Question about Toshiba 43AX60 43" Rear Projection Television
Sound but no picture
When the TV is turned on we can hear the program on TV but there is no picture....just black. Toshiba Chassis# TAC9859
  • 2 more comments
  • Tamara Lansinger Aug 01, 2007
    Model # TP43H60
  • Tamara Lansinger Aug 12, 2007
    Can you give me some idea as to where these problems maybe located and what they look like. I want to make certain that I have the right piece that I am looking at.
  • Tamara Lansinger Aug 14, 2007
    Looking for a little more detailed help please.
  • Tamara Lansinger Sep 05, 2007
    I've already got a multimeter and soldering iron just waiting for the service manual to arrive.
    Thanks for checking up.
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
When the TV is turned on we can hear the program on TV but there is no picture....just black. Toshiba Chassis# TAC9859 very simple as you hear program means sound is ok can you see light? if light is there & sound is there ypur problem in video or luminance section unless you know tv tech please do not open the set. please let me know .
Posted on Sep 14, 2007
    President:
  • 3,130 Answers
This could be a problem in the vertical sweep circuit, as when the vertical circuit fails, The video or screen will blank out so the picture tubes do not get damaged. In this chassis, I have seen the convergence IC's cause this, or the capacitor in the sweep power supply that feeds the voltage to the vertical IC has failed and blew out the vertical output IC. If you have no solid state repair experience, play it safe and call in a trained tech to assist you in this repair. Good Luck.
Posted on Aug 12, 2007
  • 2 more comments
  • Larry  Dillon
    Larry Dillon Aug 13, 2007
    You will need to get the service manual first. But if you do not understand how to read a schemaric, or a circuit diagram, it will be waiste of money
  • Larry  Dillon
    Larry Dillon Aug 18, 2007
    Like I said before my friend, you will need to get a service manual and see where you are losing the video. It most likely will be in the protection circuit, so when the vertical sweep goes out or the vertical convergence goes out, it does not damage the picture tubes. Do you have a multimeter we can use and trace voltages with? If so and you can follow a schematic diagram, get the manual and maybe I can guide you through the circuit and see whats happening to the video.
  • Larry  Dillon
    Larry Dillon Sep 04, 2007
    You need to buy a service manual first to trace out the circuit flow. We simply cannot tell you or guide you blindly without knowing what is in the circuit, and all sets are different. You will have to spend a little to fix this TV set I'm afraid. You will also need a multimeter, a soldering iron, and a knowledge of how the knowledge to use them. There is I'm afraid no magic fix to fix this TV set.
  • Larry  Dillon
    Larry Dillon Sep 05, 2007
    When you get the service manual, let me know.
SOURCE:
Toshiba 40rv525r LCD t.v. have sound but turned
Sorry, I donʻt have solution, but I do have this exact same problem, same model of TV! Iʻm wondering if youʻve had it fixed yet and if so, how did you do it?
Apr 20, 2010 | Toshiba 40RV525R 40 in. HDTV
TV turns off after lightning strike
please post how many time it blinks, this does help us solve your problem.
Jul 25, 2007 | Toshiba TE55T11 55" Rear Projection...
I have a toshiba projection t.v. and while the t.ve is on the picture gose black you have no picture as if the t.v. was off but you still hear sound but it dosen't do this all the time and when it dose it...
This is probably a cold solder joint on the bottom of the chassis. I would look at the Vertical IC first, then Convergence IC's. Then look over the entire board.
Nov 07, 2009 | Toshiba TP50G50 50" Rear Projection...
Toshiba 32a43 32' picture garbled mess
If you can get the tv to display the blue blackground(usually happens when there is no antenna or cable feed to tv) check to see if the whole screen is a solid blue, if it shows discolored areas around the screen then you might have to "demag" the screen. See if you can rent a demad coil from a tv shop and with tv on turn the coil in circular movements all over the front of screen till blue is solid.good luck!
Aug 03, 2009 | Toshiba 32A43 32" TV
Green light but no picture, no sound
Your mainboard is damaged, replace it and that will solve your issue.
Jun 06, 2009 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
No picture or sound mitsubishi 62525
Capacitor failure is the most likely scenario the FMT ans Signal PWB would cause the picture interference and the power pwb would cause the lamp light to turn red and give a 34 code when the device/ input and menu buttons are pressed in together and held for five seconds. That chassis has issues with every board in the chassis having failed capacitors you can get repair kits for the V26 chassis at the follwing link that come with instructions. Your model is the V26 chassis. Heres the link.
http://servicemanuals.vstore.ca/
Jan 25, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Scrambled picture
Which caps on which boards as that sounds like a issue with the signal and FMT PCB. The v26 chassis like yours has problems with bad caps on the DM, Signal, FMT and the PWB and terminal
Jun 28, 2008 | Mitsubishi WD-52525 52" Rear Projection...
No picture, hear sound, television will shut off after a few seconds.
Lamp life is only a few thousand hours. Hopefully its only the lamp that made to noise. Don't turn on again until lamp is replaced.
Nov 05, 2007 | Toshiba TheaterWide 52HM84 52" Rear...
No picture or sound
Pull chassis = check F850,851 micro fuses =no good ?
Replace STK IC's called convergence amps = Some special
soldering is needed = let me know.......................T.
Oct 24, 2007 | Toshiba 43H71 43" Rear Projection...
Toshiba tz50v51 popping sound
Possible problems: * The TV set may be unplugged. * A fuse or circuit breaker may be blown or switched off. * The remote control unit (RCU) may be disabled. Solutions: * Make sure the TV/VCR are plugged in and the wall switch is on. * Check the fuse or circuit breaker. Test the outlet with a lamp. * Replace the RCU's batteries: if this fails exchange the unit.
Jan 18, 2006 | Toshiba TZ50V51 50" Rear Projection...
Toshiba 43AX60 43" Rear Projection Television Logo
133 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
