Question about ASUS Eee PC 900 Notebook
Just bought a new asus eee pc 900, having trouble with audio output from music player and internet etc. had installed audacity and all worked fine for a short while, when the problem occured i uninstalled audacity thinking it may have been the source (as you can see i have no idea what im doing!!) now i cant find any way to get any listeneble volume. the speakers work fine in the diagnostics test when there are no applications running. any advice would be much appreciated, cheers, j
  • Anonymous Feb 06, 2009
    I have the same problem. Restarted and held f9 to reinstall the factory / original os and the same problem eventually comes back.
    Now when I try to hit f9 it doesn't go to the set up screen and just gets stuck in an endless loop / screen flashing.
When i start my asus eee pc 900 laptop i get an error it says
BIOS / system is not able to read ur boot files and boot sector on HD...press F8 when system starts and get into Safe Mode or Last known good comand that worked etc etc...and then do a system scan
Jan 11, 2010 | ASUS Eee PC 900 PC Notebook
Cant update adobe flash player for my asus eeepc 900 notebook
To update the flash-player, all Mozilla Firefox windows should be closed when you try to install it
Jan 04, 2010 | ASUS Eee PC 900 PC Notebook
I cannot connect to the internet on my Acer EeePC 900. When I select my network it says limited or no connection. I tried uninstalling and reinstalling but it still wont work. I have windows XP. Its...
If you are connecting via wireless, the reason is usually because your router has lost its internet connection. Try switching the wireless router off, waiting 10 seconds and switching it on again. Can you explain how you are trying to connect and if you can use any other computer successfully, etc.
Jan 02, 2010 | ASUS Eee PC 900 Notebook
Bought 3 Eee PC 900/XPs. Bought recommended Crucial 2GB SODIMMS to upgrade memory for all three machines. After upgrade and just after Windows XP loads the screen goes crazy. Crucial suggested...
pop battery out ...... re-start with cord power , then shut down completely. pop battery back in after 5 minutes .....and try that ......you may also want to check your power settings .
Jul 13, 2009 | ASUS Eee PC 900 PC Notebook
Internet Connection with Errors
Why not try Firefox? You may download it from firefox.com .
May 05, 2009 | ASUS Eee PC 900 Notebook
I deleted my audio driver and my sound
You should be able to use the AC97 HD codecs available from Realtek with your sound device.
Post your results under this thread, especially if you continue to have problems after installing the driver.
Apr 15, 2009 | ASUS Eee PC 900 16G Notebook
Motherboard
Return it back with an explanation letter and your last reference number.
Mar 27, 2009 | ASUS Eee PC 900 Notebook
Audio device gone
Try and download your audio driver from here and see if it works:
http://support.asus.com/download/download.aspx?SLanguage=en-us
Mar 11, 2009 | ASUS Eee PC 900 Notebook
Cannot install bulit in cam of eee pc 900
try turning the webcam on from the utility tray icon (located in the lower right portion of your screen). Webcam is typically enabled in the BIOS as a default.
Mar 10, 2009 | ASUS Eee PC 900 Notebook
I asked my friend to fix a problem with my eee pc 900 because it said something about a missing file with a filename that contains systems32 i think. i hve no idea what she did with my eee pc 900 but when...
if the windows working perfectly good and the sound only is the problem,means you re-install the driver of the sound driver..maybe this is the file contains accidentally removed.deleted...
Dec 12, 2008 | ASUS Eee PC 900 16G Notebook
ASUS Eee PC 900 Notebook Logo
124 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
