Question about Bose Lifestyle 48 System
Failed 802 call Bose message on a 3 2 1 system
Lost all the stored music.
5 Suggested Answers
  • 14 Answers
SOURCE: storing music in BOSE 38 system
The Bose uMusic system is a very powerful music management tool. The uMusic storage process involves pulling information from your CD (approximately 3-5 minutes per CD) then storing this information into a buffer area for processing. The buffer area will hold approximately 10 CDs worth of data. After the buffer is full, it must stop taking new data and process the data already in the buffer. The processing time is about 30 minutes per CD.
This means 5 - 6 hous of processing per 10 CDs. So be patient. This is not unusual. Other "media servers" such at Escient and Audio Request take 24 - 48 hours to process a full buffer. There is a lot of data processing going on during this time period and the result is amazing music management once completed.
I recommend clients load 10 CDs in the morning and let it process till after lunch. Then another 10 CDs and let it process until after dinner. Then another 10 CDs and let it process overnight. This routine completes 30 CDs per day.
If you have 100 to 400 CDs an automated services is available from HouseSys.com. This is the only automated service available for this system.
Posted on Feb 03, 2008
SOURCE: life style error codes 801 & 802
Unfortunately my Lifestyle is dead after getting these errors!
Bose will fix it - replace it if necessary - but at a cost!!!
Posted on Mar 18, 2008
cjackHD
  • 71 Answers
SOURCE: bose lifestyle fault code 802
Unfortunately, an 802 error is bad. That means hard drive (HDD) failure. This can happen to any hard disc drive, and there's no way to predict it and no way to fix it from home.
If you even try to troubleshoot it (reset etc), you could loose more data (music you've already stored to the system). If you try to access 'stored' music- the error will continue. Also, every time you turn the system off, it checks your HDD, and will probably cause the 802 or 801 errors to display again.
The "Format Unsupported" message may be related, but usually temporary. The 802 (and also 801) errors mean irreversible HDD damage so it doesn't matter.
Call Bose tech support immediately.. They can repair it for $165 and give a new 1 year warranty. And if it's already under warranty they will repair for free. In either case they will replace your HDD with a new one, and transfer any salvaged music files from your existing drive to the new drive.
Posted on May 31, 2009
  • 10 Answers
SOURCE: Same problem LS 38< two years, error 802, unplug and erase umusic
Sounds like hard drive is failing, 802 and 801 is hard drive problem. i have same problem. only fixable by bose repair man... tryed to change hard drive myself, changed over, looks same as playing but no sound. hope this helps:) common problem with bose other than that i have had not other probs.
Posted on Aug 20, 2009
drifterK
  • 4924 Answers
SOURCE: Bose LS 48 .Get failed
those are hard disk related errors..and probably will need a hard disk format action ...If you do not store any files on it is better cause the action will wipe out the hdd..
if after formatting it it will still make the same it is a physical issue and you will need to have it sent to be checked by professionals.
Posted on Jan 04, 2011
How do I store music in my Bose system
You insert the CD into the console and pushe the "store" button on the face of the system. You will then see the message accessing gracenotes and the % complete. Once this % has reached 100% the music is stored in the system. Hope this helps
Nov 20, 2011 | Bose Lifestyle 48 System
FAILED 802 CALL BOSSE
I have the same problem since the Earthquake in Christchurch NZ.. Called Bose support centre and it seems the hard drive has failed and will need replacing, so all stored music etc lost. Cost to fix is roughly the same as getting a new media centre (DVD/CD) component. We are getting a new one through our insurance, apparently Bose Lifestyle's do not like being shaken around a lot or dropped.
Normally accompanied by a screetching sort of sound when you try to access stored music or turn the unit off.
May 08, 2011 | Bose Lifestyle 48 System
When trying to store cd's....get the message Failed 801 call bose. Also I have lost all that i did have stored.
get your money back.
there are better products out there.
you'll have extra money in your pocket.
Feb 27, 2011 | Bose Lifestyle 38 System
Jul 10, 2009 | Bose Lifestyle 48 System
Bose lifestyle fault code 802 hi there- i have a bose lifestyle 48 and on display it reads format unsupported when i try to listen to cd's gut not on dvd's - in addition i am unable to store music into the...
May 31, 2009 | Bose Lifestyle 48 System
Bose Lifestyle sound system shows "Failed 801"
your hard drive is about to fail or has failed.
If you can still play music from stored area and If you want to keep your songs thats stored on system, turn off at power point and take to bose auth repairer, they should be able to transfer songs across to new hard drive.
I have same problem, this is a common problem with bose.... not good for how much they are. Hard drive is left of cd tray, on its side.
hope this helps :)
Mar 29, 2009 | Bose Lifestyle 38 DVD Home Entertainment...
Here's what the Bose support website suggests.  Good Luck!
Messages displayed during a Music Information Update
Messages may appear on your media center display during a Music Information Update. If you see a message with instructions to call Bose, and a three-digit code such as "Error Code 802" or "Failed 172" while performing a Music Information Update, it does not necessarily mean there's something wrong with the system. Performing a media center reset and installing the update again may address the issue.
To reset your media center, follow these steps:
  1. Turn the media center off. Wait two minutes
  2. Unplug the power cord from the media center. Wait 30 seconds
  3. Reconnect the power cord
  4. Wait until "Bose Lifestyle" disappears from the screen
Note: After a reset, you will need to wait several minutes before playing stored music (3 to 20 minutes, depending on how many CDs have been stored). All other sources will be available immediately after the system powers up.
If you have any additional questions about these messages, please contactBose® Technical Support or call 1-800-278-1281.
Dec 01, 2008 | Audio Players & Recorders
Life style error codes 801 & 802
Hi, I had the same problem, they had to replace my harddrive and the dvd, lost all my music, 145 cds, just got it back, it now works fine,
good luck
jps
Dec 31, 2007 | Bose Lifestyle 38 DVD Home Entertainment...
When being in contact with BOSE support i got the message that "FAILED 802 Call Bose" refers to issues with the harddisk not being identified.
In my case I had to send the unit to BOSE support. I replaced the existing disk with an identical unformated one but some more actions are needed. The question is what .......
Nov 18, 2007 | Bose Lifestyle 48 System
Bose Lifestyle 48 System Logo
457 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
