ERROR CODE E248-0000
Hi Friends i need help to solve this problem with my ir6800cn.I turned on the machine and i got this error code E248-0000 and the screen does not show anything except the code.Iam also hard time to get the toner.Please help.
PHILIP
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 126 Answers
E248 Main Cause The EEPROM on the reader controller PCB is faulty. The reader controller PCB is faulty. Mode of Detection 0001 The ID read into the EEPROM when the main power switch has been turned on and the ID in the ROM do not match. 0002 When data is written into EEPROM, the data written and the data read do not match. 0003
When data is written, the ID in the EEPROM and the ID in the ROM are found not to match.
****Replace the EEPROM****
Posted on Feb 01, 2009
How I Can Solve the Code C-0540
To reset Error codes C0500 and C0501, perform the following steps.
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
May 18, 2014 | Minolta DI-2010F Copier
Minolta di450 how i can solve this code c-0540
May 18, 2014 | Minolta Office Equipment & Supplies
How can i solve when it flashes on the panel
To reset Error codes C0500 and C0501, perform the following steps. 1-Turn the machine "OFF". 2-Press the "STOP" button on the basic panel. 3-Keep the button pressed and turn the machine "ON". 4-Do not release the button, until the machine warm up. 5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
May 14, 2014 | Minolta DiALTA Di183 Copier
We have a belini dishwasher with E4 error code what shuld we do?
Hi, there is a few things that can cause the e4 code......
overdosing the machine can cause excessive foaming.adding soda crystals can also cause this (by clogging) or water pressure is to high.
turn off machine then tilt it backwards about 45 degrees (so it does not upset the water management system) and the water should drain away solving the error code.Hope this helps
Sep 22, 2012 | Office Equipment & Supplies
My dishwasher is showing error code a10 model ide 1005
Hi, the interpretation for error code A10 is: A10 = fill solenoid valve triac closed/open circuit - check valve/ operation - machine drains until level switch resets + 30"
Now, to try and solve the problem yourself: Turn off the water supply to the dishwasher & remove the hose, Run the machine for several minutes in a normal position. Turn the machine off, reconnect the fill hose, turn the water back on then turn the machine back on.
If this doesn't solve the problem, then you'll need to call a service person.
Jun 12, 2011 | Dishwashers
CAnon xerox Machine IR 2318 L Error code : E 000007-0000
My canon ir 2318L shows error**E000007-0000 how can i solve this problem
Feb 28, 2011 | Office Equipment & Supplies
My Canon copier, Model IR 400s, Shows the error code : E 604. What is the problem ? How can I Solve it ?
My Canon copier, model IR 400s, Shows the error code : E604. What is the problem? How can I solve it ?
Sep 25, 2010 | Canon imageRUNNER 400S Copier
ITS DOING NOTHING
I'V GOT A CASIO TK-2300 ELECTRIC CASH REGISTER.ON SCREEN IT SHOWING INDW OVER 0 WHEN I PRESS ANY KEY IT SHOW MAC-CODE 0 THE NUMBER PAD IS WORKING.IF I TURN THE KEY TO REG1,REG2,RF,PROGRAM IT STAY SAME BUT IF ITURN KEY TO X1,Z1,X2/Z2 IT SHOW OPE ERROR 0.CAN SOME ONE HELP ME TO SOLVE MY PROBLEM.THANK YOU.
Apr 16, 2009 | Casio Parts Cash Register PC Desktop
Error E7
Hi, before i can help, you need to press the print button and it will show a 'sub code', which will determine the exact fault.
Cheers
Andy
Feb 22, 2008 | Office Equipment & Supplies
Bizhub c250 error code
hi
the problem is
"An exceptional
instance occurred
due to the unexpected
Parameter in
the System F/W"
you need to upload a new f/w to the copyer
best reg
pini - israel
Feb 12, 2008 | Konica Minolta bizhub C250 All-In-One...
132 people viewed this question
k24674
