08, 2009 | Office Equipment & Supplies
Deleting words in Adobe 7.0 Professional
You can do that to some extent (if you do extensive editing, it can mess wit the layut of your document).
Go to Tools/Advanced Editing/TouchUp Text Tools. Select the text to delete and presse delete or type the new text.
If you are not able to select text, maybe your document was scanned as an image only. In that case, go to Documents/OCR Text Recognition and do a text recognition of the page or pages you want to edit or of your entire document. Then go through the steps stated above and tr again.
Hope this helps.
May 05, 2009 | Adobe Acrobat 7.0 Professional
Scanning a document to edit the text.
you need a program to recognize the characters in the image to be edited. try checking this list of OCR programs...but i think those are trial versions only.
http://www.bumpersoft.com/Graphics_and_Drawing/Scanning_and_Optical_Character_Recognition/
Feb 04, 2009 | HP PSC 1350 All-In-One Thermal Printer
Help with editing scanned document on microsoft word
you need to install a OCR software or an adobe photoshop software.
Jul 31, 2008 | HP PSC 1350 All-In-One Thermal Printer
Edit a scanned picture
Take it into photoshop cs3.Type the text over the scanned text that u want to erase.resize the typed text to match the scanned one.
2)make a layer copy of the background layer.Turn off the original background layer.then, create a layer mask for the copied layer.and paint black over the area u want to erase, with the layer mask active.
If u don't no photoshop OR in case, u couldn't figureout what i said,then mail me ur scanned image and the text file to damy.damy.bobo@gmail.com. i ll fix it and mail u back the edited copy.THANK YOU!!!
Jun 24, 2008 | Microsoft Computers & Internet
HP PSC 2355 All-In-One InkJet Printer Logo
80 people viewed this question
Clive
Clive
