Question about Dell Dimension 8200 PC Desktop
Dell 9150 9150 desktop....last time booted said raid failed...now won't even boot o/s...any help i cant make the computer to start and want to do the restore but it does not let me
  • Francisco A
    Francisco A May 11, 2010
    A problem with the raid drive is that it might have died. If this has happened I would suggest installing a new drive and install the old raid as a secondary and run a recovery program. Also if you wish take it to a computer store and see if they will be able to recover any needed files.
  • Peter Steiert
    Peter Steiert May 11, 2010
    Did you install a RAID setup on this system? If you did and it failed then you won't be able to get your data off your hard drive(s).
    Scholar:
  • 164 Answers
If it is ME or XP, tap the f8 key rapidly as you boot and it should go into safe mode. You can do a restore from there.
Posted on Feb 19, 2009
I entered my restore disk after receiving message on hard drive on the dimension 9150. Got message
Hmmm, what concerns me is that your system BIOS is not discovering any of your SATA Drives, That sounds like an Issue in your motherboard not your OS. I would go into your BIOS settings and look for a link that says reset bios to factory defaults, then try and boot again without the recovery disk. Please keep me posted on what happened if this does not we will trouble shoot more.
Sep 03, 2012 | Dell Dimension 9150 (DIM915MIN) PC Desktop
I have a problem with my dell dimesion 9150. It cannot boot up at all and the diag LED is showing 1.
Your Computer is not POSTing, I have created guides that deals with this very problem, go through them and get your computer going again.
Firstly
How to Remove the Side Panels of My Computer Chassis!!!
next up is
How do I reset my BIOS/CMOS to defaults?
lastly
My Computer is not turning on!!! Is it dead!!! No POST!!!
That should do the trick!
damnor01
Jan 27, 2011 | Dell Dimension 9150 (DIM915MIN) PC Desktop
I want to restore my dell dimension 9150 to factory settings can u help
If you were using Windows Xp just press Ctrl + F11 when you turn on your computer.
Press F8 if you were using Windows Vista then select repair your computer from the list.
Then if you have any disk or any Operating System disk insert the disk then boot from CD and follow the on screen instructions.
Hope it helps you....:)
Sep 06, 2010 | Dell Dimension 9150 (DIM915MIN) PC Desktop
RAID-1 failure on Dell Dimension 9100 Desktop
Since you are using RAID 1 (Mirroring) you will only need to send one drive for data recovery.
Since the Dimension 9100 uses SATA HDDs yes you can increase the storage capacity up to a matched pair of 650GB drives. I'd suggest you use the most current BIOS revision, but SATA controllers seem to be much more agreeable to large HDDs vs the EIDE ones before them.
RAID is redundancy, but it is not a data backup, as you have learned. Important data should be backed up to DVDs monthly/quarterly etc. and you can even do critical backups weekly.
Jan 06, 2010 | Dell Dimension 9100 PC Desktop
My Dell Dimension 9150 will not turn on
Use your CD to boot up the computer and recover your operating system
May 05, 2009 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Dell 9150
This system has onboard RAID, sometimes it is simply because the RAID controller is in error, to get it out of error:
* Disconnect the power cable
* Hold power button for 15 seconds
* Release the power button
* Plug in power cable
* Start the computer
If this does not work, please provide information, is is Windows XP or Vista?
Dec 01, 2008 | Dell Dimension 8200 PC Desktop
GX520 error
To resolve this issue, consider the following steps:
  1. Boot up the computer with a Microsoft Windows 98 boot up disk or Windows XP recovery console. Select the correct bootup device before you do that.
  2. At the DOS command prompt, type in: fdisk
  3. Now, you will be prompted with the following question
    • Do you wish to enlarge large disk support (Y/N) ?
  4. Enter: Y
  5. Now to check for active partition, enter: 2
    Look under the Status column. The active partition is usually assigned to the drive which contains your operating system.
  6. If there's no active partition set, enter the number of the partition to make active
    Restart your computer and the problem should be resolved.
I hope this is what you are lookin for..I am still tryin to build my profile so ratings especially the good ones really help
Aug 08, 2008 | Dell OptiPlex GX520 PC Desktop
When try to load windows it says cant find drive to load to
go to the f12 menu & then select the boot device as hard disk & chk if u r able to boot.....else try chking in system setup if the hard drive is getting detectd....
Jun 27, 2008 | Dell Dim.9150 Pentium D 820 Dual...
Raid failure
Not a lot of details, but here is some basic information, assuming you have a Dell with Integrated RAID
Dimension 9150/9200 and XPS systems have RAID, depending on the model the exact troubleshooting differs. At boot, after the Dell screen, you should get the RAID status listing. RAID 0 will either be normal or failed. Raid 1 can be normal, degraded for failed.
If the RAID array was RAID 0 and one of the drives failed, then all data is lost and you'll have to create a new array then reinstall Windows and drivers
If the RAID array was RAID 1, then you may need to add the new drive to the Array, CNTL+I or CNTL+N at boot (Depending on the system model) add the new drive to the array and reboot. If the system still will not boot to Windows, then you may have a software error too with the OS.
If during troubleshooting, the array was broken in the RAID BIOS, then the array will need to be recreated and Windows/Drivers reinstalled.
Jun 11, 2008 | Dell Dimension 2350 PC Desktop
Dell Dimension 8200 PC Desktop Logo
97 people viewed this question
Alun Cox
