Question about Bosch TDA8340 Iron
I need to disassemble a Bosch TDA 8310 steam iron.
The heating element in my Bosch TDA 8310 steam iron needs replacing and I need to understand how to disassemble the iron in order to install the replacement sole with the heating element in it.
oscarn
  • 110 Answers
SOURCE: Water drips out of steam holes
I suspect that by placing it on its heel rest the water from the tank is not allowed to enter into the steam chamber and when you go into ironing mode there is a rush of water that is cooling down the sole plate to below steaming temperature. Try keeping it in the horizontal position on a heat proof pad and press the steam button just before going into ironing mode.
Posted on Sep 21, 2007
SOURCE: sticky black mark under my tefal iron
yes i did fix the probleme thank you. I did not that if i use you it would cost money.
Posted on Oct 06, 2009
SOURCE: euro-pro EP1005 iron--iron heats -blower works-but no steam
You may not need a new iron, my wife's iron is doing the same thing. take the top of the ironing board off (you will need a torx t-20 security bit driver), under the tank is a connection that may have rusted out re-connet it and turn the iron on. Once it heats up, check the tank for leaks. The tank may need to be replace as well or try a 5-minute epoxy type glue on the leaks once it has cooled. If the tank leaks you will get not get enlugh pressure building up to get the steam.
Posted on Jan 05, 2010
heatman101
  • 43501 Answers
SOURCE: the sole plate of my steam generated iron is clg
Here is a tip that will help you with that problem...
Cleaning a Steam Iron Soleplate
http://www.fixya.com/support/r5301167-cleaning_steam_iron_soleplate
heatman101
Posted on Jul 15, 2010
  • 244 Answers
SOURCE: I have a Bosch Steam
Your steam generator my have mineral deposits that are clogging the steam openings. One of the easiest things to do is to pour out the water and add white vinegar. Let the vinegar sit for about 2 hours. Then turn on the iron and press the steam button until the deposits are loosened and flushed by the heat and steaming vinegar. Do this on a towel or other absorbent fabric so you don't stain your ironing board. You may need to unplug the iron, let it cool and then gently **** the steam vents with a wooden skewer or toothpick.
I hope this helps you. If it does, please rate my suggestion!
Posted on Jun 02, 2011
The iron of my steam generator does not heat up
I had the same problem. You need to disassemble the iron itself. From memory there are two torx screws near the cable entry and there is also one under the coloured part on the handle at the switch. Yo need to take off the cover to get to it. Once you get the iron apart you need to get to the base element. On the top of it is a bimetallic switch element. I discovered that I had some carbon build up between the contact points of the switch. I cleaned these (no need to remove) with some contact cleaner and rubbed lightly with fine grade sandpaper. Reassembled and has been working fine since
Jul 08, 2014 | Tefal Pro Express GV 8120 Iron
Hi Ihave a Bosch B25L steam generator iron and it has stopped steaming completely. Any ideas?
Yousaf/Tony, Either the switch is defective or the heat element has gone bad, probably not cost effective to repair.
May 25, 2014 | Bosch sensixx TDA 8333 Iron
My Steam iron has stopped doing steam no light coming on what is wrong
The iron may be clogged and unable to generate steam or, possibly, the heating element has failed.
Apr 20, 2014 | Bosch TDA2445 Iron
Too hot to handle spits water from sides Bosch sensixx B10L
I just fixed mine - it had exactly the same problem.
First, though, check it's not within the Bosch TWO year guarantee; if it is, they'll either fix or replace it.
If it's not under guarantee then the problem is probably the rubber tubing that connects the external steam tube to the hotplate. You'll need to dismantle the iron. Mine had split right next to the spring clip that holds it on. I shortened it, clipped it back on and all is now well.
Dec 22, 2012 | Bosch sensixx TDA 8333 Iron
Bosch sensixx B25L no steam
Are you sure that you have the correct settings chosen? It sounds like you have a faulty unit!
Sep 26, 2012 | Bosch sensixx TDA 8333 Iron
Bosch Sensixx B25L
see the instruction from your manual:
Check the owner's manual for your iron to learn the manufacturer's suggestions for cleaning, what water to use, and storage tips.
Soft-water systems add minerals that can harm an electric steam iron and your clothes so don't fill the iron with softened water. Instead, use filtered or distilled water.
2) if the iron does not heat a( test the power cord for open or defective b) and thermostat for adjust c) test the thermal fuse d) test the heating element for open.
God bless you
Jul 31, 2012 | Bosch Irons
HI I have a Bosch Sensixx B25L iron. Steam isn't coming out of holes, seems to be escaping from edge of iron. Handle very hot (Too hot to hold on to), burns your hand when steam button is pressed
Jul 28, 2012 | Bosch sensixx TDA 8333 Iron
Bosch iron TDA76 light comes, on no heat
Hello, welcome to Fixya!
The problem is either from the heating element or a disconnected/loosed wire.
Get a screw driver disassemble the iron and check for any visible wire disconnection or burn. If all wire connection in the iron are intact, then it means the heating element of the iron is defective and needs to be replaced.
Good luck.
Nov 04, 2011 | Irons
Tefal steam iron not heating up properly
That is probably because the contacts to the element at the base of the iron are broken.
To disassemble you have to remove the casing, then remove the steam pump at front top of iron and then undo the safety screw mounted on the front of the base plate.
Apr 22, 2009 | Tefal UltraGlide plus 1656 Iron
Bosch TDA8340 Iron Logo
588 people viewed this question
Top Bosch Irons Experts
Colin Stickland
Colin Stickland
Mark Chaney
Mark Chaney
matt
matt
Are you a Bosch Iron Expert? Answer questions, earn points and help others
