Question about Goldstar DH304 Dehumidifier
Drain hose attachment
How to connect drain hose....lost my manual...tired of dumping all the time....
  • Anonymous Jul 07, 2008
    lost manual dont know how to install drain hose
  • Anonymous Aug 07, 2008
    want to hook up drain don't have instructions
Checkout this website...they have an owners manual you can download: http://us.lgservice.com/ A little hard to find, but it's there. In short, there is a small hole in the back of the dehumidifier between the cord handles. There will be a cap held in place over the hole by three small connectors. With some pliers, remove the hole cover. Take your hose connector and place it in the hole until it won't go any further (you can feel it hit the front of the water bucket). The instructions will show pressing the tab of your hose connector into the bottom of the hole to hold it in place. Don't know about yours, but mine is too long to do that. Connect a short length of garden hose to the threaded end of the connector and you've got it. Instructions say hose has to be flat leading straight from the dehumidifier to a drain, so don't place the draining end of the hose up in a sink or anything, use a floor drain. Hope this helps!
Posted on Aug 01, 2007
  • Phobrek Taz Nov 21, 2011
    I just bought one of these at a yard sale, and as you can imagine it didn't have the directions, but at least it still had the connector, which was a nice surprise.
    Thanks a ton for the instructions! Mine's now set up and hopefully making my basement less of a mold farm.
SOURCE:
I tried to drain direct via garden hose, perfectaire PA50 dehumidifier. I unplugged the plug, connected the little hose that came with the thing..connected to the inner spout and to the hose adaptor,...
Did you punch out (or cut) the plug that the hose connects to? If not, its blocking the water from draining to the hose.
Please rate 4 stars if this is helpful. Thanks and good luck!
Aug 15, 2017 | DeLonghi 50-Pint Electronic Control...
How do i make it continue to run with no bucket so it does not fill and and so i don't have to empty it
Attach a length of garden hose no longer than 5 feet, to the threaded drain hose connection that was supplied with your unit, to carry water to the drain.
1. Remove the drain-hole cover on the back left side of your unit.
2. Connect a garden hose to the threaded drain hose connector.
3. Push hose connector tightly to the drain-hole on Rear Grille with the arrow on the tab pointing UP.
The hose attachment will accept a standard garden hose fitting.
Do not over tighten the hose when connecting it to the hose connector,
use a rubber washer and tighten by hand firmly without stripping the
plastic threads.
When being attached to hose connector drain hose connection,
do not bend or kink the hose. The hose should lie flat from the
dehumidifier to the drain.
Jul 04, 2011 | LG LHD45EL Dehumidifier
I have a hamptom bay dehumidifer model # HB40-D i am looking for the tray that you attach a hose to drain
it should be in the same area where you pull the pan out to dump. There should be a hose hook up inside the space where the drain box is.
Apr 30, 2011 | Dehumidifiers
/my dehumidifier has a hose attachment on the back. how does that work?
The hose attachment is used in place of the water collection bucket, to drain the water directly into a floor drain or a sump pump holding tank. A garden hose is connected to the "hose attachment" and run to the floor drain or sump pump holding tank. However, it will not drain UP, only DOWN.
Hope this helped.
Mar 20, 2011 | Amana Dehumidifiers
How do I connect the hose? lost manual
If you asking about the drain hose. There's what looks like a hose hookup on the back of the unit, down near the floor. It's probably plastic and is threaded to accept a garden hose. You may have to carefully knock out the opening of the plastic connector, to allow the water to drain into the connected hose. The hose then should go to a floor drain or sump pump. Keep in mind, the water will not drain up.
Feb 08, 2011 | LG LHD65EBL Dehumidifier
I would like to SEE a picture of how to hook up a hose from the DH to a drain.( no manual & cant find one for this DH 304) TO lift the bucket off & drain has become to heavy for me. Thanks,...
My DH 304 is a hand-me-down so I don't have a manual but it did come with a hose attachment which is plastic tube with a threaded end to which you attach a hose. The other end of the tube goes through a hole in the back of the unit and then through a foam screen inside the unit to slip over the drain plug. Aligning the tube and the drain plug can be tricky; it is helpful to remove the bucket to see if you're getting the tube onto the drain plug. Once you have the tube attached to the drain plug, align the tube in the hole in the rear of the unit so that the tab on the tube is inserted into the slot at the hole in the back of the unit.
Aug 26, 2010 | Goldstar DH304 Dehumidifier
Have hose hooked up but it does not drain. Compartment fills with water and needs dumped manually. Want the hose to work so twice-a-day dumping in basement not needed. Thanks!
You connected a hose to the hose outlet on the catch tank ... right? The tank will not drain even though there are no kinks in the hose and the end is lower than the tank, right? Did you put a hole in the tank before you attached the hose? I will bet not ... and I will not laff at you ... I did the same.
Put a hole in the tank (where the hose attaches), reattach the hose and all will be well.
Thanks for your interest in FixYa.com :-)
Aug 09, 2010 | Soleus 30-Pint Dehumidifier
Can a hose be attached to the LG 45 dehumidifier to allow to drain as it fills?
Yes a hose can be connected to this unit.
1. Remove the drain-hole cover from the back of the unit.
2. Connect a garden hose to the threaded hose connector.
3. Push the hose connector tightly to the drain-hole on the back of the unit
This is explained on the manual on page 12. Hope this helps
Jul 29, 2010 | LG DH404E Dehumidifier
Dehumidifier
As for the drain most have a plastic pan and this is sometimes the type that has to be removed and dumped or a hose has to be attached and the hole it attaches to has to be cut out for self draining.
If the threads are fouled up all I can suggest is a lot of Teflon tape or pipe dope or cut out and replace the fitting with something that will correct the problem.
If this helps please rate me as high as you can and thank ytouu for using fixya.
Aug 26, 2008 | LG LHD65EBL Dehumidifier
Haier 30 pint dehumidifier continuous drain problem.
Many just attach the hose at the reservoir; from your description, Haier apparently has a separate location. Check that the point that the hose attaches has an opening (many don't, they expect you to drill it). It should then drain through gravity. Check to make sure that no part of the drain hose is higher than the bottom of the reservoir, otherwise it can't drain. It won't siphon because each time the the tank empties, the suction is broken and the siphoning can't continue.
Aug 24, 2008 | Haier Dehumidifiers
Goldstar DH304 Dehumidifier Logo
1,409 people viewed this question
Top Goldstar Dehumidifiers Experts
Gil Shultz
Paul
Paul
Michael Youngman
Michael Youngman
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
