Question about Toshiba TDP-SC25U Multimedia Projector
Toshiba TDP SC25 projector
On my toshiba TDP - SC25 projector, when I turn on unit green lamp lite comes on (bulb does not come on, at least not very brite), and green fan lite comes on. You can also here a kind of whiring sound (but not the normal sound of the fan running) . Then the on button goes to red and temp and fan lite go on. Then temp lite goes out but fan lite starts blinking. Help!
  • 1 more comment
  • Anonymous Feb 10, 2009
    I have a very similar problem that has just occured over the weekend.
  • Anonymous Apr 07, 2009
    Mine makes a whistling sound and the light gets dimmer and brighter.
  • Laurie Ward Apr 07, 2009
    I just bought a new bulb and mine is doing the same thing but it's making a whistle sound. The bulb is installed correctly.
The manual says it might be because the power went out when it was on. Just a note here, as projectors age they become more sensitive to power outages. When not in use turn off completely if you can. They have an on/off button.
Otherwise not sure but think you may need to replace the fan. Try cleaning it first but gently.
Posted on Nov 12, 2009
Projector tdp s9 lamp indicator turns yellow light, even when new bulb is replaced correctly
Once you replace the lamp you need to go into settings and reset the bulb hours back to zero. That will take care of your problem
Feb 14, 2015 | Toshiba TDP-S9 Multimedia Projector
JUST PUT NEW BULB IN A TOSHIBA TDP-S20 ON 2/18/11 . BOUGHT PROJECTOR IN 2004 USED UNTIL THE BULB HRS RAN OUT . BULB NEVER BROKE / BURST. ON START UP WITH THE NEW BULB IN MACHINE BOTH FAN AND LAMP LIGHTS...
Your new bulb is not lighting.
Check the connections are correct.
Have you also tried putting back old bulb to see if it works.
Please dont forget to vote this answer was helpful
Many thanks
Feb 18, 2011 | Toshiba TDP-S20U Multimedia Projector
Replaced bulb in projector and it still doesn't
Smetimes the other fan comes on when set to full bright. As your lamp is not lighting up, the other fan will not come on. If yo have replaced the lamp and it is still not working, then 9 times out of 10 it is will be the ballast.
Jan 05, 2010 | Toshiba TDP P4 Multimedia Projector
My projector lamp turn on about 2 then turn off. light bulb haves
the power supply needs to be replaced. if you're good at soldering, there is a capacitor that dries up quickly on the ps board. i believe it's c2.
Nov 09, 2009 | Toshiba TDP-S8 Multimedia Projector
A new bulb has been fitted and the screen is now green?
reset the lamp timer and change the settings to factory default. let the lamp burn in a bit. if you still have a green problem, you'll need to replace the main board.
Nov 02, 2009 | Toshiba TDP-S8 Multimedia Projector
HOW TO RESET TOSHIBA TDP-S8 LAMP
after installing the new lamp, hold the volume top & bottom key simulteniously, when green light indicate at panel start the projector & go to service there you may found reset lamp ? press yes the lamp will reset.
Feb 01, 2009 | Toshiba TDP-S8 Multimedia Projector
Projecter not working
I have this same problem with no indication of what is wrong with the projector. I have checked the bulb and see no lines (veins) or bubbles on it.
Jul 20, 2008 | Toshiba TDP-S8 Multimedia Projector
Standby light for toshiba
probably power supply or ballast (starts the lamp)
either would be $600.00 or so to repair, probably costs more than the projector is worth.
Jul 15, 2008 | Toshiba TDP-S8 Multimedia Projector
Power Failure, How serious a problem and cost?
Hi there
You will either be replacing the Main Power Board or the Ballast Board ( Lamp's powersupply ) The symtoms you described sounds like a faulty Ballast.
Both of the above parts are fairly cheap to replace.
Mar 25, 2008 | Toshiba TDP-T30U Multimedia Projector
Toshiba TDP-SC25U Multimedia Projector Logo
243 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
pkwc
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
