Question about Kitchen Ranges
Door switch turns oven convection fan ''off'' when door closed
And vice versa....it turns convection fan ''on'' when door is opened. I attempted to reverse the two connection wires to the door switch (one red and one black), but same result no matter how the two wires are connected. I also have to open the door slightly in order to get the self-cleaning door lock to engage. Seems like some wire must be reversed in the electric control panel or the door switch that a repair person recently replaced is not compatible with this KitchenAid range, KitchenAid Model KERC507YAL0?
  • tsbiz Jan 31, 2009
    It's a new switch. Before this switch was installed, the convection fan or self-cleaning oven would not engage at all.
    The wire connection appears intact and the switch is clearly communicating effectively to the control panel; it just tells it just the opposite of what it should be telling the control panel as to when the door is open or closed. The control panel seems to think the door is open when it is closed and thinks the door is closed when it is in fact open. Please be specific.
  • 19,396 Answers
That means that there is a contact on the door switch wirings, you need to replace the wiring harness connecting to the door switch.
Click here and enter model number to find all replacement parts for your model
Posted on Feb 02, 2009
  • 350 Answers
Dear FixYa Customer,
First and Always go to the Manufacturer for Parts Compatibility and/or Service!
For a GREAT APPLIANCE PARTS WEB SITE click on the http:// link that follows below but be sure to read this entire message first!
Same-Day Shipping, Return Any Part
Save When You Do Repairs Yourself @
http://www.partselect.com/Entry.aspx?Appliance=Range&Source=GAWS&Term=Range+Part
Remember DO NOT TO CLOSE the Parts Web Site by clicking 'X' at the top of your screen! Use the ARROW AT THE TOP OF YOUR SCREEN TO COME BACK HERE to rate us or for more help!
jackiaria
This Should FixYa Fast!!!! Please Rate Me!!!!
Posted on Jan 31, 2009
    Genius:
  • 1,199 Answers
You will need to replace relay that controls the door function! This is the only way to fix this problem!
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
How the wires on the door switch are connected would not make any difference since the function of the switch is to simply engage/join the two. I am inclined to think that what you posted is correct. The wires to the fan were fired wrong. In most units, the electronic control panel uses relays to actually do the switching of the fan. In the relay, there would be 2 pins, normally close and normally open. All that has to be done is to determine this single wire from the fan (the other would go to a common point), disconnect from its current position and connect to the other pin of the relay. Both pins would be near each other.
Pls postback result(s). Good luck and thank you for using FixYa.
    Sergeant:
  • 250 Answers
Its the wirings which r getting cut internallt needs to be replaced.
just check out with a continuity machine.
    Sergeant:
  • 221 Answers
Replace the wire connected to switch may be its shorted or cut or mistracking somewhere
    Sergeant:
  • 326 Answers
It can be possible that the door switch is faulty and needs replacement.
How do i make my convection fan turn off when i open the oven door
It sounds like there should be a switch on the door and it is malfunctioning. I would contact the manufacturer as it should be covered under warranty if it is malfunctioning. Especially for a $10,000 oven.
Dec 03, 2014 | Thermador Ovens
Our electric convection oven heats up and when you open the door and close again it no longer heats, fan stays on and the light goes on when door open and off when door is closed, any ideas?? Thanks
Hi, You can look at the micro switch on the oven door, sounds like it might have been installed on a normally open auxiliary rather than a normally closed aux. hope this helps
Oct 09, 2014 | Ovens
Jvm1790sk fan comes on when i OPEN the door
Pretty sure its the door interlock switches.
you might need a service call from the authorized rep.... sorry.
Oct 14, 2013 | GE JVM1790SK Convection/Microwave Oven
Jenn-air micro convection - cooling fan comes on when door is opened, then goes off, intermintent problem
I have seen where one of the door switches becomes intermittent causing the symptoms you are describing, tough to nail down considering there are more than one door switches.
Jun 16, 2012 | Jenn-Air JMV9169B Convection/Microwave...
Sharp 930 AK Convection/Microwave Oven
When you close the oven door the latches operate a couple of interlock switches that control power. It may be that one of the door switches is bad or out of adjustment. It's also possible that one of the door latches is broken so it's not hitting the switch. There should be two door latches. Are they both there? This oven could be fixed by adjusting or replacing the interlock parts as needed. Because of concerns about microwave leakage from an improper door seal, you should have this oven serviced by a professional.
May 21, 2009 | Sharp R-930AK Convection/Microwave Oven
Turntable won't stop
Sounds like a door switch problem or stuck relay contacts on the control PCB. Do the light and fan run too or just the T/T??
Nov 07, 2008 | Jenn-Air JMC9158AA Convection Microwave...
JVM1490 Low fan noise when not in use shuts off when door is open turns back on when door is closed?
it sounds as if your door switch is out of line. If this only happens when you close the door you may want to check they switches on the inside. one of them is either bad or you just may need to line it back up.
Jul 08, 2007 | GE JVM1490 Convection/Microwave Oven
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
