Question about LG 30" Over the Range Microwave Hood with Glide & Cook Tray, LMV1645S
Over the range microwave
My micro works and does everything it is suppose to do but heat up. Next to the time it shows a "d" example- 7:15 d I can set the microwave to defrost etc but it just doesn't heat or cook. I am so lost without my microwave so please help!
  • maryadelaide May 20, 2008
    does not cook, heat or defrost
  • debhar Dec 15, 2008
    I have the same problem. The microwave appears to be working until you open the door and take out your food. It doesn't heat up at all.
  • LG Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fgsfj
Posted on Sep 30, 2010
Everything works but micro-wave does not heat up
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Jan 18, 2011 | Kitchen Ranges
Can't get the micro to heat,everything else works
I had a similar problem but with another brand (Panasonic) microwave. Everything seemed to work, but the food did not heat up. I finally figured out that the problem was caused by a faulty door switch. I went to the local appliance repair parts store and got a new one, which fixed the problem. I don't recall the price of the switch, but it was in the $10 range.
Jan 01, 2011 | GE Kitchen Ranges
Sharp Microwave diplay light not working
We regularly repair these display / control units nationwide by mail for $39.95 postpaid with a one year guarantee.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Jul 07, 2010 | Sharp Microwave Ovens
Doesn't heat anything
It sounds like the micro generator has died.
Yes, you should buy a new one as the cost of repair is likely to be high.
Jul 01, 2010 | Amana ACO1860 Microwave Oven
My Maytag microwave stopped heating. Everything
Generally the magnetron (the part that heats the food) is the cause if everything else still works. Unfortunately replacing the magnetron is barely cheaper than buying a new microwave though you can check out repairclinic.com to decide whether you want to attempt replacing the part.
Let me know how this works out for you.
Benjamin
May 24, 2010 | Maytag 2.0 Cu. Ft. Over-the-Range...
I have a 1993 GE spacemaker microwave/range hood combo. Everything works except that for most of the day it did not heat the food. The turntable still worked and the oven still appeared to be running. Then...
In short yes it can happen again.
Intermittent operation can be caused by a door interlock micro switch, a weak capacitor, an intermittent wiring connection from heat or poor connection, a marginally performing diode or a sticking Magnetron. Except for the Magnetron all other repairs would be worth the expense.
Repair costs and parts for most everything else will be between $65 and $100.00 depending on the part(s) replaced. Replacing the Magnetron would cost more than 50 % of the total unit replacement cost.
Jan 17, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave does not heat everything else works but does not heat
Same issues here, power up as usual, everything works except it doesn't heat. Usually when the magnetron kicks in, you know it because the unit bogs down from the load, well no bogging here just steady running of the fan. (Manufactured in 2007), do I detect a class action lawsuit in the works? I was fortunate enough to have purchased the extended warranty.
Repair man showed up day one with the most likely culprits (Magnetron & Diode), replaced them both and no help, there goes thanksgiving.
2 1/2 weeks later the tech showed up with a couple of (Micro Switches and a Thermostat), replaced those, ho help.
Now he suspects it the (PWB/PCB Power Control Board), because there isn't any power coming from the board to the tell the huge transformer to power up and sent the required voltage to the magnetron.
We will see when that is replaced if I'm back in business.
Just an FYI folks, if you're going to tinker with this use EXTREME CAUTION, as the transformer could put out upwards in the range of 4,000 volts, not to mention what the mag can do to you, so be SMART and be CAREFUL.
Comments: Dec 16, 2009 - Third time is a charm, the tech replaced the (PWB/PBC) today and we have a winner. That was the problem, either the Power Control Board itself or one of the relays on the board. Replacement was free because it was under extended warranty, but still reasonably affordable at repairclinic dot com ringing in at about $60. So good luck.
Oct 29, 2009 | LG LMV1630ST Microwave Oven
No heat micro keeps cycling through all programsdemo in cook/bx
My GE doesn't have a Demo mode but say we have a power failure. It won't let me use it until I set the clock.
Try that and see if it helps
May 26, 2009 | GE Profile Spacemaker Over-the-Range...
GE microwave not heating lights and keypad functional
You may have a fuse blown on the micro/ the vent and lights are a diffrent cercut , Try replaceing the fuse. its on the in side of the unit. if you need further assitance and you think you can do this I will be happy to instruct U DFD
Apr 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Kitchen Ranges Logo
177 people viewed this question
Top LG Kitchen Ranges Experts
Marvin
Marvin
Gene Pitts
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
