Question about Sony CDX-CA400 CD Player
Memory hold on CDX-CA400 CD Player
I got this unit as a thank you gift for installing another unit for a friend. I connect the acc line to the yellow line on unit and I connect the constant 12v+ to the red line and the unit functions perfectly, but will not hold settings after being switched off. I connect ACC 12+ to red line and constant 12+ to Yellow and unit will not power up at all. I connect either source of 12+ to either line and leave the other line disconnected and unit wont power up. Both lines must be connected as in my first discription on the unit will not power on, but this leaves me unable to retain memory settings. I have no history on the unit so I am assuming perhaps it has been shorted at some time messing up the settings. I have tried resetting the unit hoping that would fix it, but no luck. Any other suggestions?
  • James Cheatwood Jul 31, 2007
    I had looked up the manuals for this unit on-line and recognize the correct wiring scheme, however it will not power on (so-far) in this configuration. I will try connecting it again putting 12+ constant on Yellow and swiched 12+ on red Thanks for your help.
    Thanks KaeZoo, I did indeed use my multimeter to verify 12+ voltage and also to test ground. I also tested each individual wire on the plug to see if they were grounded. I also am of the opinion that the unit is defective in this one area (mem hold) but as I only am interested in listening to my CD"s as I drive to work I can make myself satisfied with the unit as is. Be different if I had actually purchased the unit.But I don't look a gift horse over too closely.
  • 156 Answers
The correct wiring is constant power on the yellow wire, switched power on the red wire. I'm not certain why you weren't able to get it to work in this configuration; the unit needs power on both wires before it will turn on, but if you lose power on the yellow wire the settings will be lost.
Posted on Jul 31, 2007
  • Brian Neathery
    Brian Neathery Jul 31, 2007
    Just about any troubleshooting beyond the basic "looking at the wires" requires a digital multimeter (or at the very least, a test light). If you test and find voltage on both wires, and the unit still won't turn on (assuming the ground is good) then you have a defective player.
    If one of the wires has no voltage (with the key in the ON position) the most likely cause is a blown fuse in the vehicle's fuse box. All vehicles have at least two fuses that supply radio power: one for constant power and one for switched power. Often one isn't labeled as a radio fuse, and it's also common for one of the fuses to be located in an engine compartment fuse box.
SOURCE:
Which wires do I use for the acc/battery on Dodge Dakota for Radio
One wire stays hot all the time (yellow) and acc is only hot when the key is on. you should be able to find the wires in the original wire harness to the old radio with a test light or a meter.
Jun 09, 2012 | Sony Cdx-gt56ui In Dash Car Cd Player W...
I had the same problems as the first guy but never got another answer back. I hooked up my yellow wire to my 12v constant boat battery and I got power because I could put in a disc and take it out but the...
Hi:) The yellow goes directly to the battery posative and the red goes to the ACC on the KEY switch if the radio is not connected to the posative ACC wire on the Key switch you will have no Radio at all the yellow is just for the radio's Memory and the CD motor and eject.
Here is a install pdf. site for that radio. http://www.docs.sony.com/release/CDXM10_install.pdf
May 12, 2011 | Sony CDX-M10 Car CD/ MP3 Player
Im not sure about power wire red black ground and yellow not sure?
Connect black to earth or battery negative.
Connect red to battery positive or the acc lead from your ignition switch. If connected to acc the unit will power down when the vehicle is switched off. If connected to battery positive it will remain on irrespective of ignition switch position.
Connect yellow to battery positive for memory power. The moment this lead loses power all the settings/memory on the unit will be lost.
Leave a comment if you require further assistance
Dec 29, 2010 | Sony XPLOD CDX-GT200 CD Player
Sony CDX-CA400 FM/AM Compact Disc Player
The optic inside the CD player may be dirty or damp, this is the part that reads the data from the cd, you can try cd cleaning discs or you may have get an engineer to open it and clean it with an alcohol swab. The optic could also be faulty which will be cheaper to buy a new cd player.
Dan.
Dec 04, 2009 | Sony CDX-CA400 CD Player
Find remote wire connection for sony cdx ca400
Should be a blue wire with a white stripe in the plug that goes into your unit if its missing take the harness to bestbuy or an audio shop and they can prolly stick a wire in the empty spot. hope this helps you.
Sep 16, 2009 | Sony CDX-CA400 CD Player
Is there a way to connect my IPod directly to my after-market Sony CDX-CA400? If so, what part do I need?
if there is no i pod input on the unit you need to buy a fm modulator to do it
Jul 01, 2009 | Sony CDX-CA400 CD Player
Installing a CD player in '08 Aveo in plac eof stock AM/FM radio
You should check with Car Toys or Best Buy but you will probably need an adaptor and a wiring harness. If your doing it yourself your going to need to know how to get the stock radio out and the wiring diagram for the Aveo. Sometimes you can find the wiring diagram on Google by searching for it but usually finding diagrams for 2008 vehicles takes a year or two before it becomes available.
If your CD player has a tuner in it already you shouldn't need one. If it doesn't have one, that presents some other options.
Jun 22, 2008 | Sony CDX-CA400 CD Player
Memory
The problem is in the installation,you need to connect the YELLOW wire to constant power line,this is the wire it keeps the memory for you radio.
The RED wire is connected to the ignition key so when you remove the the key the radio shut off
Feb 10, 2008 | Sony CDX-GT410U CD Player
SONY EXCD-206 December 1996
I have the same radio, the radio's harrness has a red wire ignition 12 volt,yellow battery 12 volt, black ground, and a blue Iam not positive it can be the amp, or illumination.
Nov 18, 2007 | Sony CDX-CA400 CD Player
Sony CDX-CA400 CD Player Logo
172 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Dalynn Turner
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
