Question about GE AJCQ08ACB Air Conditioner
Ice or frost on the inside coils of the ac unit
I have cleaned my air filter and placed the temp higher on my ac, however, there is still frost or ice build up inside the ac. What else can be wrong?
  • karenlnelson Jun 24, 2008
    airconditioner is freezing up ..i have cut off the air conditioner and let it set ...have cleaned filter and i have only had it a couple of weeks ...it is tilled enough and have checked the drain plug
  • Anonymous Mar 18, 2014
    the outside unit is covered in ice all of a sudden. the unit is still running. I just changed the filter which was very dirty
    Novelist:
  • 75 Answers
Reduced or no airflow, Evaporator may be dirty. Low on freon.
Posted on Aug 01, 2007
Have haier HWRO5XCM air conditioner. Outside temp is 75 degrees and I have set on 76. Freezes up and spits ices and water. Help
Clean indoor filter , and coils in unit (you must remove from window and remove top from unit to expose coil, After cleaning coils prop up unit so it slopes to rear and spray back and forth at bottom of front coil until drain is clear . Never turn unit upside down , and do not get water inside of fan motor . Also clean evaporator blower wheel . With unit clean and drained out place in direct sunlight for at least 2 hours to completely dry before replacing top and reinstalling in window , or just drain out , reinstall and leave unit unplugged for at least 24 hours to dry before testing . If unit is clean and still icing , check to see if thermostat works (place object in front of unit to direct cold air from top of unit onto thermostat temperature sensor and compressor should cycle off, if not replace thermostat . If unit still ices you will need a pro to repair sealed system of unit or simply buy a new one .
Thanks,
Alex
Oct 03, 2014 | Heating & Cooling
My goldstar 6000 btu window ac is dripping into the house
Sounds like you're using it when the outside temp is cooler than the inside temp. when this happens, frost will build up on the condensor. Turn the unit off until the ice melts off with a shim under the unit tilting it back towards the outside of the window to drain. If it continues to drip after melting all the ice off and letting it dry out, you have a small leak in the condensor, (unit must be old or worn out) that the freon pressure has leaked out causing it to condensate more. A good checklist would be to check the level of the unit, make sure the coils are clean and not bent, the age of the unit and for small areas of corrosion or white marks on the condensor before replacing it.
Aug 28, 2011 | Goldstar KG6000R Window Air Conditioner
Ice is forming on coil fins
Either your coil is dirty or filter is dirty. Worst case your low on freon which would make a coil freeze.But freon doesn't evaporate if your low there must be a slow leak.
May 19, 2010 | LG Heat cool Window Air Conditioner
Just opened up the camper to find inside soaked on inside of unit
Check the condensate drain port for blockage and clear the blockage.
If the cover was on upside down, it is possible that it was impeding the air entering the coil.....this could have caused the coil to frost up....during your time to shut the unit off and inspect, the frost/ice started thawing and dripping into your trailer.
Here are the main items you want to address:
1. Ensure the drain is free and clear.
2. Ensure the air filter is clean and properly in place.
3. Ensure the evaporator coil is clean.
4. Ensure the covers are properly in place. ;-)
I hope you find this information to be very helpful to you moving forward. Let me know if you have any questions. Please don't forget to leave a rating for me. :-)
May 13, 2010 | Heating & Cooling
After 4-5 hrs of running it ice particals drop out of AC and fall out.
MAKE SURE THE FILTER IS CLEAN AND COLD COIL IS CLEAN . JUST REMEMBER 70 OUT SIDE AND 70 OR LOWER INSIDE AND YOU HAVE A ICE CONDITION. 75 INSIDE AND 75 OR HIGHER OUTSIDE KEEPS UNIT FROM ICING UP. IF ITS LOW ON FREON IT WILL ALSO ICE UP. MOST OF THE TIME THEY DONT LEAK FREON BECAUSE THEY ARE SEALED SYSTEMS
Apr 23, 2010 | LG Art Cool LA121CNP wall/window Air...
The unit forms ice and it does'nt blow cold
IF YOU CLEANED THE FILTER AND THERE IS NO DIRT ON COIL, YOU MAY BE RUNNING IT TO LOW FAN SPEED. REMMBER IF IT IS ABOUT 70  OR BELOW IN HOUSE YOU NEED MORE HEAT ACROSS COIL INSIDE , TURN AC TO HIGH SPEED AND ICE SHOULD MELT. IF IT DOSENT TURN T STAT TO HIGHER TEMP.
Apr 22, 2010 | Friedrich QuietMaster Deluxe RS12L10 Air...
The inside RUUD AC unit has ice and no cold air is blown
it is likely low on coolant or as some say "freon" that or the indoor fan motor has not run properly. let it thaw completely by shutting it off and just turning on your fan switch from auto to the on positon. if you begin to feel air flow eventually you need coolant added b/c you probably have a leak from the system being old
Sep 13, 2009 | Ruud UBHC Air Conditioner
Coils Ice Up and nothing is dehumidified
If the coil is clean, then have a tech check for a low charge. This will cause the coil to freeze up. Humidifers are known to lose gas and owners aren't told this so end up buying new one and scraping the old one. Trust me on this. I have seen this many times. I repair high end machinery as my business.
May 30, 2009 | Maytag M7DH65B2A Dehumidifier
GE AJCQ08ACB Air Conditioner Logo
291 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
