Home | RCA | DRC8312N DVD Recorder / VCR Combo | Rca 8312 Won't Play Dis...
RCA DRC8312N DVD Recorder / VCR Combo
Problem for RCA DRC8312N DVD Recorder / VCR Combo
Rca 8312 Won't Play Disc.......
By RMcDuff on Jan 31, 2009
My RCA DRC 8312 loads the disc then states it is "reading disc" for approx 30 seconds then states "no disc". I've tried multiple discs, sprayed air into the player trying to loosen any dust particles on lense, purchased a Maxell lense cleaning disc but it won't play that either.
When I open the tray , remove the disc, and close the tray it still says it is "reading disc" even though there is no disc in the player. Eventually is says "no disc". Can someone help me? I'm at wit's end..........
Solution #1
posted on Jan 31, 2009
Not Rated)
welcomejee
Rank: Guru  Televisions & Videos  Expert
Rating: 89%, 3087 votes
Optical block is defective and requires replacement but cost would be approx new unit so better to buy new dvd player.
Solution #2
Not Rated)
Benimur
Rating: 88%, 3768 votes
Hi and welcome to FixYa,
Almost always, your described problem indicates a faulty laser optics. Your post that it is still reading even when tray is empty validates this. The correct procedure would be to replace the laser optics. This however is an assembly that includes the carriage and support mechanism. In some instances, would even include the tray and other mechanical structure.
Based on the above, the cost of replacement assembly, cost of service, downtime and waiting time plus age of the RCA, you may want to re-evaluate your options and consider a replacement. If you are not venturing into a DIY (do-it-yourself), then repairs may no longer be economically justifiable.
Good luck and thank you for using FixYa.
Solution #3
Not Rated)
ginko
Rank: Guru  RCA Televisions & Videos  Expert
Rating: 89%, 5031 votes
That means that either the lens is dirty or defective, orthe motor is not spinning, if the motor is spinning then it is the lens.
The unit must be taken apart to clean or replace the lens pickup, or to see if there is any broken part inside, when it says no disk , it is usually the lens.
Popular Solutions for RCA DRC8312N DVD Recorder /
Questions and Unsolved Problems for RCA DRC8312N DVD Recorder /
Do you recommend RCA DRC8312N DVD Recorder / VCR Combo?
Answer
Answer
Have used this brand new VCR to DVD recorder model DRC 8312 for about 30 minutes playing a tape last... (More)
Answer
Trying to record tape on a disc says no disc. I have dvd-rw
Answer
RCA Model #DRC8312N problem: Picked up a movie from Blockbuster (DVD video) and the RCA unit says... (More)
Answer
my player wont play or record any dvd - just says disc problem .
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For RCA DRC8312N DVD Recorder /...:
Top DVD Player Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more DVD Player Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
