Question about RCA PHD42600 42 in. Plasma Television
Samsung plasma tv 42inch PS42E THDX Blue sparkles on dark areas
Whether watching DVD sky or normal tv we always get the blue sparkles on the dark areas of the picture somtimes the picture can look very pixilated too , TV is 3 years old am i still covered by warranty ?
Hi yes i had the same problem and its basically because the tv needs a software upgrade. I contacted argos and they sent an engineer to sort it and he plugged something into the back of the tv to upgrade it. all in all it took 5 mins to do and not had a problem since.
Posted on Mar 10, 2009
Lg Picture distortion on LA860
call the tata sky costumer care and complaint against this. they will solve this kind of problems.mean while you can check it with your any DVD/blue ray player whether tv is working correctly?
Nov 07, 2013 | Televison & Video
Blue dots on black images
I can tell you that I had my plasma screen replaced in the 4th year. The tech told me that the replacement panel was much more reliable. You may be looking at replacing the plasma panel...(which may be more expensive than replacing the whole unit??).
Jan 29, 2013 | Samsung HP-S4253 42-Inch Plasma HDTV
Error diffusion on Samsung 50" PLASMA TV
Yes the diffusion problem on your tv is due to the pdp panel aging. What you can try is readjusting the VSCAN voltage, there is a test point marked VSCAN using a DVM you can first check the voltage, should be around -- 190 turn the adjustment counter clockwise this should reduce the voltage, watcthing the picture turn control untill the sparkling pixels stop. That should do it. The panel is starting to age this may occur again until you can't adjust it out meaning a bad panel.
Dec 08, 2008 | Samsung HP-S4253 Television
Static on 50
Dec 08, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
We have a samsung 50" plasma. When we have alot of the colour blue on the programme we are watching the TV blacks out for about 5 seconds and comes back on Continously whilst blue is on the screen. It...
If the samsung is more than two years old it is probably the Tv. I have a 42" samsung and the color blue will appear all over the tv for awhile and then go away. It started after two months and I just thought it was from playing xbox. I believe its a known defect in the tv or related to burn in. If you got it from a store use your coverage on it
Apr 29, 2008 | Televison & Video
You should have a AUDIO menu in which you can simulate true surround sound. This should be in your owners manual. Your DVD is recorded in dolby surround sound that's why on your set it will be reproduced as recorded. I hope Samsung is using a ATSC tuner in that model?
Apr 04, 2008 | Samsung HT-Q100 System
Problem with samsung plasma tv
hello ive just bought a samsung plasma off my friend and its about a year old and yesterday i set it up and get a fine picture untill about a hour or so of being on it starts geting blue sparkles round the outside of the tv mainly on the left side and seems stronger when sport is on ive tryed doing different things but nothing seems to work?i have also bin told that plasma tvs have to have gas put in them every so often is this true?i dont no which samsung model it is but it is 42inch and is full hd ready and is black with the round circle on the front of the tv can you help me?
Dec 19, 2007 | Samsung HP-S4253 Television
Makes you wonder why nobody is taking on the problem, doesn't it?
Well , to the best of my knowledge, it is because nobody really can.
To understand why you have to understand what do they sparkles come from.
They are random electricity discharges coming from capacitors or other components that act like capacitors, but mostly capacitors.
When laymen hear about capacitors they usually associate the word with bulged electrolytic capacitors, which often cause problems in electronics of all kind.
Well this time it isn't about them.
It's about all other capacitors - or other components exposing similar qualities - which are installed on the board. Most of them are small filter capacitors put in parallel to the big ones or to other passive components such as diodes and resistors.
The excessive heat developed by the sustain boards damages those capacitors. It hardens the electrostatic material they are made of and small breaks in it start occurring at voltages that shouldn't otherwise be causing issues.
The trouble is, they can be everywhere. You can't just pinpoint which ones were caught at fault and causing the sparkles.
When it gets REALLY bad eventually the whole capacitor burns and either shorts or, more commonly, just breaks.
Believe it or not I've seen a board that exploded before my very eyes and , after the explosion, started working LIKE A CHARM!
Turned out a small filter capacitor had blown. It as not essential for the board's functionality and after being problematic for so long and causing image deffects it had eventually shorted completely and literally exploded.
Luckily, the short it had created was too short in time and apparently in a circuit that could take the load for a short while without getting damaged.
So after it blew everything worked just great!
it's a real story from my repair experience.
Hope this helps all consumers, DIY enthusiasts and competitors alike :-)
For more you are welcome to visit our site and read our tech repair blog at
and .
Aug 26, 2007 | LG 42PX5D 42 in. Plasma HDTV
One of the pictures has a great blue sky but the green tree is very dark and the other one has the green tree and very bright sky?
The two pictures were shot at dramatically different exposures - the "dark" one at 1/1600 shutter speed, f7.3, the "light" one at 1/320 shutter speed, f4.0. This accounts for the great difference, as the exposure conditions for the "light" one allowed much more light into the image during the exposure period. You didn't tell the whole story of how you set this up, I think you were shooting in a "spot" metering mode, where the particular exposure conditions the camera uses would vary considerably whether you were aiming at a dark area (making the picture light) or a light area (making the picture dark). I would make two recommendations: Switch your metering mode to "center weighted" (the mode labeled "[(•)]"), and also change your ISO setting to AUTO, as there would be no reason for shooting these photos at ISO 200 that I can think of.
Sep 04, 2005 | Panasonic Lumix DMC-FZ20 Digital Camera
RCA PHD42600 42 in. Plasma Television Logo
891 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
