Question about Cooktops
The way to change a cookng ring element under ceramic hob
The electric cooker is a Hotpoint BE 41 If Be 41 is not the right number the same question for any cooker might help
4 Suggested Answers
SOURCE: Electric ring stopped working on my T1250 Cooker Hob.
MY PHONES RINGER STOPPED RONGING MEYBE THERES SOMETHING WRONG WITH IT
Posted on Jan 18, 2008
SOURCE: Replacing faulty regulator for hotplate
Remove hotplate and oven control knobs. Under the 2nd and 5th knobs is an extra screw which holds on the front cover. Unscrew these and free the cover then access is gained to the screws (2 on each edge) which removes the plate to which the regulators are fixed.Remove the faulty regulator by unscrewing it from the plate,(2 screws) It is an easy job then to install the new part taking care to put the correct wires on the correct terminals. Reassemble, job done!
Posted on Jan 13, 2009
  • 254 Answers
SOURCE: I can't unset the child safety lock on my diplomat ceramic hob
get the model number if a cooktop will be underneatth on sticker.... go to kitchaid.com and locate thier manuals and literature section where u can download a copy or print one out.... hope this helps
Posted on Feb 06, 2010
heatman101
  • 43501 Answers
SOURCE: electric ignition to hob seems to be jammed
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Posted on Aug 18, 2010
I have broken the glass on my induction cooker
ENr is on rating plate on bottom of hob. The Ceramic top is easy to replace, it is held on by 3 pozi screws on each side (12 altogether) and just sits on the main electrical parts, obviously the unit should be isolated from main before you remove the top. Part can be ordered using the link
http://www.bosch-home.co.uk/store/spareparts/search
Mar 16, 2013 | Bosch Cooktops
USER MANUAL FOR SAMSUNG CERAMIC HOB C61R2AEE
Samsung has the manual you want is the 1.75 MB PDF at the bottom of the list here: http://www.samsung.com/uk/support/model/C61R2AEE/XEU-downloads . If this second link doesn't work, follow the directions below to reach this page.
Samsung has the User's Guide for the oven on the Support tab, see http://www.samsung.com/uk/consumer/home-appliances/cooker-hobs/ceramic/C61R2AEE/XEU . The support tab is on the right. The manual for the cooking hob can be accessed from the Need More Downloads link below the Download button.
I hope this helps.
Jul 06, 2012 | Cooktops
The top of my halogen hob has cracked from top to bottom thro the centre is there any way of repairing it? it is a 5 ring creda rangemaster
you cant repair the glass but you can get the ceramic glass as a spare part. you will need the exact model number to get the correct part once done your hob looks brand new. if cracked through one of the zones you could chack there is no damage to element or themal cutout running across the centre of the element before proceeding.
Aug 22, 2010 | Cooktops
Has anyone figured out a way to remove the dark stains that you can't get out on the ceramic top with the recommended cleaners?
no any kind of chemical u can use to remove the stain,coz its normal for ceramic hob cooker coz of pots n pons every time u use.
Jul 02, 2009 | GE 30 in. Profile JP350 Electric Cooktop
Jan 11, 2009 | Belling Cooktops
Hob turns off
hi im gerbee my suggestion is replace the pcv control wat brand u have,always also in philipines the electric hob is so very sensitive,the pcv cotrol is not repairable.or next time u by a new one gas cooktop more ok compare to electric ceramic hob, or use electric ceramic hob w/knob control compare to sensor type,i think the part of the sensor or pcv control is so very expensive,that why i buy an another one.dont try to repair more difficult to com.tnx
Nov 24, 2008 | AEG 23 in. 6410KF-N Electric Cooktop
Neff T1722 so 02 ceramic hob
its normal for the ceramic hob to ON & OFF coz of the sensor inside the unit to protect for overheating.same here in phillipines.its normal.tnx gerbee
Jul 28, 2008 | Neff 23 in. T1443 Electric Cooktop
Nov 04, 2007 | Neff 23 in. T1252 Electric Cooktop
Cooktops Logo
514 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
meztang
meztang
Are you a Cooktop Expert? Answer questions, earn points and help others
