Question about AMD eMachines Desktop System w/ 17'' CRT Display, 2.0 GHz Athlon 64 3000+ (W3400)
EMachines Recovery Discs
I have followed the instructions regarding the use of the recovery discs that came w/ my pc.When the system tries to reboot, an error appears that a problem has been detected and Windows had to shut down. Please check any newly installed hardware or software and run CHKDSK /F. I have tried a million different ways but cannot keep from getting this error. I cannot get into DOS to run the check disc, cannot get Windows to reboot at all. Also, the recovery process only takes about 15 minutes, so I've done it 3 times now.
    Brigadier General:
  • 6,966 Answers
Hi Sandysue, As I understand your problem, 1. The error could be caused by: memory, video, hardrive or drivers; 2. Windows by asking you to run CHKDSK /F has detected a possible problem with your harddrive; 3. It is possible that the reason you cannot go to DOS mode is because your harddrive is formatted in NTFS and not FAT332. There are a couple of ways on how to go about this but all would require that you have access to second PC: 1. Run a third party software (BartPE) that you will have to boot from your CD Drive or USB and run a disk checking utility; 2. Remove your hardrive and install it as a secondary master in the 2nd PC and run chkdsk or scandisk; 3. Remove your hardrive and install it in an external HD enclosure and connect using USB to the 2nd PC and run chkdsk or scandisk; 4. Remove your hardrive and install it either USB or as secondary master to the 2nd PC. Copy all your important files to the 2nd PC, and repartition/reformat. Reinstall to the eMachine and reinstall Windows. There is a possibility that even if you were able to run CHKDSK or Scandisk eventually your best bet would still be #4. If you have gained access to the inside of your eMachine PC, it would also be a good idea to remove/reinsert any cards and the memory stick(s). A little housekeeping would also be nice. I hope that this be of some help and pls post again how things turn up or if you need further information. Goodluck and kind regards.
Posted on Jul 31, 2007
SOURCE:
Trying to restore back to factory settings
System Recovery
When you've tried other methods of repairing your
system software (like System Restore or Application
Recovery), you may want to use the Compaq System
Recovery program as a last resort to reinstall the software.
When necessary, you can reinstall the operating system and
the application software that was originally installed on the
PC at the factory by using the System Recovery program.
WARNING: The Compaq System Recovery
program will delete any data or programs
that you installed after purchase. Be sure to
back up any data that you want to keep onto
a removable disc.
The System Recovery program uses a special recovery
partition on the hard disk drive that stores an image of the
original software.
NOTE: The System Recovery image is in a partition area
of the hard disk drive and takes up part of the total drive
space. This disk space is not usually available for your use.
In the unlikely event that you replace the hard disk drive,
or somehow damage the data in the special recovery
partition on the hard disk drive, use recovery discs to
reinstall the operating system and software on the hard disk
drive. See "System Recovery Using Recovery Discs."
Make your own recovery discs (CDs or DVDs) before you
need them; see "Creating Recovery CDs/DVDs." You can
also make the Recovery Tools CD. This CD contains utilities
that allow you to make changes to your hard disk drive; see
"Using the Recovery Tools CD."
Starting System Recovery
if the PC Is Responding
1 Turn off the PC. Disconnect all peripheral devices from
the PC except the monitor, the keyboard, and the mouse.
Turn on the PC.
2 Click Start on the taskbar, choose All Programs,
choose PC Help & Tools, and then click Compaq
System Recovery.
3 Wait until the System Recovery window appears asking
Do you really want to start System Recovery?
4 Click Yes to continue with the recovery process. If you
created recovery discs, you may be directed to insert
recovery disc #1. If the Recovery disc is a DVD, be sure
to put the disc in a DVD drive.
5 The PC starts the recovery; wait for the onscreen
instructions to display, and then follow those instructions.
6 Complete the PC startup, finish the registration process,
and wait until you see the desktop. Then, turn off the PC,
reconnect all peripheral devices, and then turn on the PC.
Starting System Recovery if the PC
Is Not Responding
1 Turn off the PC. If necessary, press and hold the On
button until the PC turns off.
2 Disconnect all peripheral devices from the PC except the
3 Press the On button to turn on the PC.
4 During the startup, do the following to enter the System
Recovery program:
When the black screen with the Compaq logo appears,
press the F10 key on the keyboard. (You have only a few
seconds to press the F10 key before the normal startup
process continues.)
reconnect all peripheral devices, and turn on the PC.
Oct 05, 2013 | HP Compaq Presario SR1115CL PC Desktop
EMachine EL1850-01e
It looks like you'll have to either return it or perform a default factory recovery. These instructions are from their site but proceed knowing that this will erase any data that is stored on the primary partition (meaning if you have anything on it, it's gone...). Esentially it resets it to a point as if you just picked it up in the store (which you did.. :( )
How can I restore my computer with the backup discs I created?
With user created backups you are able to restore your computer to the factory default settings. If backup discs were created instead of factory restore discs, these can be used instead and will restore the system to a user backup point.
    If you have a recovery disk:
    1. Ensure that the computer is completely shutdown, then turn on the computer.
    2. When the eMachines splash screen appears, tap the Alt and F10 keys simultaneously. A screen stating "Starting eMachines eRecovery" should appear.
    3. From the recovery options, choose Restore system from CD/DVD.
    4. Insert either the first Recovery or Backup disc that you created.
    5. From the on-screen options, choose a backup.
    6. Click OK and the installation will begin.
    7. Change the disc as necessary when prompted.
      If you do not have a recovery disk:
    8. Restart the computer.
    9. When the eMachines logo appears on the screen, press the Alt and F10 keys repeatedly.
    10. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
    11. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Dec 13, 2011 | E-Machines eMachines Desktop PC
How do you restore a emachines el1200 desk top to factory settings
[1]
reinstalling the operating system If you can run Windows...1 Click (Start), All Programs, eMachines, then click eMachines Recovery Management. eMachines Recovery Management opens. 2 Click the Restore tab, then click Restore system to factory default. The Confirm Restoration dialog box opens. 3 Follow the on-screen instructions to finish.
[2]
If you cannot run Windows...1 Restart your computer, then press the ALT+F10 keys during startup. 2 Follow the on-screen instructions to finish. IMPORTANT • • If your hard drive has failed and you can't restore the software from the hard drive or recovery discs, contact eMachines Customer Care for help. After you restore your computer, it will appear with the same files and programs it had when it shipped from the factory. You still need to download Windows updates and antivirus updates to bring your computer's software up to date.
Aug 27, 2011 | E-Machines eMachines Desktop PC
I need to press a key on my keyboard to start factory recovery
Hi and welcome to Fixya!
In order to revert the machine back to its factory setting, you need to have the recovery disk (if you don't have it, call the warranty support line of e-machines so they can provide it to you).
To restore Windows from your recovery discs, you will need to
insert the first backup disc and enable the F12 Boot Menu via the BIOS Setup
Utility.
1 Turn on your computer and insert the first system recovery disc into the
optical disc drive. Restart your computer.
2 During startup when the eMachines logo shows, press the F2 key to enter
BIOS Setup, where you can set system parameters.
3 Use the left and right arrow keys to select the Main submenu.
4 Use the up and down arrow keys to select F12 Boot Menu.
5 Use the F5 or F6 key to change F12 Boot Menu to Enabled.
6 Press the ESC key to enter the Exit submenu, press the ENTER key to Exit
Saving Changes. Press the ENTER key again to select Yes. The system will
reboot.
7 After rebooting, when the eMachines logo shows, press the F12 key to
open the Boot Menu. Here you can select which device to boot from.
8 Use the arrow keys to select the IDE1*, then press the ENTER key. Windows
will be installed from the recovery disc.
9 Insert the second recovery disc when prompted, then follow the onscreen
prompts to complete the restore.
10 Remove the recovery disc from the optical drive once the restore is
complete. Do this before rebooting your computer.
Hope this helps!
Takasashi
Jul 25, 2011 | eMachines E620-5885 Notebook
I was trying to create the Recovery Management disk but everytime I try to burn the CD it keeps ejecting. I would really like it if you could provide some help. I recently bought this E-Machine computer...
Welcome to Fixya
Please see procedure below on how to create recovery disk. Let me know if smae thing will happen.
  • 1
    Click the "Start" icon on the Windows Vista home screen. Select "eMachines," then click "eMachines Recovery Management." The eMachines Recovery Management program opens.
  • 2
    Click "Create Factory Default Disc." The program will tell you how many discs you will need. Make sure the correct optical drive is selected, then insert a blank disc into that drive. Click "Start" to begin the burning process.
  • 3
    Remove the disc when it is finished burning and label it "Recovery CD 1." Insert the next the next blank disc if one is required. Click "OK" to begin burning the next disc. Repeat this step until all of the discs have been created and labeled. Close the eMachines Recovery Management program, insert the system CD that came with the laptop and restart the laptop.
  • 4
    Press "F12" repeatedly when the eMachines logo is displayed on the screen to be redirected to the Boot menu. Select the optical drive, then press "Enter."
  • 5
    Insert Recovery CD 1 when you are prompted to insert the recovery disc. The eMachines Recovery Management program will open.
  • 6
    Click the "Restore" tab in the list on the left side of the eMachines Recovery Management program window, then select "Completely Restore System to Factory Defaults." The computer automatically restarts and the recovery process begins. Insert any additional recovery discs as requested. The computer will reboot automatically when the laptop has been recovered to its original factory default settings, and you will be taken to the Windows Setup screen.
  • 7
    Set up Windows Vista with your own personal settings.
  • Thank you for using Fixya!
    If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
    Dec 04, 2010 | E-Machines emachines (emachinees) CD-ROM...
    How do i restore my emachines to factory settings without a disc?
    How to Reboot an eMachines PC
    If you are able to load windows:-
    Note:Before performing system recovery try to back up the important data like pictures and files.
    Instructions
    Step 1
    Click the "Start" button on the Windows desktop. Check through the program list and hit the "Recovery Management" option
    or
    Click the "Start" button on the Windows desktop>>go to All programs>>Emachines>>Emachines Empowering technology>>Click on "Recovery Management/ & follow the onscreen instructions Click on Restore>>select factory default settings>>click on yes to follow the warning instructions
    It will take 10 to 15 minutes to compleate the process
    If you are unable to load windows
    1)Turn off the computer/unplug all the external devices like Printers/Scanners/USB devices/Webcams etc...
    The moment when you turn on the computer try to hit F11 on the keyboard>>it will give you the options just follow the onscreen instructions.
    If F11 doesn't work try with Alt+F10
    Aug 14, 2010 | E-Machines (T2958) PC Desktop
    Pc to slow
    for this you need a system recovery discs or boot discs just insert them and follow the instructions
    Apr 19, 2010 | E-Machines eMachines Desktop PC
    Can't use the recovery discs for emachines e420
    Sometimes the USB keyboards can take a few minutes to be recognized by the OS. Try and wait about 5 minutes after it gets to this screen before trying to type.
    Apr 02, 2009 | E-Machines eMachines Desktop PC
    Accessing EMachines W3107 Recovery Partion
    You can fix this virus without recovering.
    Log in normally. Go to run, type in msconfig and go to the startup tab. Uncheck everything and reboot your pc. Once there try your internet. If it's not working go to Internet Options, Connections, Lan Settings, and uncheck anything in your proxy settings. Close IE and reopen. You should be able to connect. Then download and run Malwarebytes, and then run Bitdefender Online scanner.
    The only other thing that may be trouble is that there may be a rootkit that neither scanner will detect. You can run Combofix, but this program isn't for the average user. Follow instructions carefully when using Combofix.
    Mar 23, 2009 | E-Machines eMachines Desktop PC
    AMD eMachines Desktop System w/ 17'' CRT Display, 2.0 GHz Athlon 64 3000+ (W3400) Logo
    110 people viewed this question
    Top AMD Computers & Internet Experts
    Ekse
    Alun Cox
    Carlo Barzo
    Carlo Barzo
    Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
