Hp laptop hey ma dvd-rom does not diaplys any drive...e-drive...wen i tried to troubleshoot it show error code 39 my laptop wont read disks either. i found a solution which involved removing the flters and it started working but within moments it stopped again. i now cant remove the filters coz they have been removed. HELP!
  • 3 Answers
Hi this is babu
U need install drives for dvd edrive
Posted on Jan 31, 2009
Dvd reading error
Try using a known-good (for instance, a movie you just watched on your TV). If it doesn't read that disc, make certain you have seated the disk in the drive properly (Laptop drives have a *CLICK!* when you have seated the disc properly). If that doesn't work- if the laptop is in warranty, get it fixed. If not, use an external drive to fulfill your media needs
Sep 22, 2012 | HP Pavilion dv6775us Notebook
Dvd+rw nd-2100ad no disk in drive error
Can you see DVD-RW drives indicator busy when you insert that disk for a long time? if so, your drive may not going to read that disk. If it is in case of CD disk, sometimes DVD-RW just can't read it while very old CD-ROM can read! If this happens in case of other CD/DVD witch is readable by other DVD-RW, You may just try to clean the lens of your drive.
Jun 29, 2012 | HP Pavilion a620n (PC028A) PC Desktop
My DVD rom drive wont work at all, in fact, only 1 disk was read properly while the others are dead, I tested each of mi disk in my dad's laptop then all of my disk works at the laptop, then I tested...
my pc did that recently, it would read the disk not all of it, so I went out & got a new drive & the new drive is reading everything
it's very possible the dvd drive is going out
Aug 26, 2011 | LG (DRD-8080BB) DVD Drive
MY , CD/DVD LAPTOP DRIVER DOESN'T WORK. IT CAN
goto run and type "compmgmt.msc"(without quotes) and select disc management if the dvd drive is showing below the hard disks means your dvd drive is working fine only thing you have to do is to right click on the CD-Rom 0 and change drive letter and paths to it
.if the CD ROM option is not seen in disk management then you have to go to the device manager option under computer management and expand cd/dvd -rom drives and you will find your dvd drive model if not that means that your dvd drive has got hardware problem
Aug 06, 2011 | Dell Computers & Internet
Hello felows ,, i have a XP lap top ,, my problem is that the cd drive reads dvd , cd -rom , audio cd ,, but when i put a dvd - raw , it wont read it ,, the cd is a hp deskjet 2050 j510 series to...
No all cds/dvd work in all cd/dvd drives. I suspect your drive cannot read that make of cd although anothers cd rom can. Try making a copy of the disk on someone elses pc and try that in yours and you will probably find it works. You could always copy the cd to a pen drive and install it on yours from that.
Jun 03, 2011 | Computers & Internet
Hi, my dvd-rom cannot read a blank dvd. it shows an error that is "windows cannot read from this disk. The disk might be corrupted, or it could be using a format that is not compatible with windows"....
What kind of DVD drive do you have? Look on the front of the drawer itself. If it says DVD-ROM, then you don't have the necessary hardware to burn something onto a blank DVD. If it says DVD-RW, then you should be able to. Also try: the same blank DVD in a known good DVD drive; other blank or commercial (movie) DVDs to see if your drive works with only certain things.
Mar 07, 2010 | HP Compaq Presario S4300NX (DF216A#ABA) PC...
My computer will not read any of my disk or install
when you say disk did you mean hard disk? if you do... did you recenlty install a new hard disks?... if you did... did you check the jumper-master-slave configuration when installing the new hard disk?
only one hard disk can be configured as master in each ide channel. set up to master (not single) the one on the end of the ide cable and set up to slave the one attached to the midlle of the ide cable.
check that both hard drives are properly attached to the cable and that the power cable is properly seated.
when you say disk did you mean cd rom disks or dvd disks?
does it work in other computers? if it doesnt.. you cd/dvd disks may be the problem
are you trying to read a dvd disk on a cd rom only drive... you can't read a dvd in a cd rom drive.
if you cd/dvd rom drive should read the disk you're putting in, check in device manager if your system detects the cd/dvd rom drive. if it doesn't: check the physical connections (reseat ide cable, check jumper configuration for slave and master on your cd/dvd rom drive and check that the power cable is properly seated), check also in device manager the properties of the cd/dvd rom drive and check if it says on device status if the device is working correctly. if it doesn't post the error code that it may give you or google a solution with error code.
suggestion.. be more specific when posting your questions.. that way it will be easier for a solution to be provided as your issue could be interpreted in different ways
Sep 24, 2008 | HP Computers & Internet
Computers & Internet Logo
103 people viewed this question
David Payne
David Payne
